Old 01-30-2014, 12:13 PM   #29
jeebus
I think I seem to have found the pattern. Around 3400RPM @ .9 engine load during cruise conditions (driving up a hill in this case). I'll dial back timing a tad and see how it goes.
jeebus is offline   Reply With Quote
Old 01-30-2014, 01:12 PM   #30
jflogerzi
jflogerzi's Avatar
so any drop in the IAM below 1 is a sign of knock and the engine will pull timing to compensate?
Old 01-30-2014, 01:22 PM   #31
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Yes. Any multiplier (DAM) below 1 reduces the timing.
^GT5 Replay Photo Mode^
Old 01-30-2014, 02:53 PM   #32
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
still trying to understand what the KC learned value is and what it should be.
KC = knock correction?
garfull is offline   Reply With Quote
Old 01-30-2014, 02:58 PM   #33
steve99
Drives: FT86
Jamesm explained it to me
You need to look at the Engine RPM Vs Load table in tunepro/romraider ect and look at the value in the table for the given RPM vs Load. If that value is say 6 and your KC Learned is say 2 then it means its pulled 4 degrees of timing at that RPM/load point.
If the value in the RPM vs Load table equals the KC Learned then their is no knock retard at that rpm/load.
Hopefully I got it right.
Old 01-30-2014, 08:58 PM   #34
PMok
Codename: Stitch
PMok's Avatar
so I did another run today on a full tank of 91, with similar results.
http://www.datazap.me/u/pmok/stage-1...og=0&data=1-12
Adv. Multiplier was around 0.52 when I started the car. As you can see it went back up a little during the run, but still nowhere near 1.00 at all. Thoughts/recommendations? Assume that I have no tuning skills at all and very little inclination to get too involved into it. Should I be worried enough to switch back to stock tune, or find a way to get higher octane gas?
Old 01-30-2014, 10:01 PM   #35
garfull
garfull's Avatar
Try recording some runs on the stock tune to see if u still have similar results.
The Following User Says Thank You to garfull For This Useful Post:
PMok (01-30-2014)
Old 01-30-2014, 10:07 PM   #36
connorlug
Drives: #1553 10 Series FRS
Originally Posted by jeebus View Post
I had the best luck with 76 in my modded Forester XT...so it doesn't sound odd at all. However, I had the best luck quieting the crickets with Chevron which is why I stuck with it. That, and every convenient stop on my commute is Chevron....however, I'll give 76 a whirl if I don't just run e85 all the time.
Sorry to randomly chime in, but I also used to have a modded forester xt... were you on the sf.org forums?
connorlug is offline   Reply With Quote
Old 01-30-2014, 10:15 PM   #37
steve99
Drives: FT86
+1
Be interesting to see if it was happening on standard tune
Pmok are you at significant altitude above sea level ?
PMok you could
Source some higher octane fuel
add octane booster to current fuel
Pull some timing in the problem area's (although you stated you don't want to get involved in doing that)
Run E85 and E85 tune
Old 01-30-2014, 10:29 PM   #38
PMok
Codename: Stitch
PMok's Avatar
+1
PMok you could
Yeah I will try logging at stock tune and see if I get similar results. Was wondering if anyone would say to let it keep learning a little more or what. I live in the hills about 1200ft above sea level but the logging and most driving is done pretty close to sea level.
Thanks guys!
Old 01-30-2014, 10:31 PM   #39
jeebus
yeah, long time ago. same username.
Old 01-31-2014, 12:24 AM   #40
jamesm
i've fought tip-in knock with this thing since i started tuning it. I've tried all sorts of stuff, from the regular timing adjustments to throttle mapping and cam timing. Nothing so far has worked. Not even E85 lol. You can make it happen less often, and you can make it less severe (where you may see up to -2.1's you can get it to only ever pull -1), but I haven't found a way to eliminate it entirely. I've got it down to one or two instances in a 20-30 minute log at best.
My next plan is a custom map that'll pull timing based on throttle delta. If that doesn't work, i'll try the same thing with MAP delta.
The hack around the IAM dropping is just to make sure the value in the advance map where it happens is less than 3.9 (while keeping the same total timing).
Old 01-31-2014, 01:57 AM   #41
atledreier
Drives: GT86 DGM
Bob at Circuit Motorsport fixed my tip-in knock. No idea what he did, though.
atledreier is offline   Reply With Quote
Old 01-31-2014, 02:41 AM   #42
Kodename47
Kodename47's Avatar
Drives: UK GT86
The IAM will not start to increase until the engine is satisfying certain RPM and load parameters. IAM will not try and increase during low load (normal low RPM) driving.
Basically, most of the 2nd half of that log the ECU isn't even trying to increase timing, that may not be due to it seeing knock etc. Its not ideal that its starting at 0.52. Its hard to tell if its pulling timing during the WOT pulls as you've not repeated them so there's nothing to compare.
.: Stealth 86 :.
Kodename 47 DJ:
PMok (01-31-2014)
K&N Air Filter installed, MPG dropping? HATED1 Engine, Exhaust, Transmission 35 05-09-2018 10:13 PM
Santa keeps dropping the BRZS off HeubergerMotors BRZ First-Gen (2012+) — General Topics 11 12-19-2013 06:26 PM
Displaying the Adv Multiplier sw20kosh Software Tuning 12 12-09-2013 10:42 PM
Multiplier and offset for OMNI 2.5 bar map sensor? ATSAaron Forced Induction 2 10-28-2013 11:16 AM
Dropping car off Friday for TSB service.. some questions pgeist Issues | Warranty | Recalls / TSB 6 07-15-2013 02:45 PM
