Old 02-02-2014, 03:42 AM   #15
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
It looks like a coffee table... A bit overkill, no?
The Following User Says Thank You to Turbo95eg6 For This Useful Post:
Redlinedfrs86 (02-03-2014)
Old 02-02-2014, 03:44 AM   #16
KONVERTER
KONVERTER's Avatar
Extra desktop space is always a plus...
KONVERTER is offline   Reply With Quote
Old 02-02-2014, 05:40 AM   #17
KONVERTER
KONVERTER's Avatar
Well I just went out to the car and shoved down on the front of the brackets and I couldn't get the trunk to flex much at all. Addition of a under bracket won't do much except add weight if anything.
The brackets are quite wide on this wing as on others I have seen only have half the width.
Old 02-02-2014, 02:00 PM   #18
raytrix
Drives: Series 10 FR-S
Mounting location is critical. This guy in the picture put a universal Origin wing that didn't really fit the car at the proper mounting locations. As you can see it was not close to the ends of the trunk where that is a the stiffer part of the trunk since it sits on the edge of the chassis there. This guy said that after driving the car one day his entire trunk has ripples on it and it's warped where the wing sits on the trunk surface. If you look closely it's not mounted near the edge of the trunk either, instead it's on a nice open flat surface of the trunk which is a thin sheet metal. Most wing companies that make a specified wing for this car either has the wing mounted at the very side edges or very close to the center of the trunk and wrapped around the edge. For sure keep us updated of any warping issues you see with your center mount setup.
Here's an example of a reinforcement plate you can make or design for trunks. The S2K center mount wings require this so when the wing starts pulling or pushing on the trunk that it'll spread out the load more evenly than if it was straight at the base of the wing mount.
http://www.gotuning.com/product_info...oducts_id=1103
raytrix is offline   Reply With Quote
Old 02-02-2014, 02:09 PM   #19
KONVERTER
KONVERTER's Avatar
Thanks for the info...
One of the reasons I went with this wing was the mounting base, how it wraps around the back of the trunk. It may be a center mount wing, but it is not putting all the weight on flat sheet metal but uses the bend of the trunk which is much stronger... That part doesn't seem to flex to me...
But we will see...
The Following User Says Thank You to KONVERTER For This Useful Post:
raytrix (02-02-2014)
Old 02-02-2014, 02:20 PM   #20
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Originally Posted by raytrix View Post
headlikeahole is offline   Reply With Quote
Old 02-02-2014, 02:51 PM   #21
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You trying to tell me that this guy with his strecthed, hellaflush setup (minus the hideous drop) actually went fast enough to mess his trunk up?
OP, do your thing and don't mind the people hating on your functional setup.
Old 02-02-2014, 02:54 PM   #22
KONVERTER
KONVERTER's Avatar
Many reasons why I didn't go with a universal wing and for something that had specific mounts for this car.
(That wing above looks like it is a bit heavier with metal brackets etc).
Thank you and will do!
Old 02-02-2014, 04:09 PM   #23
raytrix
You did the right thing and went with a legitimate wing that was designed for the car vs universal. I just want to see some feedback from people finally that has the balls to drop money on a nice wing. Any feedback will definitely help others in the future that plan to buy this particular wing.
The Following User Says Thank You to raytrix For This Useful Post:
khan (02-02-2014)
Old 02-02-2014, 06:30 PM   #24
KONVERTER
KONVERTER's Avatar
The kit was alright. I had a bit of a problem with some supplied hardware. The button end bolts for the side fins are listed as M5 and that is what was included, but the inserts were M4 size so I needed to get the smaller bolts. One of the inserts popped out and fell into the wing. We had to fish it out with a magnet and get creative when getting the fin bolted on. Ended up going on well and was able to be torqued down properly.
Besides that no issues at all with the kit.
The instructions are available on the blitz site, they basically just say what comes in the kit in Japanese. Would be nice if there was a template for placement but there isnt.
Functionality I couldn't tell you just yet... but I definitely feel it on the butt dyno! Haha
Old 02-02-2014, 06:51 PM   #25
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Jesus that thing is HUGE. To each their own, and I totally respect others tastes, but that thing looks completely disproportionate in my opinion.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 02-02-2014, 07:04 PM   #26
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
That's what she said?
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 02-02-2014, 07:05 PM   #27
KONVERTER
KONVERTER's Avatar
Thank you I appreciate your opinion!
Old 02-02-2014, 07:48 PM   #28
KONVERTER
KONVERTER's Avatar
Looking at the pictures they do make the wing look HUGE. It is not wider than the car... Will bring the car to the local meet and let one of the photographers take some photos.
Thoughts on Tommy Kaira FRP+Carbon Wing Brody602 Cosmetic Modification (Interior/Exterior/Lighting) 43 01-27-2016 01:12 PM
Gauging Interest: Wing or GT Wing?! awang0528 Exterior Parts (Aero, Lighting, Etc.) 3 05-01-2013 01:12 AM
Carbon Effect Wing Mirrors faz1 Cosmetic Modification (Interior/Exterior/Lighting) 11 08-25-2012 10:12 PM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 07:11 PM
