#43 | |
Drives: BRZ Sport-tech
Some tires display adhesion (like tape). They mold to the surface (conjoin), etc. Not just friction. |
#44 | |
http://www.caranddriver.com/features...rbitals-page-3 I'm not claiming you can get 3G, but it is definitely possibly to get above 1G without downforce. This is also a sustained skidpad reading, in a shorter corner you can record much higher forces than you'll pull on a skidpad. You also have to make sure you're comparing apples to apples, some skipads are 300', some are 200' and some are 120'. The same car will pull different numbers on each diameter.
Light travels faster than sound, so people may appear to be bright until you hear them speak... flickr Last edited by wparsons; 01-30-2014 at 02:17 PM. |
#45 | |
BRZonite
Drives: 2013 BRZ Sport-Tech, 1992 FD3S RX-7
#46 |
Drives: WRB BRZ Sport Tech
Maybe someone can post lateral g's using the same tires as a new Corvette aka Michelin pilot super sport stock size and I would guess it would pull significantly better.
#47 |
i'm sorry, what?
Drives: Canada
AFAIK the PSS don't come in 17s
#48 |
They are actually pretty affordable.
http://www.tirerack.com/tires/tires....SSXL&tab=Sizes Here is what the FRS can do with meaty AD08's http://www.edmunds.com/car-reviews/t...rack-test.html Last edited by PMPB; 01-30-2014 at 03:07 PM. |
#49 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
Apparently not - the ZR1 Vette gets 1.1G on a skidpad, and the 991 GT3 gets 1.12, despite the fact that you could easily buy two of each and a nice house for less than the cost of the Veyron... |
#50 | |
i'm sorry, what?
Drives: Canada
i think i was thinking of some other super fancy, corvette-only tire (that only comes in like 3 sizes)
#51 | |
Drives: 2013 GBS BRZ Limited
I agree that there IS a very brief transient downforce on the outside wheel due to the rotational inertia of the car as you "snap into a corner" , but it does not last more than a fraction of a second. So it does not really come into play over the course of an entire corner. This is part of the concept of "Mu" that suberman was trying to get across. When the weight of the car is distributed evenly over 4 wheels and you try to pull the car sideways with a lateral force, you have 4X as much contact patch as you do if only one wheel is in contact with the ground, but each contact patch is only carrying 1/4 the weight. Since each contact patch has 1/4 the weight, it can sustain 1/4 of the lateral force. When all of the weight is on one contact patch, that patch can sustain 4X as much lateral force due to the additional down force on that contact patch. That is the concept of Mu. Regardless of how much contact patch you have or how the weight is distributed, you have the same ability to resist the lateral force. (that is until the non-linear characteristics of tire deformation & stiction come into play) |
#52 |
Drive From Home
Drives: BRZ STI Performance
Okay then post up the lateral g's for the Subaru BRZ tS they come with 225/40/R18 PSS stock lol! I tried googling it in Japanese but nothing even from the reviews.
#53 | |
When you go up in skidpad radius, the average speed of the vehicle goes up so aerodynamic downforce comes into play. Another effect I have seen when trying to measure lateral acceleration in cars with data acquisition: A fixed data acq system (like traqmate) has internal accelerometers that can measure acceleration in 3 axes. I have seen a 62 triumph TR4 register nearly 1.0G "lateral" acceleration. That is clearly not reasonable in that car, so what is happening is that as the car corners, the body rolls and the "lateral" accelerometer is now getting a component from gravity. So sometimes the lateral "G-force" numbers are lying a bit. Last edited by stugray; 01-30-2014 at 05:28 PM. |
#54 | |
Site Moderator
Drives: Stuff
Keep it up and your stay will be shorter than you expect it to be.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#55 |
i'm sorry, what?
Drives: Canada
rats, the mods are on to him.
our chance for village justice is ruined.
#56 |
Ridge Racerrrrrrrrr
I like my Master's degree
| Tags |
| bill o'reilly offspring, clueless retard lawyer, cognitive dissonance, death by friction, it's all about me, read at your own risk, suberman is delusional, tricycle is faster, village justice |
