Old 01-29-2014, 08:04 AM   #1065
steve99
Drives: FT86
Originally Posted by jdcorbitt3 View Post
Hello Shiv
I am waiting for delivery of my OFH. Is it safe to run the E85 stage 2 tune with stock intake and exhaust?
John
Hi John,
have a look at this thread
Stock car on E85 stage 2 tune
http://www.ft86club.com/forums/showthread.php?t=56452
jdcorbitt3 (01-29-2014)
Old 01-29-2014, 09:27 AM   #1066
jdcorbitt3
jdcorbitt3's Avatar
Drives: 2013 red FR-S, OFT. 2000 Miata SE
I noticed in the above mentioned threads, they talk about the AF ratio being richer, but the number is higher than pump gas. Is because the ratio is in pounds and ethanol has more energy per pound?
John
jdcorbitt3 is offline   Reply With Quote
Old 01-29-2014, 09:42 AM   #1067
steve99
Drives: FT86
John
I am no expert but see here
http://www.brighthubengineering.com/...ir-fuel-ratio/
Gasoline: 14.7
Ethanol: 9
but you have a mix ie E85 and it varies maybe to E70 sometimes
My understanding is Gasoline has more energy content per litre than ethanol, but ethanol has a much higher octane rating than gasoline.
luckily these tuner's have sorted all this out and apparently this tune is good for anything from E60 to E85 given a bit of learning time.
Old 01-29-2014, 10:07 AM   #1068
Malt
Drives: 2015 WRX
Gasoline: 14.7
Ethanol: 9
O2 sensors read stoichiometry so it's not different between gas and E85 from a tuning standpoint. Also the thought that ethanol has a much higher octane value than gas is a myth. I'll post a reference when I find it.
EDIT: http://en.m.wikipedia.org/wiki/E85
It has an octane rating of 94 - 96
Malt is offline   Reply With Quote
Old 01-29-2014, 11:00 AM   #1069
steve99
Drives: FT86
"O2 sensors read stoichiometry so it's not different between gas and E85 from a tuning standpoint."
you would need different amounts of gas compared to ethanol or E85 to achieve stoichiometry ?, so it is kind of different
"Also the thought that ethanol has a much higher octane value than gas is a myth"
Well I suppose "much" is a subjective word , but pure ethanol (as opposed to E85 mix ) would have a higher octane rating that E85 ? which is kind of higher that 91-93 for gas
Old 01-29-2014, 11:23 AM   #1070
Malt
Drives: 2015 WRX
It's not different from a tuning standpoint. The O2 read how far from stoic the exhaust gas is. You are not going to see 9 as a reading on the O2 sensor when using E85, you'll see 14.7, which was my point.
I assumed that most people reading the word "much" would take that as difference greater than 2 octane points. Stations often label their E85 pumps as 105 or even 115 octane. That is not an accurate number and is misleading, which is why there is a common misconception about the octane level of E85.
Old 01-29-2014, 11:33 AM   #1071
Cross
It's the Mad Cow
Cross's Avatar
Look AFR and Lambda are often confused.
Let me put it to you like this, a Wideband O2 reads in Lambda first then converts that to AFR via a conversion calculation based on the gas. in Lambda 1.00 is dead on Stoich be it gas or E85. (All O2's basically do, just with most widebands they will display numbers in Lambda most of the time)
Because this calculation is done to the Lambda number the only real change to make a Wideband read E85 vs Gas AFR levels is to the calculation after the Lambda base is read. This means 14.7 basically = 1 Lambda and Lambda does not care if its gas or E85 its still the same point it reaches 1.
So long story short the AFR you are seeing does not have to be changed because the calculation is still based off Lambda. You are reaching the correct levels and AFR is just a calculation added on top because people seem to be to lazy to learn Lambda.
[ame="http://en.wikipedia.org/wiki/Air%E2%80%93fuel_ratio"]Air–fuel ratio - Wikipedia, the free encyclopedia[/ame]
The Following 2 Users Say Thank You to Cross For This Useful Post:
FearBoy (03-05-2014), Malt (01-29-2014)
Old 01-29-2014, 02:03 PM   #1072
Kodename47
Kodename47's Avatar
Drives: UK GT86
Ideally you'd want to output the O2 sensor as lambda for E85 useage, then use the calculation above to work out the actual AFRs. There is also a table to adjust the reading of the stock O2 sensor.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-29-2014, 09:18 PM   #1073
Vmax911
Drives: WRB BRZ
Hey guys, I've done a few pulls with 1.42, and notice my AFR is a bit leaner than it was stock. When I logged stock rom I was 11.9-12 WOT. With this tune I seem to be around 12.5 or so at WOT. Just have a drop in, test pipe, and catback. I'm also around 5200-5400ft. Would any of these cause a slightly lean condition. Is the AFR anything to worry about?
http://www.datazap.me/u/vmax911/142-...zoom=4204-4426
Multiple pulls here
http://www.datazap.me/u/vmax911/142-...g=0&data=1-2-9
Thanks for any helpful feedback!
Vmax911 is offline   Reply With Quote
Old 01-29-2014, 09:34 PM   #1074
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Multiple pulls here
Yes, you will run a little bit leaner than most due to your altitude and the fact that you aren't hitting the same engine load levels (g/rev) as those at sea level. Totally normal and expected.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Vmax911 (01-30-2014)
Old 01-29-2014, 10:57 PM   #1075
Vlady
Vlady's Avatar
Drives: Argento Scion FRS
Hey all just wondering how you are posting your datalogs on here. I am clueless!
Vlady is offline   Reply With Quote
Old 01-30-2014, 09:03 PM   #1076
TM
TM's Avatar
Drives: DGM BRZ 6MT
Shiv posted a tutorial here.
After that, you can also export it and import it into Datazap to view and share with others.
TM is offline   Reply With Quote
Old 01-31-2014, 04:12 PM   #1077
sprintamx
I posted this in the 1.5x .dev thread, but maybe it's better to post it here (I'm still learning to work the OFT and OFT manager software):
Would someone mind briefly explaining--or pointing me to a thread--the file auto-generate feature? I know that the .bin files were released today, and that this may now be academic. But, I did try--unsuccessfully--to load the 1.5x .dev file. I erased the .bin files I had on the OFT, but kept getting an error message every time I tried to load the .dev file in the OFT database management section: "File size incorrect."
Obviously I didn't / couldn't load the .dev file and so I don't know what I should have expected to see on the OFT during the "write" process in the car.
So, either I did something "wrong" or there's another problem I don't know how to identify / diagnose.
Thanks in advance.
sprintamx is offline   Reply With Quote
Old 01-31-2014, 04:19 PM   #1078
steve99
Drives: FT86
Thanks in advance.
sounds like you did everything correct, deleting all bin tunes then loading dev tunes. probably have to ask the OFT guys.
looks like they removed .dev download link to 1.5 tunes, sorry can't help
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
