Old 01-30-2014, 09:52 PM   #15
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
in for installed comparison pics!
glorydays is offline   Reply With Quote
Old 01-31-2014, 01:05 AM   #16
wallace03
wallace03's Avatar
Drives: WRB BRZ
All i can think about after seeing these pictures is Iron Man 2. You sir, have created a new element.
wallace03 is offline   Reply With Quote
Old 01-31-2014, 01:16 AM   #17
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
@Acree think you could post up a whiteboard diagram of what the modified boomerang circuit looks like?
^GT5 Replay Photo Mode^
Old 01-31-2014, 11:47 PM   #18
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Yes sir, I will take care of that tomorrow.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
The Following User Says Thank You to Acree For This Useful Post:
SirBrass (02-01-2014)
Old 01-31-2014, 11:48 PM   #19
Acree
Acree's Avatar
Thanks a lot!
Old 02-01-2014, 12:19 AM   #20
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
While this looks amazing, the end of this line is my concern:
The more material you remove from the heatsinks, the hotter the LED is going to run which diminishes the LEDs life.
Even with the correct thermal management, what are we looking at for reduced life of these LEDs? Some, none? Any input you have would be appreciated prior to me setting out to make this change.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 02-01-2014, 12:41 AM   #21
Acree
Acree's Avatar
I did all of my testing with an infrared thermometer directly onto the heatsink. (Full disclosure, the manufacturer recommends the use of a thermal probe near the thermal mounting pad of the LED, but I do not believe that is necessary in this application.)
I never saw temperatures over 60*C on the heatsink with them being on for an hour straight. Now, two caveats with this: 1) This is with an ambient temperature of 72*F or 22*C. 2) This leaves a temperature increase of 30*C at a minimum before I would even begin to worry about diminished LED life. Even in the direct sunlight on a 110*F Texas day, I don't believe the LEDs will ever get hot enough to worry about overheating or shortended life spans.
The main reason I made that statement was so people would be very conservative when trimming the heatsink. If you go ahead and chop off half of the fins, then the thermal resistance would be close to double of what it used to be. In other words, it would dissipate heat half as well. That's bad.
Superhatch (02-01-2014)
Old 02-05-2014, 01:44 PM   #22
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
whats your thoughts on using slightly smaller heatsink fins? I have a bunch of 25x25x13 laying around.
gdrider77 is offline   Reply With Quote
Old 02-05-2014, 01:59 PM   #23
Acree
Acree's Avatar
Originally Posted by gdrider77 View Post
whats your thoughts on using slightly smaller fins? I have a bunch of 25x25x13 laying around.
As long as the thermal resistance is damn close to 15.6 or lower, no problem.
Old 02-05-2014, 02:12 PM   #24
caffeinejunky
hella stock
caffeinejunky's Avatar
Drives: BRZ Limited
Do you have any pictures with the boomerang assembly on the headlight enclosure? I wanted to see the clearance between the heatsink and the headlight assembly. Assuming there is enough space, wouldnt a lower but wider profile heatsink work better? Lets say, 30x30x10mm?
mods & accessories:
beat-sonic shark fin | raceseng apex r limited green | perrin intake | E85 | RS*R Super Down sus | Cleib CF Lip | STi Side Skirts | Rays Gram Lights 57DR
caffeinejunky is offline   Reply With Quote
Old 02-05-2014, 02:16 PM   #25
Acree
Acree's Avatar
I do not have any photos of that. I'm sure there are a number of different configurations that would fit. I just bought 4 of the same heatsinks that I knew had a small enough footprint for both locations.
Old 02-05-2014, 03:20 PM   #26
caffeinejunky
hella stock
Drives: BRZ Limited
Thanks. Seems like you've looked into this a lot. Another question if you dont mind, so with the DRL's, what are they hooked onto? You said there is no circuitry in the DRL module itself, so I'm assuming its just an led strip? I'm thinking of doing this mod but i'm gonna incorporate the dimmer instead of just cutting it out.
mods & accessories:
Old 02-05-2014, 03:30 PM   #27
Acree
Acree's Avatar
Here ya go.
http://www.hidplanet.com/forums/show...GHTS-INTERNALS
caffeinejunky (02-05-2014)
Old 02-17-2014, 03:20 PM   #28
djdnz
1337
Drives: 2013 BRZ WRB S/C
Why do I have to be so electrically incompetent!?! This sounds like something I'd like to do, but something I'd hate to have to do myself.
djdnz is offline   Reply With Quote
brighter fog light bulb for BRZ? chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 17 01-11-2016 01:57 AM
Interior LED Dome Light Diffuser | DIY | 6X Brighter Dezoris Cosmetic Modification (Interior/Exterior/Lighting) 8 04-21-2013 08:59 PM
Brighter "Boomerangs" Jaylyons1 Mid-Atlantic 3 02-05-2013 07:53 PM
