Old 02-05-2014, 03:35 PM   #1219
Ross
Drives: 85 corolla gts
push lock will be fine just make sure to use the appropriate hose
Ross is offline   Reply With Quote
Old 02-05-2014, 03:40 PM   #1220
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Originally Posted by SmsAlSuwaidi View Post
Only thing that comes with this kit is a pile of sh**
Sent from my IBrick
Hey I know you got burned and all... But I'm really tired of you spewing nothing but negativity with almost every post you make. You help make this experience coming to the forums worse every time. Give it a break.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following 3 Users Say Thank You to feldy For This Useful Post:
bgibbsunc (02-06-2014), ecko04 (02-05-2014), lbroskee (02-05-2014)
Old 02-05-2014, 03:42 PM   #1221
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Well its an owners thread i happen to kinda own one, and the point is i want people to get informed about this product.
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
FAER (02-05-2014)
Old 02-05-2014, 03:44 PM   #1222
feldy
feldy's Avatar
Sent from my IBrick
People are informed you don't have to repeat your self a million times over. You made your point over and over and over again. You are just beating a dead horse.
The Following 5 Users Say Thank You to feldy For This Useful Post:
ecko04 (02-05-2014), FR-S FI (02-05-2014), lexusb3 (02-05-2014), Mild2Wild (02-06-2014), tg_1981 (02-10-2014)
Old 02-05-2014, 11:03 PM   #1223
FAER
Drives: Silver BRZ
you could always put him on ignore rather than telling him what to do....
FAER is offline   Reply With Quote
The Following 2 Users Say Thank You to FAER For This Useful Post:
Lonewolf (02-06-2014), SmsAlSuwaidi (02-05-2014)
Old 02-05-2014, 11:27 PM   #1224
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
FA20Club Turbo Kit Owners Topic
Sent from my IBrick
Taking your anger out on the owner is misdirected. You're not harming Toni by making those statements to a fellow owner.
Chiming in when an owner asks for help with the system he already has with useless information of no value is excessive and at the end of the day doesn't help him resolve his problem.
Shouldn't the FA20Club kit be coming with all the needed hoses and fittings along with instructions or are you adding a GTX turbo to the kit when you ordered it with a non water cooled turbo? I can tell you that I pulled the coolant from the flat coolant jacket that goes over the top of the block and returned the coolant to a vertical fitting on the back of the driver side of the block. I essentially used the coolant hose locations that would normally warm the throttle body to instead cool my turbo.
Thanks for answering the question at hand @King Tut.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following 8 Users Say Thank You to ecko04 For This Useful Post:
bgibbsunc (02-06-2014), FR-S FI (02-06-2014), jamesm (02-06-2014), lbroskee (02-05-2014), lexusb3 (02-05-2014), pixel67 (02-05-2014), Ryan P (02-06-2014), tg_1981 (02-10-2014)
Old 02-06-2014, 01:21 PM   #1225
Ryan P
Well said ecko04. Thank you King Tut , Ross (behind the scenes this man has been a huge help)
Sent from my SPH-L710 using Tapatalk
Ryan P is offline   Reply With Quote
The Following User Says Thank You to Ryan P For This Useful Post:
lexusb3 (02-06-2014)
Old 02-08-2014, 09:18 PM   #1226
Dan@AWD
Drives: 2013 Argento FR-S
My kit is for sale.
http://www.ft86club.com/forums/showthread.php?t=57655
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Dan@AWD is offline   Reply With Quote
Old 02-08-2014, 09:23 PM   #1227
Ryan P
Im still awaiting the rest of mine
Old 02-16-2014, 07:36 AM   #1228
Justkiz
Drives: WRB BRZ
urgent help needed! I'm in the middle of installing Fa20club turbo kit here in Australia and confronting few problems with fittings.
First of all, I got a 57trim kit and my car is a BRZ (RHD).
most of small troubles were ironed with relatively simple fabrication except one.
The biggest problem is my down pipe is too short, there is about 1inch gap to the over pipe. I have a Perrin over pipe and it has a exactly same length as a stock one. and also bottom o2 sensor is hitting the engin block.
have you guys had any similar problem? any trick to fit it?
any input would be appreciated.
Justkiz is offline   Reply With Quote
Old 02-16-2014, 08:34 AM   #1229
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Yes, mine was as well. Pretty much had to loosen everything and pull it in tight to make it work. Now shit hits the subframe and rattles. Fuck this kit.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 02-16-2014, 08:38 AM   #1230
woode
Boosted Member
woode's Avatar
You won't ever see all of it. Trust me. File claims now before it is too late, and that might pressure him into sending at least some of it.
Old 02-16-2014, 09:28 AM   #1231
Ryan P
Did after contacting you about how to. Thanks again
Old 02-16-2014, 09:41 AM   #1232
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
How long and how many boxes have you received already? Think it takes about a month for each box to reach you and you may receive 3-4 boxes, I know it sucks because this isn't the timeframe that was given but what you may want to do if you don't want to wait is contact FA20Club for a refund and return shipping if you can if they do not answer then contact paypal and let them know you gave not received product in specified timeframe.
Ny Brz is offline   Reply With Quote
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
