#29 | |
Drives: Scion FR-S 2013 Raven
Best shifter setup
How do you do that?
o= FR-S =o Last edited by Mikepage; 02-04-2014 at 12:50 PM. |
#30 |
Mtec springs, motul fluid (not in yet in my case), weighted flossy shorty knob. Couldn't possibly want it any shorter and the feel is fantastic.
#31 |
Boosted
Drives: Not a supra....yet
Act 6puck w/ light flywheel
Kart boy short shifter Mtec shift spring Motul fluid Still havent got used to it |
#32 | |
Dances with Cones
Drives: 2013 Scion FR-S Raven
I run a TWM M1 Abram on the lowest setting for street and a TWM 4" knurled competition knob for track. The extra leverage from the competition knob makes shifting a breeze and saves me from looking for the shifter when going for the next gear. It's a grab, throw, and go setup. A shorter shift will not make me a faster driver.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD |
| The Following User Says Thank You to that_guy For This Useful Post: | Mikepage (02-04-2014) |
#33 |
Best shifter setup
Exactly that am trying to say ![]() How did you pay for the energy suspension bushing, am looking for this...
o= FR-S =o |
#34 |
Dances with Cones
I bought it from Performance Improvements in Ontario (because I work at one of the stores). It's pretty cheap. They also make the steering rack bushings which I purchased. Not sure I'm going to install them yet, but again, they were cheap, so why not.
#35 |
Drives: 2013 Asphalt FR-S
You just loosen the lockout plate and adjust it like you would if you were installing a short throw shifter. Check out post #6 in @F1point4 how-to for the kartboy
It may or may not help, for me it made more difference than swapping to motul 300 (which made the 2nd gear cruch worse unless the fluid is fully up to temp).
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | Mikepage (02-05-2014) |
#36 |
Don't care
Drives: 2013 Whiteout FRS
My kartboy rattles at high rpm, it's coming off this weekend. Other mods are kartboy rear stay, kartboy positive shift tranmission bushing, and mtec springs. The rattle was there before I installed either bush, was hoping the bushings would help but had no luck. Tom told me I most likely didnt grease it well enough so I tore everything down, regreased and still have the rattle/buzz so im done with it. Since I installed all parts seperately I'd say leave the stock shifter and change out everything else for best feel and least noise/rattles
#37 | |
Do you think this adjustment can fix the 2nd gear grind with the stock shifter? Am not sure because in my case it's only happen on cold temp when the oil is cold... It's also a little bit better since I replaced the trany oil by the Redline oil.
o= FR-S =o |
#38 |
Drives: 2014 BRZ Limited-SWP
Is the kartboy reverse lock out plastic or metal? Its hard to see in the pics, if its plastic can it be removed for an after market piece?
#39 | |
I found the knock off ebay short shifter (same type of design as the billet pro rattled like hell from 4k and up, it was much worse with my mtec drift shift knob than with the stock knob. My kartboy barely rattles with the mtec drift and only slightly noticeably with the stock knob. Weighted knobs seem to reduce rattle, i guess because they act like a mass damper.
~Namaste~ |
#40 |
Mine was the same, as soon as i adjusted the lockout more to the left it got better, much better. If your lockout plate is preventing you from lining up the gate just right it will make it notchy.
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | Mikepage (02-08-2014) |
#41 |
Drives: WRB ZC6
The shifter in my brz is pretty meh compared to the my s2000 shifter feel and they both have the same gearbox. The s2000 is my pinnacle of shifter feel for me. I only had that car for one year and had 100k miles on the original box too. If I can achieve the same feel I wpuld be happy
#42 | |
Drives: frs
I wouldn't purchase the BPS again. Not because the rattle bothers me (I barely hear it with the exhaust) but because BPS has given me the run around and promising fixes for a year. At the same time they continue to sell a defective product. |
| Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? | soulstice | Cosmetic Modification (Interior/Exterior/Lighting) | 52 | 01-24-2016 08:20 PM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 01:41 AM |
| Anyone have this setup? | Gt86_nick | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 03-04-2014 05:32 PM |
| Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing | swansons | Issues | Warranty | Recalls / TSB | 4 | 02-02-2014 02:27 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
