Old 01-31-2014, 07:09 PM   #1
Pacific Auto
Master Installer
Pacific Auto's Avatar
Drives: Scion FRS
Hawk HP+ Problems?
I have recently purchase a set of Hawk HP+ brake pads. Upon opening/ installing I realized three problems:
#1 The pins for the springs have been grinded.
#2 One of the springs was unpressed in the box.
#3 Only two of the pads had pins/springs while all four of the OEM's did.
Is this normal?
Pacific Auto is offline   Reply With Quote
Old 01-31-2014, 07:12 PM   #2
CSG Mike
CSG Mike's Avatar
Yes, you only need indicators on the inside...
However, that one that fell off... it shouldn't fall off that easily.
If you regularly inspect your pads, you won't need the indicators anyways.
Old 01-31-2014, 07:22 PM   #3
Pacific Auto
Master Installer
Drives: Scion FRS
Ok, since I am probably going to return these. Should I get another set of the same or is there a better pad in the same price range? Car is DD and time attacked almost once a week.
Old 02-03-2014, 04:54 PM   #4
funbeatsfast
funbeatsfast's Avatar
Drives: '13 FR-S
Hawk HP+ pads work fine for me. They stop well when cold, don't seem to fade too much at track days. Not too noisy as long as you bed them in right.
I take the clips off b/c they're easier to get in the caliper that way. Personally, I wouldn't bother sending them back. As long as the pad material and backing plate are fine....
funbeatsfast is offline   Reply With Quote
Old 02-03-2014, 05:19 PM   #5
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I have these. In the cold and wet they are terrible. In the cold? Just fine. Wet? Just fine. Combine the two and it's like banging rocks together to stop.
post_break is offline   Reply With Quote
Old 02-04-2014, 12:39 AM   #6
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
not on the hp+, but hps pads, my indicators where on the wrong side of the pads. just removed them and havent had any issues. although im starting to think the hps are not well suited for the track.
garfull is offline   Reply With Quote
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
FS Hawk HPS Brakes Front and Back qbcsvt Brakes, Suspension, Chassis 4 02-16-2014 09:08 AM
Hawk HP Plus Fronts Sheldon Brakes, Suspension, Chassis 2 04-05-2013 09:32 AM
Hawk HPS Front Pads Sheldon Brakes, Suspension, Chassis 1 01-04-2013 03:54 PM
Tony Hawk Jumps Over LFA M-17 Other Vehicles & General Automotive Discussions 5 05-16-2012 02:35 PM
