Old 01-26-2013, 07:01 PM   #1
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Changing out the door/courtesy lights - problem
For those that changed out the door lights to leds - did anyone have a problem with a dim/non functioning harness?
My driver's side door is having a problem - tried one set of led bulbs, in the drivers side door it was dim, so I left it alone and ordered another set of bulbs (passenger side is fine). Once I got the new set, the passenger side is still completely fine, but the drivers side bulb will not light at all - even going back to the incandescent bulb isn't working anymore. Wondering if it's possible I blew a fuse or shorted something out....? Seems silly I know but just looking for a little help in the event I'm missing something small, before I take it back to the dealer to have them look at what I potentially screwed up.
Oh, and yes I tried flipping the bulbs both ways, no dice.
mikalem is offline   Reply With Quote
Old 02-02-2014, 02:44 AM   #2
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
I've had the same problem today, did you ever solve the problem ?
ucsmfu is offline   Reply With Quote
Old 02-02-2014, 03:26 AM   #3
wrohdejr
Drives: 2013 subaru limited wrb brz
I had this problem. I had to take it into the stealership because i crossed a wire and blew the BIU "body integrated unit". This is like the ecu of all the electrical stuff in the car. They had to order a new one and then reprogram everything. Luckily for me they covered it under warranty. They were going to make me pay but they couldn't prove i caused the issue because i put the stock bulbs back in. Part was over $600 and labor would have been 6 hours because of time to reprogram and install.
Portland 86ers
wrohdejr is offline   Reply With Quote
Old 02-02-2014, 03:30 AM   #4
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
When I go back, should I put all the bulbs back to stock ? like dome lights, license plates etc... ?
thanks
Old 02-02-2014, 03:56 PM   #5
wrohdejr
If you want to try to have them warranty it. If you don't they will see that you swapped the bulbs and try to blame you for the failure and might not cover it under warranty.
Portland 86ers
Old 02-02-2014, 08:48 PM   #6
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I had a problem with the LED not lighting up at first on the driver side. My problem was that the enclosure for the light wasn't completely snapped together. It looked correct, but I guess something was loose. I had to take it out again and make sure that whole entrapment was completely secured and locked closed....then my light started lighting up.
Maybe that'll help. If not...then definitely take it to the dealership and see if there's something damaged. Those door lights are a PITA to take out!
ericmpena is offline   Reply With Quote
Old 02-03-2014, 01:02 AM   #7
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Sometimes you have to flip over the bulb as it only works on one side...
Old 02-03-2014, 02:13 AM   #8
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
tried both sides, didnt work, no burnt fuse.
Old 02-03-2014, 10:24 PM   #9
mikalem
mikalem's Avatar
@ucsmfu - solution with me was the same as well - blown BIU. Got it covered under warranty as well.
Old 02-04-2014, 03:33 AM   #10
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
so after the repair, did you try to go with led bulbs again ? or just kept the stocks on ?
thanks
Old 02-04-2014, 07:36 AM   #11
mikalem
mikalem's Avatar
thanks
I went a head and put in LEDs - haven't had a problem since the swap out. As a precaution you might want to disconnect the battery before installing them - just to avoid any potential shorts in the line.
Sent from my SGH-M919 using Tapatalk
Old 02-04-2014, 09:51 AM   #12
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
do you think if I hold down the side door button, that will do the job, or I will still have a chance to shorten the courtesy door lights ?
thanks
Old 02-04-2014, 10:04 AM   #13
mikalem
mikalem's Avatar
thanks
Honestly I'm not sure - just trying to offer up as much as I can so you don't have the problem again. Honestly I think subaru got a bad batch early on in the run for these cars (mine was built Oct 2012) - that control unit I know of at least 4 different people that got it replaced. Not sure if it was still a problem for the others but mine was fine the second time around.
Old 02-04-2014, 10:11 AM   #14
buddy32
Drives: WRB Subaru BRZ Limited
Disconnect battery first, or you may blow the BIU. Mine didn't do it under warranty, I paid for it and left them alone from then on.
buddy32 is offline   Reply With Quote
BRZ Driver's Door Courtesy Light Won't Work delusional Issues | Warranty | Recalls / TSB 31 05-29-2022 07:15 AM
Door lights on FRS DanoFA20 Scion FR-S / Toyota 86 GT86 General Forum 11 03-02-2013 09:05 AM
