Old 01-30-2014, 12:16 PM   #1
juanam0909
Drives: scion fr-s
Short ram or cold air intake?
Hello guys, I don't know a lot about engines to be honest, so with that said, I need help on deciding what intake to get short or cold what's the difference?
Sent from my Nexus 7 using Tapatalk
juanam0909 is offline   Reply With Quote
Old 01-30-2014, 12:28 PM   #2
Malt
Drives: 2015 WRX
Neither. Wait for grimmspeed to release their intake and get that since the majority of the intakes sold right now are Crap.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
sprintertrueno86 (02-01-2014)
Old 01-30-2014, 12:45 PM   #3
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
panel filter.
supramkivtt2jz is offline   Reply With Quote
Old 01-30-2014, 01:26 PM   #4
juanam0909
Drives: scion fr-s
Malt thanks for the response, but still whats better cold air or short ram what's the difference? My car is bone stock just suspension
Old 01-30-2014, 01:46 PM   #5
Malt
Drives: 2015 WRX
I personally would not buy any of the currently available intakes. They either require aftermarket tuning to make power or just plain suck.
Old 01-30-2014, 01:50 PM   #6
FR-S Matt
Cold air is always better, but depending on the car, it may not be possible. Grimmspeed will probably have an awesome intake after their testing results.
Old 01-30-2014, 01:56 PM   #7
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Not much difference other can sound.
If I didn't already have an intake, id wait for full blown
http://www.ft86club.com/forums/showthread.php?t=56850
Carlitoz3 is offline   Reply With Quote
Old 01-30-2014, 02:07 PM   #8
wheelhaus
wheelhaus's Avatar
Some will argue a cold air is better. And that a short ram only ingests hot air from the engine bay. This may be true on some platforms, but is much less likely on the 86. Most intakes I've seen use the factory location to good effect, cold air or short ram. I believe CSG Mike did some thermal tests with the Jackson Racing supercharger kit's short ram intake and it was ingesting ambient air temps so long as the car was moving.
The only risk to a short ram is heat soaking while stopped, which isn't a problem because the engine is under no load and the moment you move, cool air comes in. The paranoid will an a shroud, which in and of itself isn't a bad idea, just not completely necessary.
The problem I see with a cold air is if the filter is in a fender or exposed in the bumper is troublesome maintenance and/or possible water ingestion.
The Following User Says Thank You to wheelhaus For This Useful Post:
juanam0909 (01-30-2014)
Old 01-30-2014, 02:18 PM   #9
juanam0909
Drives: scion fr-s
Wheelhaus thanks for answering my question!
Old 01-30-2014, 02:41 PM   #10
zooki
Drives: waiting on a 2021...
Just get a drop in filter. The stock air intake setup is already cold air induction, and it is very well designed from the factory from everything I've seen. It will probably support any horsepower increases you would conceivably see from bolt on parts. The only reason I see to go aftermarket is sound.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
jflogerzi (02-01-2014)
Old 01-31-2014, 06:16 AM   #11
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
The BEST combo out there is the TRD cold air intake with any aftermarket snorkel air duct scoop, the only down side is both together are $500 plus.
Dr. BRZ is offline   Reply With Quote
Old 01-31-2014, 06:22 AM   #12
Carlitoz3
Carlitoz3's Avatar
I'm sorry what's snorkel air duct scoop?
Old 01-31-2014, 06:30 AM   #13
Dr. BRZ
Dr. BRZ's Avatar
easy, 3 in 1 and 1 in 3.
Old 01-31-2014, 09:46 AM   #14
zooki
Has ANYONE actually tested any of these aftermarket snorkels and made more power? Or is it a case of "it looks cooler so it must be better"? The one member who actually dynoed his car(with a Zeek duct) gained 4HP at the very top end while losing 15 lbs./ft. of torque throughout much of the RPM range. I would have to see some actual results before I would spend the money. But, hey, it's your money, not mine. Grimmspeed has tested the stock snorkel and it seems to be a very well designed part.
Best cold air intake natesparxxx Engine, Exhaust, Transmission 31 05-31-2021 06:04 PM
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
Short ram Intake/CAI ? QC-FRS Engine, Exhaust, Transmission 12 02-01-2014 09:02 PM
GI/FS: AMR Cold Air Intake Kuzuri Engine, Exhaust, Bolt-Ons 5 08-19-2013 09:58 PM
Custom Cold Air OR Short Ram Intake - Any color Powder Coated Signature Products Engine, Exhaust, Bolt-Ons 6 08-02-2013 06:51 AM
