Old 02-04-2014, 04:29 PM   #71
wu_dot_com
Drives: accord
Originally Posted by Tt3Sheppard View Post
Is this related to being able to rotate the driveshaft while in neutral about 20-30 degrees with the parking brake on? I also pushed the car with the E-Brake up and while in neutral and I can hear the clicking sound coming right from the left rear axle area.
hum i just drop off my car at the dealership for the same click issue. its also on the driver rear axel area. i thought it was a crack wheel bearing, but it seems like it could be a crack CV. the noise is intermittent, and its usually occurs when rolling from a stop in either forward or reverse.
wu_dot_com is offline   Reply With Quote
The Following User Says Thank You to wu_dot_com For This Useful Post:
DAEMANO (05-23-2014)
Old 02-04-2014, 04:36 PM   #72
wu_dot_com
Drives: accord
here is a question for those who supports the lowering is the cause for this CV breaking problem.
if lowering the car is the cause, why is it that only the driver side rear CV broke and not the right?
also, what are the relative timeline of each members car mfg year? mine was initial delivery on may 21 2012. so im guessing its the very first / second batch.
Old 02-04-2014, 04:38 PM   #73
wu_dot_com
Drives: accord
too bad we dont have a close up of the fracture point. otherwise we can determine if this is a fatigue, brittle, or overload failure.
Old 02-04-2014, 06:41 PM   #74
wu_dot_com
Drives: accord
the dealership just called saying my clicking sound was a result of a deficient axial nut torque value.
The exact location of said axial nut location is not specified to me. I will ask when I pick up the car.
Could this be a root cause leading up to the eventual cracking?
Old 02-04-2014, 07:18 PM   #75
Boxer486
Drives: small
Not sure if this is an answer at all, but I know the left side is quite a bit heavier than the right when cross weighting, then add the weight of the driver on the same side too. Be interesting to see if they have the same issue on the same side for RHD models.
Boxer486 is offline   Reply With Quote
Old 02-05-2014, 07:23 PM   #76
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
so it has all broken just on the driver side and not the passenger side?
I'm interested in the Diff brace, will this be better than getting the DSS +600hp rear axles, not just considering cost?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 02-07-2014, 09:11 PM   #77
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Most was the driver side, I've broke the passenger side too (Only one?) (Not F/I :I )
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 02-07-2014, 10:02 PM   #78
yuicebox
Drives: Asphalt FRS
Is this happening even when people have aftermarket rear control arms?
yuicebox is offline   Reply With Quote
Old 02-13-2014, 12:01 AM   #79
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
So I fixed my axle yesterday. Kept my ride height and found no more mechanical ticking noises from the drivers side rear axle. Hit bumps, potholes, and even a large lump of rock on the road and not a peep from the axle. Maybe I had a defective axle, considering the fact that most other lowered fr-s on the island have been running way lower than I was and from the beginning of their ownership (I lowered my car at 15,xxx miles)?
Basically when removing, I decided to rip open the CV boot.
Image 2 is a closeup of the EDJ cage that broke into 4 pieces.
Its hard to see in image 3, but basically there are gouges where the ball bearings slipped out of the cage.
Image 4 highlights a tri-opening fracture.
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
The Following User Says Thank You to markmatley For This Useful Post:
Old 02-13-2014, 12:02 AM   #80
markmatley
markmatley's Avatar
I have PSM LCA's and my drivers side axle broke at the cv boot.
~Matt
Old 03-04-2014, 05:39 PM   #81
choi0706
Drives: t
any one else have failures?
choi0706 is offline   Reply With Quote
Old 03-05-2014, 01:43 PM   #82
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
I might be wrong, but there is still no real clarification as to what the root cause is for the axles to break, is there (i.e. lowering the car, too much power, too much grip, etc.).
Eurasianman is offline   Reply With Quote
Old 03-05-2014, 04:01 PM   #83
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
All of what you said minus too much power and add aggressive launching.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
TTGT (05-24-2014)
Old 03-05-2014, 04:49 PM   #84
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Bob from drift office posted pictures from another slammed 86 that snapped an axle or two on facebook. He said it's pretty much certain that the geometry of a suspension that's lowered way too far causing the failures. He could offer a whole lot more specifics than I could though.
DoomsdayJesus is offline   Reply With Quote
more money than brains, stance bro
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
