Old 02-04-2014, 12:47 AM   #169
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
@JDLUniversalDesignStudio
More questions for you :/
1/ I have read else where of an option for coating that involves both outside and inside of the pipe. Supposedly keeps the heat in better. What is your opinion on this?
2/ The flexi-joints bug me. They look like exhaust goiter. Do they introduce any impediment to flow? How concerned would you be at producing these pipes without flexi-joints?
Thanks.
Old 02-04-2014, 12:58 AM   #170
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
2/ The flexi-joints bug me. Do they introduce any impediment to flow? How concerned would you be at producing these pipes without flexi-joints?
Thanks.
If you can afford the coating I would do it. Keeping the heat in helps keep up the velocity of the exhaust pules and will also keep the bay temps down. As for the flex sections on the header, have you seen how much it actually moves? Ive seen them move a significant amount with the car in neutral so I can only imagine how much more it would move with load on the engine.
Here is a break down of how they are laid out. They are the smoothest as possible while still allowing movement. For a street car I dont really recommend running without them. If it was a dedicated race car that gets refreshed after a few hard track days than that may be a different story
JDLAutoDesign is offline   Reply With Quote
The Following 4 Users Say Thank You to JDLAutoDesign For This Useful Post:
Captain Snooze (02-04-2014), Darryljr11 (02-04-2014), FR-S Matt (02-04-2014), SirBrass (02-04-2014)
Old 02-04-2014, 01:36 AM   #171
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Are there benefits to thermal coating besides looks that make it significantly better than thermal wrap?
^GT5 Replay Photo Mode^
Old 02-04-2014, 04:11 AM   #172
Captain Snooze
Drives: Red Herring
@JDLAutoDesign
Sorry, my question was meant to have asked does your coating do the inside as well as the outside?
Old 02-04-2014, 04:29 AM   #173
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
Originally Posted by JDLAutoDesign View Post
We have a local car (SC'd but we are also looking for a local NA car) dyno the EL Catless and Cat section for numbers. I should be able to have those by the end of the weeek
Do you stock the 3" over pipe / front pipe or is it made to order?
Thanks!
h4nh is offline   Reply With Quote
Old 02-04-2014, 01:50 PM   #174
JDLAutoDesign
Drives: 13 FRS
Thanks!
Made to order currently. Also dont done the 3" front pipe up on the site yet but will soon
Old 02-04-2014, 01:51 PM   #175
FR-S Matt
Have you guys experimented with Helmholtz (drone killers) yet? I've heard good things about them in different areas from front pipes to actual catbacks.
Old 02-04-2014, 01:56 PM   #176
JDLAutoDesign
Drives: 13 FRS
That would be something put in a catback if we offer them
The Following User Says Thank You to JDLAutoDesign For This Useful Post:
Old 02-04-2014, 02:07 PM   #177
Boxer486
Drives: small
I believe thermal wraps can cause corrosion and also add more weight than coatings. Thermal performance could be worse as well depending. I think the only reason to select a wrap over coating would be to try to save money.
Boxer486 is offline   Reply With Quote
The Following User Says Thank You to Boxer486 For This Useful Post:
JDLAutoDesign (02-04-2014)
Old 02-04-2014, 02:23 PM   #178
JDLAutoDesign
Drives: 13 FRS
We dont warranty wrapped products. If wrapped too tight it will not allow for the metal to expand and contract properly and will cause cracking. Coating will keep the heat in and help with keeping the velocity of the exhaust up and better scavenging. The coating is the standard coating and it does well for its intended purpose.
Old 02-04-2014, 03:47 PM   #179
tennisfreak
Drives: 2018 BMW M240i
@JDLAutoDesign
Will a coating help any with noise?
Old 02-04-2014, 05:02 PM   #180
FR-S Matt
Originally Posted by tennisfreak View Post
@JDLAutoDesign
Mine is coated and still makes noise. It's just the nature of the header having thinner walls and no heat shields. If it does reduce the sound, its very minimal. Mine only makes a lot of noise during cold start up front in the engine. Once it warms up, sounds beautiful.
The Following User Says Thank You to FR-S Matt For This Useful Post:
tennisfreak (02-04-2014)
Old 02-04-2014, 08:45 PM   #181
JDLAutoDesign
Drives: 13 FRS
Coating is for heat only sorry
Old 02-04-2014, 11:54 PM   #182
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
So dumb question.....
Looks like the headers are in two peices....is that for installation ease? This will bolt up to a stock location front pipe?
GR86 MT premium
StormTrooper is offline   Reply With Quote
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 11:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 01:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 08:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 09:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 10:05 PM
