Old 02-02-2014, 09:35 AM   #29
krulux
Drives: 2013 Scion FRS
Not seeing how the OFH could be considered a copy of the Borla header.
Not even close.
krulux is offline   Reply With Quote
Old 02-02-2014, 10:17 AM   #30
Basket Case
Drives: 2013 Raven fr-s
I forgot about the flex joints. Are they important ?
Basket Case is offline   Reply With Quote
Old 02-02-2014, 10:29 AM   #31
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
I really don't know. I can tell you that the OEM EL headers have them and that JDL UEL headers have them but others such as HKS and Revworks do not. When you ask them why they dont they say its not necessary. I have heard other forum members with experience say that they would be useful in turbo applications or perhaps long autocross / track days when they can get really hot and their is a lot of engine action. ...who knows.
The engine moves around a bit so the flex joints help to dissipate some of jerking traveling through the engine block into the headers by flexing. It can help to relieve some of the stress and prevent the header from cracking. However, I believe that some of these after market headers use quality stainless steel materials. I dont know what the OEM header is made of but if its not made of the same quality part then I can understand why they would put flex joints in there.
I wonder if flex joints could, at some point in the lifetime of the header, be a vulnerable/brittle spot. If they do help to dissipate movement then they will be flexing. They are welded into the headers tubing so those welds could crack or the flex joints themselves could crack. who knows...
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 02-02-2014, 11:51 AM   #32
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Originally Posted by Fast_Freddy View Post
Indeed, the OFH looks as good or better than the Borla UEL it copies.
I am glad they never copied the collector
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
garfull (02-04-2014)
Old 02-02-2014, 11:52 AM   #33
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Shiv
My current exhaust setup is FA20Club Equal Length Catted Header (coated), Perrin Overpipe, Nameless Performance Front Pipe with Catalytic converter and Helmholtz Resonator, Stock Catback exhaust , Perrin Tips, Datalogging of current setup at bottom
Running OFT Stage 2 EL header Gas 1.54 which performs extremely well, smoother, quieter (makes me question selling the Perrin CBE), quicker.
Recently removed and sold to "DaBRZ" a Perrin Catback exhaust, it was too loud with this header.
"Neutron256" has my Perrin Catted Front Pipe that displayed a drone with this header.
With this system in mind, will I see gains and/or be better off with your UEL header?
How much louder or differently will it sound?
I'm considering a purchase from FA20club for their uncatted header pipe, replacing my FA20club catted header pipe. Is your UEL header a better option?
Thank you for your products.
http://datazap.me/u/tonystewart/first-log-155
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 02-02-2014, 12:04 PM   #34
victorb
Drives: Black 86
Those headers looks good aesthetically! But time will tell if those welds will last. Lots of joints or what they call elbows. Are these mandrel bent or crush bent? Are those flanges stainless steel?
Am interested
victorb is offline   Reply With Quote
Old 02-02-2014, 12:44 PM   #35
Malt
Drives: 2015 WRX
Am interested
Shiv stated that the flanges were mild steel because it does better with thermal expansion.
Malt is offline   Reply With Quote
Old 02-02-2014, 12:54 PM   #36
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
That is correct. It also saves a bit on complement cost which can then be put into more useful areas of construction.
And yes all the tubing is mandrel bent 304 stainless steel. No crush bends.
Shiv@Openflash is offline   Reply With Quote
Old 02-02-2014, 01:18 PM   #37
s2d4
s2d4's Avatar
The Borla UEL it copies.
Can you provide any reasons behind your accusation?
Otherwise you are effectively slandering a forum member/vendor.
Old 02-02-2014, 01:38 PM   #38
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
Originally Posted by trevorovert View Post
25k car that most will DD = people not wanting (or able) to spend $1k + on headers, $1k+ on exhaust, $5000 FI, etc.
You won't have to spend 1k on the exhaust if you buy used If anyone spends anything over 2 grand on this car on just exhaust mods. . . not a good idea. Headers though, I can see 800 or so on a quality piece just cause they are pretty difficult to fit properly and are pretty much the most important piece of the exhaust.
IAmNotTheDriftKing is offline   Reply With Quote
The Following User Says Thank You to IAmNotTheDriftKing For This Useful Post:
86-tundra (02-02-2014)
Old 02-02-2014, 01:45 PM   #39
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Who cares? The differences between the Revworks, JDL, OF and Borla UEL headers is mostly in the quality of the construction, materials, flex joints, collector and warranty. They all look about the same. They all seem to have good shop support. OF being unknown at this point but Shiv generally has a decent rep. He's been around forever compared to alot of the jokers that claim to be tuners on this forum. Shiv tuned my 02' wrx back in the day and it was solid. Had his 321 uppipe on that car for 9 years and when I took it off, it still looked new.
industrial is offline   Reply With Quote
The Following 4 Users Say Thank You to industrial For This Useful Post:
86-tundra (02-02-2014), Apoc (02-02-2014), flippy (08-08-2014), Shiv@Openflash (02-02-2014)
Old 02-02-2014, 02:08 PM   #40
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
You said you had a 321 uppipe on your subi for years and it looked great? Did Shiv sell that to you?
FRS
Old 02-02-2014, 02:28 PM   #41
FR-S Matt
Careful, he gets defensive over the Borla UEL and when people talk about how shitty it is. When fisher price welds your collectors, would you expect people to say nice things about it?
The Following 2 Users Say Thank You to FR-S Matt For This Useful Post:
ATL BRZ (02-03-2014), CamryDS (02-06-2014)
Old 02-02-2014, 02:32 PM   #42
tonystewart
Fisher Price, LOL!
affordable power upgrade, and dyno proven, borla collector, borlacollectorsuck, it's open flash time, no shiv no, shitwelderfrom usa, slow boat from proc
OpenFlash Header Shiv@Openflash Engine, Exhaust, Bolt-Ons 2334 06-14-2016 08:37 AM
INTRODUCING ***VISHNU*** OPENFLASH HEADER FOR FR-S/BRZ Garrett@Openflash Engine, Exhaust, Bolt-Ons 7 12-19-2013 06:37 AM
OpenFlash Header Ride Along Video Rombinhood@OpenFlash Engine, Exhaust, Transmission 26 12-04-2013 03:08 PM
FS: Borla EL Header & Openflash Unit toekneehair Engine, Exhaust, Bolt-Ons 12 11-25-2013 04:38 PM
Header Flange Specs? boredom.is.me Engine, Exhaust, Transmission 18 11-11-2013 04:28 PM
