Old 02-02-2014, 04:48 PM   #15
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Here's something I'm working on.
1" x .049 4130 tube with .120" end plates. Abound 5lbs. pulsed TIG welded. Doesn't get much more solid than that and it clears all the factory components. Can be mounted over or threaded under the upper AC line.
Still not complete yet. Will add a couple of ounces with some 'accessories' once complete. The functionality of the 'accessories' will be worth the extra weight, I will guarantee that. Let me know what you guys think.
Old 02-02-2014, 04:58 PM   #16
solidONE
solidONE's Avatar
Originally Posted by h4nh View Post
I can make this for you if you want. With thin walled 4130 tubing, of course.
Old 02-02-2014, 07:24 PM   #17
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
I'll take it if u can make it out of home depot pvc.
h4nh is offline   Reply With Quote
Old 02-02-2014, 09:17 PM   #18
solidONE
solidONE's Avatar
Doable... if you don't mind the use of epoxy and self tapping screws.
Old 02-02-2014, 09:20 PM   #19
h4nh
h4nh's Avatar
No worries.. I did have my roof epoxied on and it holds up well. Maybe we can set up a group buy for this!
The Following User Says Thank You to h4nh For This Useful Post:
solidONE (02-02-2014)
Old 02-02-2014, 09:26 PM   #20
solidONE
solidONE's Avatar
been waiting to use this'en. lol
Old 02-02-2014, 09:45 PM   #21
Squishy86
Squishy86's Avatar
Drives: Your Car
Please move this thread to the Best of FT86Club section.
Squishy86 is offline   Reply With Quote
Old 02-02-2014, 09:53 PM   #22
kuhlka
Drives: 2013 BRZ Limited AT
It seems like you should be making use of that third bolt like a full strut tower brace if you're going to cross the middle like that. Mild steel or cromoly?
kuhlka is offline   Reply With Quote
Old 02-02-2014, 10:08 PM   #23
solidONE
solidONE's Avatar
The reason I did not tie in the strut mounting bolts was because it would have minimal increase in stiffness over the current design but it would increase the weight and complexity of the assembly by a good amount. The mounting plates are .120" thick. Probably a bit thicker than required. I could tie in more points and even use stronger/thicker material, but the benefits over the current design is minimal if any and it would add too much weight and defeat the purpose of using this stronger material.
4130 = Chromoly
Old 02-03-2014, 08:34 AM   #24
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
arn't there cad programs where you could simulate whatever design for stress points and materials use
no offence, OP, but if you're gonna use MS paint to "design" a component meant to be ridgid and light, you're not gonna get very far in terms of efficiency.
plus, as was stated, plenty of people have made really nice and well thought out pieces already.
Old 02-03-2014, 08:55 AM   #25
mrk1
Drives: Sterling BRZ Ltd
Nothing wrong with MS paint
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
NYCsubaruBRZ (02-04-2014)
Old 02-03-2014, 09:06 AM   #26
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
for making DOGE memes and proving to the world how much free time you have:
[ame="http://www.youtube.com/watch?v=vUWqRhReaZk"]MS Paint Car - Pixelgod II - YouTube[/ame]
The Following User Says Thank You to 7thgear For This Useful Post:
wparsons (02-03-2014)
Old 02-04-2014, 01:04 AM   #27
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
no offense taken.... wasnt using it to design... was using it to show ideas of a design. im not building this... someone else is building it for me. im just gonna have it made a bit thicker and solid.
NYCsubaruBRZ is offline   Reply With Quote
Old 02-04-2014, 03:37 AM   #28
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
fooddude is offline   Reply With Quote
Aluminium diagonal braces for engine bay strut tower NYCsubaruBRZ NY / NJ / CT / PA 0 01-27-2014 06:41 AM
GrimmSpeed Strut Tower Braces now available at RallySport Direct!! RallySport Direct Brakes, Suspension, Chassis 10 12-27-2013 02:23 PM
WTS Cusco Strut Tower Bar / Adjustable Angle Braces and more ryansb Hawaii 1 10-29-2013 12:45 PM
Local opinion on strut tower braces Areddi Mid-Atlantic 22 12-18-2012 06:12 PM
strut tower braces made out of bamboo?!? aspera Scion FR-S / Toyota 86 GT86 General Forum 26 04-02-2010 01:27 PM
