Old 02-03-2014, 02:52 PM   #197
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
30-45 degrees... I think they could have tried a little harder than that for the temperature range.
Found on another site:
"I'm looking at the Chemical Compatability Chart of my Lab Safety Supply catalog. Compatibility is sometimes affected by temperature. For RIGID PVC and gasoline, it states:
At temp 20C (68F): Good (scale of Xlnt/Gd/Fair/Not Recommended)
At temp 50C (122F): NR"
Source: http://www.bobistheoilguy.com/forums...&Number=547427
I applaud the DIY stuff. Especially when someone can easily afford the catch can as the Camaro owner who spent at least $7k on that Whipple. His approach to the solution has sparked more thinking in the community which is great.
Radium products are really nice though. If you want something you can purchase that is well engineered and setup to work right out of the box. It's also good to have those options available.
PhastekSport is offline   Reply With Quote
Old 02-03-2014, 03:01 PM   #198
OrbitalEllipses
Drives: Attitude
Originally Posted by Vracer111 View Post
In hand gun terms, Radium products would be comparable to an HK, you pay a premium for a premium piece.
Did not want an HK until I shot one. So expensive.
Old 02-03-2014, 03:22 PM   #199
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
The HK416 i received a couple of years ago is one of the finest engineered firearm I have ever laid my hands on.
But I still miss the good old HK G3 we used in service over here before.
Well, enough off topic.
Can anyone verify if the new radium setup works together with hood struts?
It sure looks like its going to be a tight fit combined...
I have a grimmspeed kit installed in my brz.
Andreas83 is offline   Reply With Quote
Old 02-03-2014, 09:36 PM   #200
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
I wont have mine until next weekend and I'll likely have to get longer bolts before I can consider installing it.
I also have the hood struts.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 02-04-2014, 09:27 AM   #201
utekineir
blowhard
Drives: frs, project forester
Originally Posted by Dezoris View Post
If you are worried about cost clearly these are not the cans for you.
Theres a difference between broke and cheap.
I've bought a handful of expensive catch can solutions in the past on other cars, and always was left wondering why the hell I had just paid $2-300 for a tin can with some condensing media and a bracket.
Nowhere have i shit on the radium product. I just have an issue justifying roughly $450 after shipping on some hose, 2 brackets and 2 cans. They have every right to make a profit and price their product where they want. I have every right to giggle and try fill my engine with fumes from dissolving pvc.
Anyway if i wasn't making myself scarce and keeping busy with stupid projects I'd probably be expected to help clean the house. Just wait till i put up pics of the diy corner balance rig with 16 $8 walmart scales I made this weekend.
Awesome, thanks for info. Pretty sure theres a wireless thermometer around here somewhere, that should be able to help with finding proper locations.
utekineir is offline   Reply With Quote
Old 02-05-2014, 08:17 AM   #202
Stevo22
Stevo22's Avatar
Drives: GR86
So I just got done installing this kit right here. Every part of the kit has amazing quality. The only complaint I have and it can be seen in this stock picture is it is going to be hard to unscrew the catch can part to empty the can with this positioning. I have small hands it is a tight fit even after unscrewing the lines. That is really the only major issue I found. There are a few other minor issues but nothing worth noting.
Stevo22 is offline   Reply With Quote
The Following User Says Thank You to Stevo22 For This Useful Post:
normancw (02-05-2014)
Old 02-05-2014, 08:21 AM   #203
that_guy
Dances with Cones
that_guy's Avatar
Glad you brought this up. Looking at the wire harness below the can before ordering, I decided to pick up the petcock drain kit to help with clearing it out. I hope there is room for it though...
The Following User Says Thank You to that_guy For This Useful Post:
Old 02-05-2014, 09:19 AM   #204
Stevo22
Stevo22's Avatar
Drives: GR86
There should be room for it. The wiring harness sits below and kind of between the fender and the catch can. I will try to get some pictures of my setup a lunch and upload them. Also not from the picture the orientation of the top barb (which is easily rotated out of the way) is right above the oil dipstick. It is not a big deal, but worth stating.
Old 02-05-2014, 10:19 PM   #205
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Your not going to need to dump it out very often....took me 6 months to get ~ 1/4" fluid level in the can. That would mean several years before really needing to dump it...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
Old 02-05-2014, 11:15 PM   #206
utekineir
blowhard
Terrible advice
How many miles do you drive, do you drive hard? Texas I'm guessing also doesn't have the increase in collected water that catch cans see in cold climates.
What works for you and your driving doesn't necessarily work for anyone else.
Usually a pretty good way to go is to drain/check the can during oil changes. Or at least till you have an idea of how fast a can is filling. A good can design shouldn't take more than a minute or two to drain, no reason what so ever to let sit a "couple years"
Letting it fill also may mean the risk of drawing fluid back through I.e. During spirited driving, let alone the reduction in fan volume and it's potential reduction on effectiveness, or the increased freezing risk during winter
The Following User Says Thank You to utekineir For This Useful Post:
Vracer111 (02-10-2014)
Old 02-10-2014, 03:18 AM   #207
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
I installed my kit a few nights ago. Quality, no problems installing at all. Sure draining won't be easy but it's 3 easy bolts to undo, pop it out and unscrew. Ill just put it in with my oil changes. Took about 15 min including cutting and installing the hoses.
FRSfan111 is offline   Reply With Quote
Old 02-10-2014, 03:19 AM   #208
FRSfan111
Ill take pics in the day. Like my oil cooler and my grimmspeed brake brace, the catch can in black is very low key and Oem looking. Popping the hood on my car looks stock accept for the trained eye.
Old 02-10-2014, 08:31 PM   #209
Vracer111
Vracer111's Avatar
Originally Posted by utekineir View Post
Terrible advice
I see where you are coming from and didn't think through the proper level you should let it get to. My comment was merely on the level reaching a certain point in the can and how long it would take to get there... I don't think I'd actually go 2+ years since I check it once a week and it's easy to get to and dump anyways. Every oil change is indeed a good time.
Old 03-31-2014, 11:06 PM   #210
Dezoris
Dezoris's Avatar
Here is the updated video showing new cans:
Radium Master Cylinder Install and Catch Can Demo
VIDEO
[ame="https://www.youtube.com/watch?v=v6svcEF_GQE&"]Radium Brace and Catch Can Install | FR-S and S2000 | S02E01 - YouTube[/ame]
The Catch Cans
Radium has now released their official plug and play kit for the S2000 and FR-S and BRZ which means you can finally install these kits without having to make your own brackets. Quality is top notch and cans are pressure tested for forced induction applications and also baffled.
It is the only can with built in dip stick to check oil and fluid level.
After running these cans on three cars for several years, they have maintained their seals and also been able to suspend oil and unburned fuel without ever servicing the stainless steel screens or pads.
2013 FR-S Product Technical Info and Specs (from Las Vegas press event) ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 53 07-19-2021 05:59 PM
Fifth Gear reviews the GT86 (Full Video) lazyluka Scion FR-S / Toyota 86 GT86 General Forum 20 10-10-2012 06:09 AM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
Full Specs and Info on GREDDY SCION FR-S vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 109 01-02-2012 11:11 PM
