#29 | |
Drives: 2013 BRZ, WRB
I thought about buying lightweight pulleys (I'd like less flywheel effect during shifts)... but on doing a little math I think I'd be disappointed in the difference these would make. I'll put the cash in the piggy bank for now and maybe put it towards a lightweight flywheel later (which will make a much bigger difference and doesn't come with the downside risk of some internet maven looking under my hood and screaming "Oh Noes! Lightweight Crank Pulley, your crank is half broken!! ". There's a ton of opinion on the subject, very little actual info.
| The Following 2 Users Say Thank You to Ralph Spoilsport For This Useful Post: | Boofneenee (11-02-2013), Gixxersixxerman (12-08-2013) |
#30 |
Drives: toyota mr2/ Toyota GT86
is this kit undersized pulleys or standard ?
as just lighter/ same size pulleys shouldn't make any difference to steady state horsepower? unless the dyno pull was done with a transient brake? |
#31 |
Drives: UK GT86
They are same size
.: Stealth 86 :.
#32 |
Drives: frs
Standard size. I wouldn't pay much attention to the dyno, I got it for throttle response
#33 |
so who does the best undersized ancillary pullies?
I was thinking about 10% smaller on water pump and the alternator |
#34 |
Drives: UK GT86
Smaller overdrives the alternator and water pump. You oversize to reduce the drag. Which is therefore better, normal size (lighter) or larger (less drag) who knows?? I'd suggest that both are pretty much close enough, I'd just rather not under drive essential parts.
.: Stealth 86 :.
#35 |
Whoops thats what I meant
10% slower running is what I was after the reason for asking is that most water pumps are over capacity and alternators too so while you're there making new pullies, then it makes sense to me to slow these down a little circuit werks seem to be std size so who does a lightweight overszed pulley? |
#36 |
Drives: '13 FR-S
#38 | |
Drives: 2013 Subaru BRZ & 99' Ford Explorer
#39 |
they always try to leave some meat on the bone. they want a reliable car.
#40 |
#41 |
Drives: 2018 BMW M240i
I am happy with mine. Been running them for about 4,000 miles now. Absolutely no wobble.
With the price of the Circuit Werks so cheap I cant see why you would go with another set. Name brand does not mean much to me if it is going to cost double and get me nothing. They are all aluminum pulleys. |
#42 | |
Here's the long answer if you're curious. Any weight removed off the drivetrain assembly (crank pulleys, flywheels, drive shafts, wheels, etc) reduces rotating mass and thus improves throttle response, acceleration, and drivetrain efficiency which is why there are slight increases in HP. The side effect is that rev matching must be more precise because the throttle response is so quick and may be a challenge for some drivers to shift smoothly. More mass makes shifting easier but also creates throttle lag. Manufacturers always try to find a balance between performance and driving comfort for the average consumer. They also have a target production cost. Lightweight components cost more and they have to pick and choose what components are made of aluminum let alone forged billet aluminum. The cost of CNC machining is also a factor. They made the right move on the aluminum hood as this has more impact on the power to weight ratio without any adverse affects to comfort. Lightweight flywheels and pulleys are a personal choice depending on whether you want smoother and easier shifts or better throttle response. They left these kinds of choices up to the end consumer. I've had a lightweight flywheel on a previous car and it was one of the best bang for your buck upgrades i ever made. You can feel it most in first and second gear but I had to be more precise with my throttle and clutch technique to keep shifts smooth. |
| The Following User Says Thank You to dj petey For This Useful Post: | stugray (04-05-2014) |
| Effectiveness of a Lightweight pulley | DrifterX | Engine, Exhaust, Transmission | 94 | 12-11-2016 01:10 AM |
| FS: red Perrin lightweight pulley | DGMBRZ | Engine, Exhaust, Bolt-Ons | 14 | 03-25-2013 05:42 AM |
| Go Fast Bits Lightweight Pulley Kit on sale & Free Shipping @ Circuit Motorsports | Circuit Motorsports | Engine, Exhaust, Bolt-Ons | 58 | 03-20-2013 02:07 PM |
| *****Lightweight Pulley For your FR-S/BRZ/86 ***** | SOURCE,LLC | Engine, Exhaust, Bolt-Ons | 2 | 03-07-2013 08:21 PM |
| Lightweight pulley wow | Silverdub | Engine, Exhaust, Transmission | 240 | 01-23-2013 01:00 PM |
