#29 |
Drives: AE86, 2x GT86, TE27
#30 |
I Love custom Turbo kits
Drives: Limited BRZ
No problem, I know where you are coming from
![]() Boost plot here: http://www.ft86club.com/forums/showp...postcount=1707 Dyno here (it's a work in progress, but we ran out of time on the Dyno, DISREGARD AFR, was off by more than a point): http://www.ft86club.com/forums/showp...postcount=1701
#31 |
Hmm interesting.
Based on the dyno, I'd say you're not making full boost till 4800, as that's when peak torque is basically reached. Say max boost was reached at 4300, then I can't see why torque would continue to climb between 4300-4800, if boost stayed constant. |
#32 | |
Drives: Limited BRZ
But still, even if it were 4800, it is not 5500 either. I will look at the log again and see if I can point out why 4300 not 4800. Edit: @diss7 I will also add that the moment where you reach max torque does not automatically means it hits full boost there. There are different tuning strategies and one of them is to ease the torque hit via cam timing, and ignition timing and that peak torque can be phased to a different point than the first hit of full boost.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | diss7 (02-05-2014) |
#33 |
Agree 4800 is better than the 5500 I was stating. Can't recall who's dyno I saw around 5500, must have been ptuning, but I think they're gt3076r, not gtx. Which would account for the difference between 4800 and 5500
#34 |
Drives: Limited BRZ
Full boost is reached at 43XX and 44XX in both. I believe the matter of reaching full torque later is a matter of tuning. I've seen JR tunes with a GTX28 where torque peak is at over 5K, where he explained specifically he delayed the torque hit to make it a smooth progression and being easier on the motor.
.82 Backhousing Looking at Log one 4085 7.34 4117 7.92 4163 8.355 4213 8.79 4277 9.66 4319 9.66 4322 10.095 4424 9.805 4442 10.385 4512 10.24 4585 10.095 4614 9.66 4712 9.805 4734 10.095 4870 10.385 4868 10.53 4970 10.53 Second log: 4109 6.76 4119 7.195 4135 7.195 4193 7.63 4231 8.5 4314 9.08 4354 9.66 4436 9.805 4444 10.385 4471 10.095 4540 10.095 4622 10.095 4640 9.805 4672 9.95 4765 10.24 4819 10.53 4874 10.24
#35 |
It really depends what your full/target boost is.
#36 |
Drives: Limited BRZ
Very true. full boost targeting 10 psi will be reached at a different RPM than 20 psi.
#37 |
Yep that's where it's hard to compare numbers as well. People running these turbos on EJs and SR20s, etc. are generally running at least 18psi or so on a GT30 series turbo, most times more than that because they are looking to make 400+ WHP. Those looking to make 300-350WHP are usually using the GT28 series stuff since it accomplishes their goals with the least amount of lag.
It's difficult on this motor with the 12.5:1 CR. It can help mask some of the lag and if you are willing to deal with a little more lag you can make the power on a GT30 with a lot less heat than the smaller turbos by running less boost. |
#38 |
I can't wait to get my gtx2863r on and get some comparisons. From the performance above of a gtx30, my turbo is going to be awesome as a daily / track hack.
Edit - I'm hoping for ~250ft/lbs from 10psi, from 3500 (or less ) to 7000rpm. If it starts to taper at 7000rpm, then I can live with that. Although I think the gtx2867r graphs I am seeing this on, are more a reflection of the gtx28 0.63 turbine housing becoming restrictive. I am hoping my 0.86 with 3" exhaust (with no cats or mufflers) will help/solve this issue. Its got to be the turbine, the compressor (even the 63r) can provide the airflow, somewhat efficiently at 7500rpm. Its certainly very efficient up untill 7000rpm.
#39 | |
Drives: Limited BRZ
#40 |
Much impress. wow.
| The Following User Says Thank You to diss7 For This Useful Post: | Sportsguy83 (02-05-2014) |
#41 |
Boosted
Drives: Not a supra....yet
| The Following User Says Thank You to SmsAlSuwaidi For This Useful Post: | Sportsguy83 (02-05-2014) |
#42 |
Im pretty sure I have the GTX2867R with methanol injection, full 3" catless exhaust and my car is being tuned presently. I hope by next week sometime for it to be done.
I'm hoping over time to get it fine tuned and show some good numbers. I'll post graphs when I get them. |
| Which turbine size for gtx3071r? | diss7 | Forced Induction | 67 | 02-02-2014 08:19 PM |
| EFR6258 vs GTx2863R | diss7 | Forced Induction | 25 | 12-01-2013 10:15 PM |
| Garrett GTX2863R turbo, TiAL v-band wastegate | Turbowned | Engine, Exhaust, Bolt-Ons | 10 | 11-27-2013 02:07 PM |
