Old 03-06-2012, 05:19 AM   #15
Kunzite
Drives: Toyota Auris
Understeer and oversteer explained:
[u2b]zoICf55jED8[/u2b]
Kunzite is offline   Reply With Quote
Old 03-06-2012, 05:28 AM   #16
Dark
Elite Padawan
Dark's Avatar
^^ awesome explanation. hahaha
Originally Posted by ashtray View Post
That was a simple explanation. There's cases where a fwd car car oversteer, and a RWD can understeer. Know how the car is behaving while turning and losing traction and which wheels are being driven will help you react to maintain control. But in pretty much all cases, you point the wheels in the direction you want the car to go.
The BRZ might understeer a bit in dry conditions under hard cornering. depends on the suspension setup.
I think some reviews said BRZ is not tail happy as FR-S, but it still oversteers. I don't think a bit tweak on damper and spring rates for stability in BRZ will make it go understeer like FWD cars. It maybe just more grippy less tail happy at the corner.
Dark
Dark is offline   Reply With Quote
Old 03-06-2012, 08:20 AM   #17
Lighting Red
Habitual Line Crosser.
Lighting Red's Avatar
Drives: ^ Two of my favorite things.
I think that it is both a little sad, yet overall funny that for many folks (myself included, I am 31 BTW) the BRZ/FR-S will be their first RWD car. Not including my motorcycles, I have grown up on a diet of FWD and AWD cars, and I suspect that several people here are in the same boat.
To the OP, while I am a NoVA resident as well, the bad weather does not concern me. Remember the two cardinal rules of operating... Well just about any vehicle... 1) The vehicles go where your eyes go. 2) This build off rule one: do not target fixate. If you go off your intended course, rip your eyes away from what you may hit, and direct them where you want to go. Your body will do what it takes to feed inputs into the vehicle in order for the entire system (you+vehicle) to go where you want.
Of course, practice can't hurt. I recommend going to an empty parking lot - bonus points if it's a rainy day - and progressively (read: safely) search for the limit of what the car can do. It is also a great way to find out you are comfortable with, which is highly important! I do that with all my new car/motorcycles purchases, and I think it is important to know how my vehicle acts in such a situation. Bear in mind that is not the way to be normally driving - like that needs to be said.
I am personally looking forward to straightening the car out with the throttle on corner exit every once in a while
Lighting Red is offline   Reply With Quote
Old 03-06-2012, 08:43 AM   #18
Brett
First 86
Brett's Avatar
Drives: Whiteout MT FR-S
get a second set of rims with snow tires and you'll be fine.
Ditto. Blizzaks or similar, and it'll drive like a tank.
Don't shop, adopt!
Brett is offline   Reply With Quote
Old 03-06-2012, 08:48 AM   #19
Pakjk89
Drives: 2010 VW GTI
Yeah, I hear you. I have been scratching and clawing to get a rwd car, let alone a manual one. I sadly have a GTI and (regretfully) got an automatic. I guess it was because I never learned how to drive a manual (please don't roast me guys). This will hopefully be my first rwd and manual car that teaches me the true meaning of proper driving.
Pakjk89 is offline   Reply With Quote
Old 03-06-2012, 10:05 AM   #20
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
RWD is fine in the snow, if it's not then there won't be many BMWs left on the road.
Hanzo is offline   Reply With Quote
Old 03-06-2012, 10:31 AM   #21
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by Pakjk89 View Post
Excuse me for being a complete car noob but I have always wondered what understeer and oversteer meant and this is exactly the best explanation ever. I read that the BRZ tends to understeer though. What does that mean relative to bad weather/slippery conditions?
Here's a great quote (I can't find the origin though):
With understeer you hit the wall with the front of the car. With oversteer you hit the wall with the back of the car. Horsepower is how fast you'll hit the wall, and torque is how far you take the wall with you.
In the real world, even RWD cars will understeer if you go too fast into a corner. At that point it's more about the front tire's grip and braking. But where the difference occurs is when you step on the gas. A FWD car will lose traction in the front so more understeer. A RWD car will lose traction in the rear so the understeer will turn into oversteer. It's this switch from under- to oversteer that freaks people out and makes them think RWD cars are unpredictable and dangerous.
In fact, RWD cars are MORE controllable than FWD cars. But they take some skill to do that, and driving skill is an oxymoron for the majority of US drivers.
