Old 01-28-2014, 05:35 PM   #1
SpeedR
First86 / boat thief
Drives: MKIV Supra
Wheel Directory: Rota Titan 17x9.0 +45
Love this setup very good service from wheeldude they have definitely have spent some time doing UX training.
17x9 Rota Titan -Hyper Black (5x100/e42/73) @ 17.8lbs
PilotSuper Sport 245/40/17 @ 23lbs
I got 40.9lbs total weight not sure where the .1 extra came from?
OEM17" wheel & tire combo= 41.4 lbs
This setup saved about .5 lbs per corner and gained a huge amount of grip for very little $.
Cost of the Titans with Christmas sale was about $700 shipped
Money I saved compared to rimes I was going to get got me this:
RaceCompEngineering "Yellow" Lowering Springs
Camberbolts for the front
2mm spacers (just in case I needed them on the front, I did not so I used them on the back for a little more poke).
Lifttime aliments to my specks at firestone.
SpeedR is offline   Reply With Quote
The Following 3 Users Say Thank You to SpeedR For This Useful Post:
Easy (05-24-2015), normancw (01-29-2014), SirBrass (02-04-2014)
Old 01-29-2014, 11:31 AM   #2
SpeedR
Drives: MKIV Supra
Originally Posted by flashburn View Post
Nice. I'm thinking about these same wheels in Gold for my WRB.
Were the Camberbolts actually necessary?
For the cost there a no-brainer your going to want a way to control camber.
Old 01-29-2014, 12:19 PM   #3
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Got a set of these in white for my SWP sitting in my garage. Waiting for weather to get a bit better over here.
Is this before you put the racecomp springs on?
Flat Black VW is offline   Reply With Quote
Old 01-29-2014, 03:38 PM   #4
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by fooddude View Post
Hmmm...I was expecting a 245 on a 9" to be a bit meatier lookin like others with 245 D2's or RS3's ...are the PSS's thinner than those other tires? It looks like a very slight stretch.
Regardless...sweet ride!
PSS have a rounded edge so it enhances that effect. I don't know about DIIs, but I hear RS3s run pretty wide. Even so, a 255 is more "fitted" to a 9" wheel anyway. My 2010 STi had 8.5" wide wheels and the 245 Dunlops had a slight stretch.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
crouchingpinoy (05-22-2015)
Old 01-29-2014, 08:28 PM   #5
SpeedR
Drives: MKIV Supra
The 245s have slight stretch the pics do not do it justice they look quit meatey.
If I had to do it again I would go 255.
the pics are with the racecomp springs on it, looks lower in person.
Personally I think this is a very good DD setup that can be fun at the track also.
The Sup is very fun and gives me the big HP fix I need every once in a while.
Old 01-30-2014, 12:40 AM   #6
Kakawate
Man-ape
Kakawate's Avatar
Drives: 2013 Buddy Club Scion FR-S
255/40 all day on 17x9 best bet. Love the way asphalt looks with hyper black.
I got grids in hyper black on my asphalt. Looking good bro!
Kakawate is offline   Reply With Quote
The Following User Says Thank You to Kakawate For This Useful Post:
SpeedR (01-30-2014)
Old 02-04-2014, 04:11 PM   #7
SpeedR
Drives: MKIV Supra
Originally Posted by SkAsphalt View Post
Where did you get these in hyper black from?
Weeeeeeeird, they are listed under STI but not under the FRS so I did not even know they had them! I would have ordered a set on the black Friday sale had I known!!!
I called and asked, wheeldude did not know they weren't on the web for the FRS so they added it after my call.
The Following User Says Thank You to SpeedR For This Useful Post:
shattered_memory (02-21-2014)
Old 03-22-2014, 11:53 AM   #8
Flat Black VW
Talking White on White: White Rota Titan 17x9 F+R on SWP BRZ
Finally got my wheels installed last night.
They are Rota Titans
17x9 Front and Rear
245/40-17 Bridgestone RE11-a Front
255/40-17 Bridgestone RE11-a Rear
Needed a 5mm spacer in front to clear the factory strut perches.
Will update with some better pictures when I get some soon. Needs to be washed bad.
The Following 5 Users Say Thank You to Flat Black VW For This Useful Post:
cactus (03-26-2014), finch1750 (09-20-2014), hmong337 (12-27-2015), SkAsphalt (03-23-2014), The Tengu (03-23-2014)
Old 03-22-2014, 02:23 PM   #9
jflogerzi
jflogerzi's Avatar
Not bad at all. Looks good
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 03-22-2014, 03:59 PM   #10
johnb831
johnb831's Avatar
Drives: SWP 2013 Subaru BRZ Limited
Looks really nice!!
johnb831 is offline   Reply With Quote
Old 03-22-2014, 07:27 PM   #11
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
What offset are the rims? You needed spacers front and rear?
ashtray is offline   Reply With Quote
Old 03-22-2014, 07:27 PM   #12
fa5tco
fa5tco's Avatar
Drives: 2013 Firestorm FRS
Is the 5mm spacer needed? or did you just use it for your peace of mind?
you still using the stock lug bolts or did you have to get longer ones?
fa5tco is offline   Reply With Quote
Old 03-22-2014, 07:59 PM   #13
Flat Black VW
Offset is 42. Only needed spacers in the front.
Old 03-22-2014, 08:00 PM   #14
Flat Black VW
Without the spacer it is way too close. No it doesn't quite touch, but it's not a safe clearance. I have seen others with 3mm spacers on the same offset and I will probably switch to 3s when I get some time.
Still using stock lugs.
Wheel Directory: Rota MXR 18x9.5 +38 jonbatz01 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 05-19-2020 02:57 AM
Wheel Directory: Rota Grid 18x8.5 +44 Cjymiller Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 09-05-2016 10:42 PM
Wheel Directory: Rota RKR 18x8.5 +38 / 18x9.5 +38 jsc1234 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 05-30-2014 10:06 PM
Wheel Directory: Rota RT5 17x9.0 +30 b-25 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-03-2013 02:21 PM
Wheel Directory: Rota GR-A 18x7.5 +48 pro_djke Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-03-2013 02:06 PM
