Old 02-04-2014, 04:08 PM   #85
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by Calum View Post
That can be manipulated.
Unless ECUtek has special tables for it, it cannot on start and during the warmup process. I have heard of DI being turned off more than once, but never turning off PI.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Calum (02-04-2014)
Old 02-04-2014, 04:17 PM   #86
jamesm
once warm, the car idles on 100% di all the time. it idles on 100% port during warmup.
The Following User Says Thank You to jamesm For This Useful Post:
charged86 (02-15-2014)
Old 02-04-2014, 04:20 PM   #87
FullBlown
FullBlown's Avatar
Drives: Scion FRS
I was under the same assumption. I am not sure if you can turn the DI off during cranking and post start on the stock ECU. Although I have never tried to do it myself so I can't verify.
I do know that it uses PI while cranking and then remains on PI for roughly 60 seconds then switches to DI.
FullBlown is offline   Reply With Quote
Old 02-04-2014, 04:25 PM   #88
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
My guess would be that the starter kicking the motor doesn't spin the mechanical DI pump enough to generate the PSI at the rail needed for the DI so it has to start on PI. I would think that the time it had to stay on PI prior to changing to DI could be manipulated in the coding.
Old 02-04-2014, 04:30 PM   #89
Luckrider
Luckrider's Avatar
Something like this would need to be confirmed with @EcuTek and that would require new tunes for anyone who gets this. It would also eliminate other tuning options which might not be the best business decision considering @FullBlown's goal was for this to be suited to NA and FI applications.
Old 02-04-2014, 04:37 PM   #90
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Exactly, it would also drive the cost up since it would require custom fuel rails and hardware.
The Following 3 Users Say Thank You to FullBlown For This Useful Post:
crook (02-04-2014), Joveen (03-19-2019), Luckrider (02-04-2014)
Old 02-04-2014, 04:45 PM   #91
Luckrider
Luckrider's Avatar
This right here is exactly why I want an FBM kit when I am finally ready (if ever) to go fully fledged FI. Nothing but fantastic customer service with a focus on their customers every step of the way.
The Following 3 Users Say Thank You to Luckrider For This Useful Post:
DustinS (10-27-2014), FullBlown (02-04-2014), Nomed Alucard (02-13-2014)
Old 02-04-2014, 05:09 PM   #92
jamesm
i wonder if a custom map outputting ratio vs. load and rpm just like the stock one might override the settings in the other modes too?
Old 02-04-2014, 05:11 PM   #93
FullBlown
FullBlown's Avatar
Drives: Scion FRS
I wouldn't be surprised if you could. With Ecutek's custom maps you can manipulate almost anything.
Old 02-04-2014, 05:19 PM   #94
Luckrider
Luckrider's Avatar
It really makes you wonder just how much is left on the table with the factory programming, and how much truncation this is with certain custom maps.
But, that isn't what this thread is about. What do you think (based on what an intake change like this seen on any other motor) would do for power? Do you think it will boost higher RPM torque, boost low end torque, increase the usable rev range (make power above 7k rpm)?
Old 02-04-2014, 05:30 PM   #95
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We obviously would be happy with gains all across the board. We have found that if you get too aggressive on the plenum, you lose the low end but increase power up top.
Ideally, we would like to see gains more in the mid range and the power carrying out past 7k but there's only one way to find out..
Brody602 (03-07-2014), Dipstik-sportech (02-04-2014), Luckrider (02-04-2014)
Old 02-04-2014, 05:35 PM   #96
Luckrider
Luckrider's Avatar
I'm not going to lie, 250WHP on e85 is the magical number for me. I think it is possible on this platform by year's end.
Edit: That is NA of course.
Old 02-13-2014, 09:06 AM   #97
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
The Following User Says Thank You to whitefrs For This Useful Post:
Old 02-15-2014, 09:43 AM   #98
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
any ideas how much additional HP?tq one could expect to see with piece if it was tuned?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold cover protpibe Engine, Exhaust, Transmission 16 02-28-2014 06:44 PM
Wanted intake manifold ciro Want-To-Buy Requests 0 09-27-2013 12:03 PM
Aluminium intake manifold? Hempo Engine, Exhaust, Transmission 18 06-27-2013 01:19 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