Rule #1 of circuit racing works well in the real world too. Especially when conditions get bad.
"Always do ONE thing at a time." You can Turn, Brake, or Accelerate. But only do one at a time. Your tires only have so much grip, and you have to spend it like money to buy what you want to do. If you try to do two things (turning while accelerating) you'll have to spread your money out and have less for either.
So if conditions are bad, brake for a turn before you get to it, then get off the brake and start to turn the wheel as you enter the turn. Then when you unwind the wheel straight at the exit of the turn, you can step on the gas to accelerate again. Brake, THEN turn, THEN accelerate.
The BEST thing you can do to learn your car is find an *empty* parking lot covered in snow and go do donuts and drifts. When you become familiar with how the car will move when it breaks traction, you'll be less likely to panic if it happens unexpectedly. And if you're holding and switching up drifts, you'll become familiar with how to get out of and control slides.
Enjoy your RWD daily driver.
Old 03-06-2012, 10:33 AM   #22
GMU-BRZ
Drives: 2013 Subaru Impreza Sport
FWIW, I’m in basically the same situation as you. Planning on getting this car as my daily driver, and I doubt I ever take it to the track.
GMU-BRZ is offline   Reply With Quote
Old 03-06-2012, 11:08 AM   #23
Jayde
Jayde's Avatar
I'm also planning on using this car as a daily driver too, unless I can find somewhere to store my Integra for a winter car.
Jayde is offline   Reply With Quote
Old 03-06-2012, 11:10 AM   #24
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Originally Posted by Corey View Post
If you drive like a normal person you will most likely never even notice the difference between FWD and RWD. People like to exagerate the dangers a lot but realistically most people who crash, especially in poor weather, would have crashed regardless of the drivetrain. It will be a fine daily driver.
Well put! Driving skills + winter tires = wintertime competence, regardless of drivetrain.
I'm planning on DD'ing the BRZ. I'm planning on putting winter tires on the stock wheels, and then getting another set of rolling stock for summer. This won't be my first rear-drive car; I've had rear-drive DD's sporadically for most of my driving career.
For those that this will be their 1st rear-drive car, I suggest some HPDE's, auto-x, or lonely parking-lot time to acclimate to the new driving style and learn the car near, at, and beyond the limits of adhesion. Practice makes perfect.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 03-06-2012, 11:53 AM   #25
stateless
Double Dragon
stateless's Avatar
Drives: 2013 6MT BRZ Limited
If you are interested in understanding the dynamics and proper driving techniques better, this is a decent site: http://www.drivingfast.net/
stateless is offline   Reply With Quote
Old 03-06-2012, 11:55 AM   #26
maxeveland
maxeveland's Avatar
Drives: n/a
lol that is a hilarious explanation
maxeveland is offline   Reply With Quote
Old 03-06-2012, 02:22 PM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'll DD mine. No snow concerns though since I live in hell. :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-06-2012, 02:29 PM   #28
BillY2KFRC
Drives: 2003 Corvette Z06, ECS Dry Sump 427
Yup, daily driver here in CT for me, I love RWD in the snow. Think it'll be awesome with the great F/R weight distribution and some proper snow tires. Don't let people get you all worked up over the RWD thing, those are the same people that drive their SUVs into a ditch when it snows.
2003 Corvette Z06 - Dry Sump LS7 built by East Coast Supercharging
560rwhp & 549rwtq 10.8@134
2013 Subaru BRZ Limited - WRB, 6MT, PTuning Header, Motriv OP & FP, Perrin Res. Catback, Toms Tail Lights, Sprint Springs, Rays 57DR Wheels, 186rwhp
BillY2KFRC is offline   Reply With Quote
brz, daily driver, snow
FT-86 -- daily driver, weekend car, or garage queen? My86 Scion FR-S / Toyota 86 GT86 General Forum 90 05-28-2012 01:28 AM
Good sporty daily driver? Staticz Scion FR-S / Toyota 86 GT86 General Forum 79 03-01-2012 05:20 PM
Comfort and daily driving - Should I go with a sports coupe? Undecided Off-Topic Lounge [WARNING: NO POLITICS] 22 03-01-2012 03:17 AM
The daily driver KiingDavid CANADA 25 02-06-2012 02:14 PM
