Old 02-02-2014, 12:36 AM   #1
Euro7R
Drives: 2013 Subaru BRZ
Midpipe Options
Installed a 2.5' Nameless Axleback last weekend. Currently running stock header, overpipe, frontpipe and midpipe.
When I was installing the axleback, I noticed the midpipe end where the axleback meets is rusting (surface rust). Cheap OEM crap. I want to replace the midpipe.
What are my options for midpipe replacement? Would I have to replace front pipe etc?
Euro7R is offline   Reply With Quote
Old 02-02-2014, 12:38 AM   #2
FR-S Matt
Nameless can make one custom if you really want. I would call them up.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Euro7R (02-02-2014)
Old 02-02-2014, 12:45 AM   #3
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
They can make you a 3" midpipe. They won't make a 2.5" section, but if you pester them enough they'll cave.
JDKane527 is offline   Reply With Quote
Old 02-02-2014, 12:53 AM   #4
Euro7R
I need 2.5'' midpipe lol
Old 02-02-2014, 01:46 AM   #5
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
@PERRIN sells high quality 2.5" resonated or unresonated mid pipes, you just have to contact them directly.
mwjcyber is offline   Reply With Quote
Old 02-02-2014, 02:19 AM   #6
Fast_Freddy
Drives: Passat
That "cheap OEM crap" will last ~20 years but waste your money as you see fit. The same 409 grade SS OEM crap on my 93 Legacy still hasn't rusted through after 185k miles and 20+ salt-filled winters. Lots of surface rust though...
You might want to look into the Works midpipe made from aluminized mild steel. That might last a few years if you keep it clean.
Fast_Freddy is offline   Reply With Quote
Old 02-02-2014, 02:27 AM   #7
Euro7R
I've never had surface rust on my exhaust parts from my previous daily driven cars even owing for 10 years. But the BRZ, only been a year ownership, terrible surface rust building up already.
Old 02-02-2014, 02:35 AM   #8
JDKane527
JDKane527's Avatar
But the connection from midpipe to muffler won't work because the Perrin catback exhaust has the pipe connect to the muffler at the middle, and the Nameless connects the way the stock exhaust does.
Old 02-02-2014, 03:32 AM   #9
Euro7R
That's my problem at the moment. Either I sell my Nameless Axleback, which I kinda don't want to and go with a different setup or suck it up and keep everything as it is.
Not sure what other route I can go in terms of replacing the midpipe...
Old 02-02-2014, 03:41 AM   #10
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
i have a solution for you
this will fit your nameless axleback
--> http://www.86industries.com/WORKS-EX...aust_p_50.html
86_ZN6 is offline   Reply With Quote
Old 02-02-2014, 04:50 AM   #11
Fast_Freddy
Drives: Passat
If your concern is longevity or N/A performance, save your money but if your concern is appearance, an aftermarket mid-pipe made from 304 won't exhibit the same appearance of surface rust that the oem 409 does. Just avoid that aluminized crap from Works. I've seen it up close and it is garbage. The only worthwhile replacement mid-pipe I know of is from Supersprint.
Good luck.
Old 02-02-2014, 04:54 AM   #12
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Good luck.
FYI works has a full 304 version now
Old 02-02-2014, 05:12 AM   #13
Fast_Freddy
Drives: Passat
That's a game-changer for sure!
The Following User Says Thank You to Fast_Freddy For This Useful Post:
86_ZN6 (02-02-2014)
Old 07-01-2016, 05:37 PM   #14
Black86
Black86's Avatar
Drives: 2013 Raven Black FR-S
Are you still selling/producing the works midpipe for the frs? I have berk muffler delete and berk catless front pipe but it seems my factory midpipe between is very rusted and the flanges are pretty much toast so im in need of a midpipe. Not sure if I want like factory and have a resonator on it or to have it without one but im Interested if the price is right. Let me know thanks!
-Raven Black 13 FR-S : The daily driver
-88 supra turbo : 2jz 66mm single on E85 in the process
Black86 is offline   Reply With Quote
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 02:35 AM
WTB Midpipe 636 Engine, Exhaust, Bolt-Ons 5 12-29-2013 07:42 AM
WTB Midpipe Vlady Want-To-Buy Requests 0 12-10-2013 12:08 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 02:11 PM
