#29 |
Drives: FR-S 10 series
@ARK Performance
Thank you for finding this thread and replying to my concerns. I will try again an ask for my brother's asistance this time. I will loosen all the bolts and start tightening from the engine side as you say. Any other recomendation? Like do you recommend hanging just two hangars or do all 4 while i tighten? BTW I am extremley happy with this. The quality and looks are top notch and the sound is absolutley impressive. Thank you for this as well. I have no problem paying well for a well made product, and you delivered! Props to you |
#30 |
Drives: Subaru BRZ
@pablitomarerro
My biggest recommendation would be to do it on a lift, it is very difficult to do it on the floor with jack stands and a jack, you are given a lot more leverage when on a lift. Next thing is to make sure all the hangers are in while you tighten the exhaust |
| The Following User Says Thank You to ARK Performance For This Useful Post: | Pablitomarrero (08-23-2013) |
#31 | |
Drives: Firestorm FR-S AT
| The Following User Says Thank You to UnOvertime For This Useful Post: | Pablitomarrero (08-23-2013) |
#32 |
@ARK Performance
Well I dont have a lift, so jack stands will have to do. Ill try it again, this time all the way from the engine side. The only thing I adjusted last time was the middle section with the part going to the midpipe fully bolted down. Thnks! Crossing fingers |
#33 |
@ARK Performance
Update: so I finally gave in and went to a muffler shop to adjust it... Try as they may the right side still hung lower. And so I looked at older pictures with the stock exhaust and found the problem: stock exhaust also hung lower on the right side. So the shop just banged one of the hooks holding the exhaust and presto. Perfect. Thanks for your help! |
#34 |
Drives: Subaru BRZ
sounds good! thank you for double checking and I'm glad you're happy with the system!
| The Following User Says Thank You to ARK Performance For This Useful Post: | Pablitomarrero (08-28-2013) |
#35 |
Drives: Ultramarine FR-S
@ARK Performance What's the DT-S system's weight?
#36 |
Drives: Subaru BRZ
The DT-S is about a few pounds lighter than stock but very minimal
#37 |
Drives: 2013 86 white
Which outlet tip has larger diameter when look in person DTS or Evo3? This car need the bigger tip to fill that cut-out.
#38 | |
Drives: Subaru BRZ
Anyone else looking to buy an exhaust? ![]() Give me a call or email. erick@arkperformanceusa.com |
#39 |
^ Pm me, may be I think you have good deal local pick up for DTS and Grip !
#40 | |
Drives: 2013 Asphalt FR-S/2003 Honda Accord
starting from engine back means I gotta unbolt everything from the pipe right? |
#41 |
Drives: Yes
Holy thread resurrection Batman, but I just installed this exhaust over the weekend and felt like chiming in on how sweet this exhaust sounds... the tone is deep AF! And it looks amazing too.
Combined with the uncatted Perrin front pipe that I already had, it's pretty damn loud. I'm quite sure I wake up the entire street with cold starts, so I may have to throw the factory front pipe back on soon to see if that tones it down a bit. Despite being a loud exhaust, it's quite easy to shut it up on the freeway with the right throttle input. Hums a bit under light acceleration but I wouldn't describe it as "drone". WOT is audible sex. According to the butt dyno, car also feels torquier down low, but not sure if that has something to do with the Perrin inlet hose I installed at the same time.. One tip sticks out further than the other (only noticeable to me), I think this may have to do with the Perrin front pipe being slightly shorter than the factory one (took a bit of force to mate it to the midpipe), so I should be able to correct that when I swap out the FP. Overall, great system @ARK Performance [ame="https://www.youtube.com/watch?v=3azs5o9YCxA"]ARK DT-S with Perrin Overpipe & Test Pipe - YouTube[/ame] Update for anyone who cares: Putting the stock front pipe back on toned it down a bit, and now it is just a nice deep tone without the obnoxious cold-start. The tips are now perfectly aligned as well: I was using the factory donut gasket on the Perrin front pipe which added a bit of extra clearance between that and the midpipe.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#42 |
Drives: 2012 Evo X - STOLEN
Any comments on how an unresonated midpipe + UEL manifold makes this sound?
| Perrin Catback Exhaust Installation and Review! | Sony | Engine, Exhaust, Transmission | 316 | 01-24-2016 01:01 PM |
| Perrin Pulley review? Invidia Q300 exhaust review? | ScionFrsFan | Engine, Exhaust, Transmission | 4 | 12-10-2012 08:27 PM |
| Review of ISIS Street Catback exhaust | sirhc | Engine, Exhaust, Transmission | 24 | 10-29-2012 04:57 AM |
| 2013 Subaru BRZ Limited Start Up, Exhaust, and In Depth Review | delta86 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 06-26-2012 03:25 AM |
| AutoExpress BRZ Review - Follow up to the GT86 Review | Zgrinch | BRZ First-Gen (2012+) — General Topics | 3 | 12-13-2011 08:03 AM |
