Old 01-30-2014, 12:51 PM   #253
tendogy
The factory narrowband bottoms out at about 12:1 AFR. This is rich enough that being lower won't be an issue (unless you're so rich the car will barely idle). It does, however, accurately read up to 18:1 AFR, and maxes out at 20:1 AFR.
Thanks, that is great information (and saves me $474)!
How accurate is the OEM MAP sensor once supercharged? The Scangauge reads that too, but I was planning to not trust it (based on no reason at all).
You know... I think the Scangauge might also be able to display AFR... I'll have to look it up.
Edit: Looked it up, and I was correct. So in summary, a Scangauge II can display Oil temp, AFR, MAP, Intake air temps, and Coolant temps. It can display up to four simultaneously. The refresh rate on the readings is a bit slow, but plenty sufficient for daily monitoring.
tendogy is offline   Reply With Quote
Old 01-30-2014, 12:56 PM   #254
CSG Mike
CSG Mike's Avatar
It reads up to 20.0 PSI absolute, but starts to get inaccurate over 19.3 PSI. The ECU will also read barametric pressure, and you need to subtract the barometric pressure from the MAP pressure, to get your actual boost pressure (but again, the MAP sensor maxes out before you hit peak boost).
Most OBD2 readers will be able to read Lambda, which is a raw voltage value for AFR. If we see 0.8-0.9 raw on that under WOT, we're happy. It's "close enough". We also read the catalytic converter temp (also available through the ECU), and that'll tell us very quickly if we're leaning out, as the temp will skyrocket past 1600F. I don't think we've ever seen it go over 1500F under hard use, and normally sits around 1100-1200F cruising, and 1450F under sustained load (going uphill, WOT, etc.)
Old 01-30-2014, 06:00 PM   #255
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
lambda is perfect for reading AFR , just do the calculations like mike said. I look for around .83 on WOT.
if you are really serious about boosting, i'd recommend getting an afr gauge still. simple enough, cheap enough, worth it
86-tundra is offline   Reply With Quote
Old 01-30-2014, 06:55 PM   #256
jamesm
i wouldn't drive a boosted car without a wideband. you could maybe ditch the boost gauge on a supercharger (certainly not a turbo car. wastegate lines DO pop off). you just never know, and a couple hundred bucks on gauges can save your bacon. right @Frs300?
$200 isn't much when you consider the cost of windowing a block. there are a lot better places to save money.
Old 01-30-2014, 07:00 PM   #257
CSG Mike
CSG Mike's Avatar
The factory narrowband reads plenty accurate in the danger areas of running lean. Doesn't hurt to have a wideband, but we choose not to.
Old 01-30-2014, 07:57 PM   #258
Frs300
Frs300's Avatar
Drives: Pile of junk
$200 vs $10k...i should have installed mine from the get go instead of being lazy and wanting to take it down the street and back.
BANG CLANK BOOM
Frs300 is offline   Reply With Quote
Old 01-30-2014, 08:15 PM   #259
jamesm
'can' and 'would' are very, very different things... but to each his own. i can't say i've never done it...
Old 01-30-2014, 11:57 PM   #260
Pete156
I like to eat!
Originally Posted by Frs300 View Post
BANG CLANK BOOM
I've heard that song before
Pete156 is offline   Reply With Quote
Old 01-31-2014, 01:15 AM   #261
CSG David
CSG David's Avatar
You mean this song? By the way, I love Just Kidding Films and their YouTube friends like the Poreotics...lol
[ame="http://www.youtube.com/watch?v=fw1My4WtcDc"]No More Power No More Gas | OFFICIAL MUSIC VIDEO - YouTube[/ame]
Old 01-31-2014, 07:27 AM   #262
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
$5,000 +/- Daily Driver FI (out-the-door) buyer's guide - Persuasion time
No way anyone should be boosting without a proper wideband. The factory AFR sensor is fine for closed loop operation but a wideband is necessary for open loop (WOT).
There's no point in having the sensor (narrowband) if the sensor can't read the measurement accurately, hence the need for a wideband.
I use a standalone wideband as a way of checking the narrowband against each other. I had a fouled narrowband, it never threw any DTC but it's readings were horribly off compared to my wideband. The wideband readings were inline with what I was expecting to see. I replaced the narrowband and both readings were spot on. Not to mention who doesn't want to monitor their tune?
The boost gauge is also important. Yes, you'll know if you're losing boost but you may not be able to tell if you're over boosting, which could lead to disaster. The butt gauge is about as effective as the butt dyno.
Even if you use a gauge like the P3Cars vent gauge where you can program the gauge to flash if you bypass the set boost even if you're not on the boost screen, you'll know something is wrong and to let off if it flashes.
Wastegate lines can become frayed and no boost cut will work if that happens. For engine longevity, I recommend one with an FI build.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 01-31-2014, 11:29 AM   #263
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Huh, I gotta tune my butt gauge and my butt dyno again
Nothing makes you take your foot off the throttle like a flashing light or smoke from the engine!
Old 01-31-2014, 11:33 AM   #264
CSG Mike
CSG Mike's Avatar
I think this post is absolutely spot on for Turbo applications.
Old 01-31-2014, 11:38 AM   #265
jamesm
not true . ecutek racerom custom map... can read the MAP directly and cut fuel (or do anything else) when appropriate.
aside from that i agree with you whole-heartedly lol
Old 01-31-2014, 11:41 AM   #266
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Exactly. I like turbo applications, I like gauges, because racecar.
FT86 Buyer's Guide! FRS vs. BRZ Differences Detailed! [Video + High Res. Stills] Rosso_Corsa Scion FR-S / Toyota 86 GT86 General Forum 23 11-03-2013 04:10 PM
First time buyer - help! chotemaamu Scion FR-S / Toyota 86 GT86 General Forum 27 02-27-2013 12:21 PM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) — General Topics 47 05-23-2012 12:15 PM
The daily driver KiingDavid CANADA 25 02-06-2012 01:14 PM
