CANADA Canada
Old 01-30-2014, 03:41 PM   #57
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Originally Posted by 7thgear View Post
rats, the mods are on to him.
our chance for village justice is ruined.
Haha that's funny.
Gords_zenith is offline   Reply With Quote
Old 01-30-2014, 03:53 PM   #58
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
lol. I had to add a thread tag.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
7thgear (01-30-2014), wparsons (01-30-2014)
Old 01-30-2014, 04:20 PM   #59
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
After reading a few more of his posts, I figured I'd just throw this in here as evidence of how dangerous this car is with it's crazy snap oversteer. Plus I forgot how entertaining it was when this happened.
[ame="http://www.youtube.com/watch?v=1m_Iy6gTPVg"]Oops in turn 1 at Sebring. Subaru BRZ / Chin Motorsports 4-13-13 - YouTube[/ame]
(and yes, the crazy snap oversteer bit was sarcastic)
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
sal (01-30-2014), wparsons (01-31-2014)
Old 01-30-2014, 04:21 PM   #60
jvincent
jvincent's Avatar
I say we DOGE him into submission.
The Following User Says Thank You to jvincent For This Useful Post:
Nasty Sausage (01-31-2014)
Old 01-30-2014, 08:02 PM   #61
Suberman
Drives: Subaru BRZ Sport Tech Satin White
And in Suberman's defense (I know I will regret this).
The BRZ is rated at 0.92Gs on the 300 ft skidpad.
Just beneath the 1988 Vette (0.93Gs) and barely above the 1985 Honda CRX (0.91Gs).
Note: The 2008 Bugatti Veyron gets exactly 1.00G. If you could get significantly greater than 1.0G in a skidpad test, dont you think a multi-million dollar car could do it?
So based on those numbers, the BRZ is a poor handling car (by today's standards).
(caveat: the above 0.93G skidpad test was done with the well known "crappy" stock tires)
No regrets. That number is apparently on the stock tire. Put Prius tires on the 'vetted and see what the g number is.
There's no doubt the BRZ can handle. It's after it stops handling so well that the issues arise.
On dry road the car grips well enough but on wet roads, and as this whole topic got started, and snow or ice it reveals an Achilles heel.
Suberman is offline   Reply With Quote
Old 01-30-2014, 08:16 PM   #62
Suberman
Originally Posted by maloney2 View Post
Yes they are, but the weight has been transferred from the inside wheels so the total normal load remains the same. In general the more load transfer the lower the cornering potential of the vehicle due to the diminishing frictional coefficient of the tires with increased load.
You're right, I went a bit over board on a new guy. Sorry about that.
The Big Bang reference was supposed to tip you off I wasn't serious, but I guess you misinterpreted that.
You did accuse me of making false statements. And in all caps AND bold. In my line of work that's calling someone a liar which justifies a sharp rebuke.
A moments longer reflection might have reminded me you likely use "false" in the mathematical sense as "incorrect".
Just writing that in your opinion I'm wrong would avoid that misunderstanding.
You validly point out the fact that the coefficient of friction between tire and road varies and varies with load. I was simplifying that for this reason. While it is true that the coefficient of friction varies it does so by reducing as load increases. It is not linear but it is close enough to linear for a lay person. The main point is mu for rolling tires is treated as for static friction even though there's a lot of movement going on at the contact patch. For practical purposes the driver only needs to know that rolling mu will be at a minimum just before the tire slides and mu then becomes much lower kinetic mu, often quite quickly. The higher mu experienced at lower tire loadings is not noticed by and not relevant to the driver because slip angles haven't reached critical levels when mu is higher.
That's not all that you state correctly but there's no point me setting out every point I agree with you upon.
These boards are a democracy. You can accept or reject whatever you wish.
Old 01-30-2014, 08:18 PM   #63
Suberman
So basically you just insulted someone who continued their education past the bare minimum because you felt threatened by them or something?
Keep it up and your stay will be shorter than you expect it to be.
Not intended. The Big Bang reference should have made that clear.
Old 01-30-2014, 08:59 PM   #64
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
THAT'S what democracy means!?!!? I've been doing it all wrong this whole time. Thanks, lawyer genius!
- AdrianG
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
Old 01-30-2014, 09:00 PM   #65
PMPB
Drives: BRZ Sport-tech
BS. You've attacked me when I pulled out my credentials, wparsons when he defended himself against your attack on his intelligence when he stated that he works at the nuke, so on and so forth.
Stop trying to be coy, you're a bully to those who threaten you with their knowledge and intellect.
PMPB is offline   Reply With Quote
Old 01-30-2014, 09:05 PM   #66
mrceltic
Drives: 2013 Hot Lava Scion FR-S
To summarize, Suberman was wrong, but it was Maloney's fault...
HE misinterpreted. HE used the wrong word, or phrasing. HE called Suberman "a liar" by using capital letters?
Trollpology.
mrceltic is offline   Reply With Quote
The Following User Says Thank You to mrceltic For This Useful Post:
Old 01-30-2014, 09:13 PM   #67
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
Funny how the words "true", "agree", and my favourite "sorry" come out only when threatened with possible removal from the site.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
The Following User Says Thank You to that_guy For This Useful Post:
Old 01-30-2014, 10:03 PM   #68
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yeah. It was a clear attack on him.
Attack his point of view and facts all you want, that's fine, but personal attacks won't be tolerated.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-30-2014, 10:57 PM   #69
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Then that just means that those cars have tires that have a frictional coefficient that is greater than 1.0 OR the results were taken on a skidpad greater than the 300ft version.
When you go up in skidpad radius, the average speed of the vehicle goes up so aerodynamic downforce comes into play.
Another effect I have seen when trying to measure lateral acceleration in cars with data acquisition: A fixed data acq system (like traqmate) has internal accelerometers that can measure acceleration in 3 axes.
I have seen a 62 triumph TR4 register nearly 1.0G "lateral" acceleration.
That is clearly not reasonable in that car, so what is happening is that as the car corners, the body rolls and the "lateral" accelerometer is now getting a component from gravity.
So sometimes the lateral "G-force" numbers are lying a bit.
I believe these numbers were on a standard skidpad, and body roll isn't much of an issue on those cars. I would bet on the sticky tires as the cause - both of those cars can come with the Michelin Pilot Sport Cup tires, which are barely street legal and mostly made for the track. They really aren't practical tires in any way. They do put down impressive results on the track though. The pilot sport cup 2s (the newer version of the same tire) were used on the 918 spyder for its sub-7 minute lap of the nurburgring, for example.
chrisl is offline   Reply With Quote
Old 01-31-2014, 07:36 AM   #70
wparsons
wparsons's Avatar
Best part, I'm not an engineer and don't work at a power plant at all. I figure he either tried to look me up online and failed, or was trying to make a lame homer simpson joke.
flickr
bill o'reilly offspring, clueless retard lawyer, cognitive dissonance, death by friction, it's all about me, read at your own risk, suberman is delusional, tricycle is faster, village justice
