Old 01-29-2014, 12:49 PM   #141
JFBRZ711
Drives: 13' BRZ Limited CBS
Having a hard time finding light sockets for a 1157 or 3157 bulb that's isn't from an old vehicle. Those sockets are huuuuge and bulky. Is that what everyone is using? If not any suggestions?!?
JFBRZ711 is offline   Reply With Quote
Old 01-29-2014, 01:21 PM   #142
TheLaughingMan
TheLaughingMan's Avatar
I used a smaller bulb (921) and this
just a little rubbery/plastic socket I found at an autoparts store. that probably doesn't help you much but at least it's an alternative
TheLaughingMan is offline   Reply With Quote
Old 01-29-2014, 07:07 PM   #143
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
I just purchased this kit, used a 15% off coupon and it was like $39 including shipping. Comes with everything needed, even the drill bit and LED light. Hard to beat that price even getting the parts myself.
http://store.ijdmtoy.com/Scion-FR-S-...led-sku224.htm
Deathalo is offline   Reply With Quote
The Following User Says Thank You to Deathalo For This Useful Post:
JFBRZ711 (01-30-2014)
Old 01-30-2014, 11:27 AM   #144
ericw2k
Nice write up, will the water get inside?
I drive slow!
ericw2k is offline   Reply With Quote
Old 01-30-2014, 01:28 PM   #145
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by milhouse View Post
Is there a way to tap into the BRZ fog lights to do this? I know it can't be done with the FRS but the BRZ limited has fogs.
Sent from my iPhone using Tapatalk - now Free
it can if you bring wire to front to engine bay and tab it?
Old 01-31-2014, 10:52 AM   #146
TheLaughingMan
I suppose it's possible, I haven't had any problems and you can read about my less-than-perfect experience up above and the cheap little socket I used.
Old 01-31-2014, 02:29 PM   #147
Boxer486
Drives: small
So how about wiring it to the brake lights?
Boxer486 is offline   Reply With Quote
Old 01-31-2014, 02:43 PM   #148
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by Silverdub View Post
To those complainimg about this not being switch all i have to say is just run an extra wire and a switch where you want it. As for the brightness it is very bright i can confirm that now that i saw what it looks like at night. Of course i wasnt expecting everybody to like this, this is The Internets afterall and we need some real haterz!
Or just wire the activation switch to the front fog circuit so that when your factory front fogs turn on, so does your rear. I'd require running much longer wires, but it wouldn't involve your tails at all.
^GT5 Replay Photo Mode^
Old 03-04-2014, 10:28 PM   #149
AdamBomb518
Stealth ***e
AdamBomb518's Avatar
So anyone that took off their light, how the hell did you do it with the stock muffler in place? I tried today but after 10 minutes of my hand squeezed up to removed the bolts, I gave up, ha. I figured it's easier just to drop the muffler to access everything. Is there a secret way I'm missing here? Nobody ever mentioned removing their muffler so I feel like there's something I'm missing, haha.
AdamBomb518 is offline   Reply With Quote
Old 03-04-2014, 11:53 PM   #150
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
I did it without removing the muffler. It's tough. Have to be careful blnot to break the light. The muffler is no big deal to remove. Put stuff(soap,oil,etc) on the hangers to make them slippery to more easily get them off.
DrDuquette is offline   Reply With Quote
The Following User Says Thank You to DrDuquette For This Useful Post:
AdamBomb518 (03-06-2014)
Old 05-28-2015, 01:01 AM   #151
exE36M3
So... after 3 months... getting the Traction Control and ABS light error
So I wired up the JDM rear brake/fog kit about 3 months ago. No problems since the install... until this week. I've been getting a traction control / ABS light on my dash.
After some fiddling, it looks like when I turn on the headlights (and on goes the rear light mod), the Traction Control / ABS light turns on.
I clipped the rear light mod wires to sever it from the circuit and the TC / ABS lights go off.
Are some light control modules just more finicky?
I'm going to try to rewire NOT off the parking brake circuit but off the license plate power and see how it goes.
exE36M3 is offline   Reply With Quote
Old 05-28-2015, 12:21 PM   #152
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
My front turn signals (which are switch backs) blink on and off now randomly, not sure if because of this install, or the Diode Dynamics Brake light as turn light module..either way. going to try to revert back to stock tomorrow and see if that fixes it.
The Following User Says Thank You to SkAsphalt For This Useful Post:
exE36M3 (06-09-2015)
Old 05-29-2015, 01:40 AM   #153
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
I have the Diode Dynamics Brake light as turn light module as well ad I just spliced into the module itself for the 12v signals. I believe red was for the running lights and yellow was for the brake lights if I remember correctly. Oh, and I snapped my tab on the light assembly lol. That thing is a SOB to remove, I thought I was being gentle until it just snapped lol. But with the bolts and everything in it, it still doesn't move so I'm not really worried about it.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
The Following User Says Thank You to Drakiv For This Useful Post:
SkAsphalt (06-01-2015)
Old 05-30-2015, 07:27 PM   #154
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
I just installed the ijdmtoy kit and it was a pain in the @$%. the socket is just not a good fit and the instructions were horrid. I referred to the instructions here for the most part. I didn't remove the fog light. I just drilled a hole laying under the car, took my time because as previously stated, the plastic is very brittle. I am happy with the results though. the provided led light provides the perfect amount of light in my opinion. I tapped all three wires directly to the three drivers side taillight wires.
fx1mark is offline   Reply With Quote
The Following User Says Thank You to fx1mark For This Useful Post:
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 01:19 AM
rear seats? EJ20 BRZ First-Gen (2012+) — General Topics 67 11-12-2012 07:15 PM
Rear Bumper Foglight kanundrum Cosmetic Modification (Interior/Exterior/Lighting) 2 06-08-2012 12:47 AM
215/40-17 front, 225/40-17 rear? ZDan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-21-2012 02:08 PM
