Old 01-29-2014, 12:44 PM   #1
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
Question Tire Trailers
For this upcoming season, I've been considering purchasing a tire trailer and completely dedicating my separate wheels/tires to off-road use only. Did anyone use a smaller trailer to tow their tools and wheels/tires last season (or plan on doing it for this upcoming season)? I don't know the first thing about hooking up a trailer to this car - any suggestions? Can the FRS/BRZ rear bumper support a tow hook/hitch and trailer? What's the best way to hook up the electrical harnesses?
Thanks!
PoorMansRacing is offline   Reply With Quote
Old 01-29-2014, 12:51 PM   #2
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
What? You don't want to cram them all into the car? All that wasted space!
Anthonytpt is online now   Reply With Quote
Old 01-29-2014, 12:55 PM   #3
Anthonytpt
Anthonytpt's Avatar
Here you go: http://www.ft86club.com/forums/showp...7&postcount=30
And here: http://www.ft86club.com/forums/showp...28&postcount=7
Those folks should be able to share some knowledge.
Old 01-29-2014, 01:40 PM   #4
stugray
Drives: 2013 GBS BRZ Limited
You actually CAN fit all 4 tires/wheels inside the car if you wanted to.
Old 01-29-2014, 05:52 PM   #5
Eric1855
Drives: LP DSP / CSP '13 BRZ
You can and I have but a trailer is so much easier.
I've built several tire trailers and I am building another this year. It's easy to start with a harbor freight frame an build it up yourself. You can make a deck out if diamond plate or wood and then configure to your liking and tire sizes.
The one I'm doing now is pretty basic with two posts with lockable tops to stack tires 2 high and lock them in place. Then a lockable tool box on the front for gear storage.
Eric1855 is offline   Reply With Quote
Old 03-12-2014, 08:07 PM   #6
Eric1855
Finished up my trailer this weekend.
Started with a HF frame
3/4" plywood deck
Lockable tool chest
Assembled and used galvanized pipe to build the poles for holding the tires. Put a screw on T-joint at the top that I run a bike lock through to discourage people from running off with the tires easily.
I had a friend weld up a custom hitch, bolts into the tow hook receivers.
Loaded up and ready to go
Old 03-12-2014, 09:41 PM   #7
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Oh that's brilliant, using both OEM tow hook holes!! How can I get one?! I love it!!
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 03-12-2014, 10:46 PM   #8
t.chk
Drives: Subaru BRZ Limited
Use kasks' hitch, its the shit!
It is bolted directly to the rear bumper, and it does not mess with ground clearance, and you do not have to change the towhook sheering off.
t.chk is offline   Reply With Quote
Old 03-12-2014, 10:49 PM   #9
DAEMANO
Time Traveller
Looks perfect!
I want this so bad.
Anyone know if this is legal in CA? If not what would make it so?
Thanks!
3/4" plywood deck
Lockable tool chest
Old 03-12-2014, 10:52 PM   #10
Eric1855
I have nothing against the other hitches, I just like this design because I can take it off at the track and save the weight...and it was only like $100 in materials.
Only issue we ran into with this one is that you need really tight tolerances to get the right fit and when we tried it on other BRZ/FRS it wouldn't fit because they were each all slightly off (1-2mm) so it is not one size fits all. So while it would probably fit most other cars, it won't fit all other cars.
Old 03-13-2014, 11:05 AM   #11
smbstyle
smbstyle's Avatar
How much would your buddy charge to make one?
2013 SWP BRZ
Old 03-13-2014, 10:32 PM   #12
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Your trailer looks a lot like the one I have. I believe you have 8" rims though. Very interested in the Hitch/Tow Bar and can make my own. Would your friend care to share the information about his design? Very ingenious, wishing that I had thought of it. Is that the Stig on the wall? Outstanding.
3/4" plywood deck
Lockable tool chest
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
Old 03-13-2014, 11:01 PM   #13
Eric1855
I can talk to him and see. It would be tough to make one for someone else without being able to get exact measurements and do test fits on the exact car before welding, because it is weird, but every single car we looked at was just slightly different.
Old 03-14-2014, 09:26 AM   #14
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I would be interested in a hitch reviver like that as well for exactly the same thing you're doing.
WTB: 1 OEM FRS/BRZ Tire RedFR-s Canada Classifieds 3 11-08-2013 11:43 AM
Tire Noise? Admiral Ballsy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 07-04-2013 09:02 PM
what is your tire pressure? abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-03-2013 10:49 AM
WTB One (1) OEM Tire Trojan_SC Wheels and Tires 2 05-07-2013 03:59 PM
What tire PSI are you using SEC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-30-2012 09:09 AM
