Old 02-05-2014, 03:30 PM   #1
AyJay
AyJay's Avatar
Drives: 22 GR86, 13 FR-S, AP2 S2000
Sharing 17x9 Track Wheels & 255 Tires with a 5x114 Car
It's been documented ad naseum how 5x100 sucks. While searching, I've seen mentions from people/shops on this forum about using the same wheels for S2000 and FR-S but none of the posts give all the details about how they are getting it done.
I currently have a set of Rota Grids 17x9 +42 5x114 mounted on the s2000 and that's probably the lowest offset I'd want to run on this car. I switched away from RPF1s in order to clear a StopTech 328 BBK.
I've theorized about using the Project Kics 11mm adapter to put the Grids on the FR-S (making it +31) however I think this probably might make the 255/40 tire rub on the outer fender wall under hard cornering? FR-S will be lowered 1" on Eibach Pro-kit and I have a set of crash bolts (both collecting dust in my garage right now).
A hub conversion on the FR-S is unlikely at this point.
Ideally, a dual drilled wheel with a +42 to +45 offset and spokes designed to clear my s2k bbk would be ideal for me but the only ones i'm familiar with are the Rota DPT and the Mach V. Mach V is out of the question for the S2000 because the hub bore is too small. As far as the Rotas, frankly, I just have less confidence in the thinner spokes of Rota DPT than I do the Grids.
So, I imagine the pool of drivers with this problem is somewhat small, but has anyone come up with a good solution for this?
AyJay is offline   Reply With Quote
Old 02-05-2014, 03:33 PM   #2
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Why is a hub swap unlikely? Theyre out there FS already
Fett4Real is offline   Reply With Quote
The Following User Says Thank You to Fett4Real For This Useful Post:
wparsons (02-05-2014)
Old 02-05-2014, 03:42 PM   #3
AyJay
AyJay's Avatar
I say unlikely because I view it as the absolute last resort and most PITA to execute. I'll searched it a lil bit and saw that Megan had a pricey kit that they've since pulled from the market... and Greddy never brought their's to market.
Probably some other options out there I suppose... i view it as a last resort tho. I'd need to see evidence that those kits are long term durable for tracked cars.
Old 02-05-2014, 03:56 PM   #4
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I believe the hub swap is unnecessary because unless you're pushing something ridiculous in the power department, you won't brake the hub. The axles, diff, or trans will go first. And if you are in the power department, you already should have that covered. I seriously considered swapping it over, but I came to the conclusion that there's no point.
Not a useful mod, IMO.
slicktop is offline   Reply With Quote
Old 02-05-2014, 04:04 PM   #5
vroom4
Why not do the Mach V and just get the hub bored out? Shouldnt take much $$$
vroom4 is offline   Reply With Quote
Old 02-05-2014, 04:47 PM   #6
xwd
The S2000 has a pretty large center bore at like 70mm, the Mach V is 56.1mm to match Subaru's center bore. That's like half an inch to be machined off, I don't know if there is even that much room since the dual drilling takes up space.
The DPT is really the only option I could come up with since it has a 73mm center bore.
Old 02-05-2014, 05:44 PM   #7
CSG Mike
CSG Mike's Avatar
We explored this option back in summer of 2012. It was one of the first things we did, since we have a LOT of s2k wheels we could have swapped with this car. It's not feasible, even with conversion spacers, unless you're willing to cut your studs and compromise the number of turns. On that note, we have 15mm conversion spacers for sale, that were only used for a test fit.
S2k wheels with a 10-20mm spacer would have been pretty close to ideal on this car.
Old 02-05-2014, 06:01 PM   #8
AyJay
AyJay's Avatar
I'm not sure I follow on the reason you would need to cut your studs? Do they not sit flush w/in the 11mm adapter? Would the same hold true with a 15mm adapter?
I can see a 15 or 20mm adapter working for OEM wheels or some of the +62-ish wheels on the s2000 but I'm not really interested in those super high offsets. A spacer that wide would definitely be outta the question for my Grids.
Old 02-05-2014, 06:02 PM   #9
CSG Mike
CSG Mike's Avatar
The studs will stick out, getting in the way of the wheel you're putting on.
Old 02-05-2014, 07:07 PM   #10
AyJay
AyJay's Avatar
I'm glad I posted this as I was really considering purchasing the adapter. Obviously, that would be no bueno.
So did you guys just end up purchasing 5x100 wheels and not sharing?
Old 02-05-2014, 07:10 PM   #11
CSG Mike
CSG Mike's Avatar
Yup... I think we have like 4 or 5 sets of wheels... would have been a lot nicer to share with the s2ks.
AyJay (02-05-2014)
Old 02-06-2014, 11:19 AM   #12
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Rota grids are like $700. Get another set.
Old 02-06-2014, 12:24 PM   #13
AyJay
AyJay's Avatar
I'm pretty much on the verge of doing that. The only thing I don't like is that I wanted to only have to keep 1 set of track tires for both cars. Or maybe have a set of 200tw Street tires and a set of R-comps I could rotate between each.
Old 02-06-2014, 01:25 PM   #14
BlaineWasHere
Grip>Drift
Drives: FRS
If you do enough events you'll use up the tires and be buying more soon anyway.
If you're gonna get cheap rotas for the FR-S get the Titan. Comes in the same 17x9 et42 as the grids but is 3lbs lighter each.
Widest Track tires for stock wheels?? track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 56 10-11-2015 11:01 AM
WORK Meister S1 17x9 +18/ 18x10 +5 5x114.3 Adam498 Wheels and Tires 1 10-23-2013 09:00 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped apexsti46 Wheels and Tires 6 09-05-2012 02:54 AM
