Old 01-28-2014, 04:45 PM   #1051
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Hah my bad
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 01-28-2014, 05:26 PM   #1052
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
I think @shiv@vishnu should organize a couple beginner tuning classes maybe once every week or so, in the evenings. I'd pay good money for that. And he could probably knock out tuning some of his remote tunes
86-tundra is offline   Reply With Quote
Old 01-28-2014, 06:28 PM   #1053
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
Originally Posted by Malt View Post
Did you load the stock Rom back on the ecu from the OFT before the dealer flashed the new Rom?
Yes. Flashed stock rom before i went the dealer.
Sent from my XT912 using Tapatalk
Terrapin77 is offline   Reply With Quote
Old 01-28-2014, 06:33 PM   #1054
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Perfect. Connect oft to OF Manager with wifi. Erase data. Then reinstall as if it were new
Shiv@Openflash is offline   Reply With Quote
Old 01-28-2014, 11:13 PM   #1055
Terrapin77
Terrapin77's Avatar
Already got the new map flashed. Just wanted to make sure I had the correct steps before i proceeded to flash a new map. I didn't want to brick the OTF since the correct steps aren't easy to find. I'm sure it has been posted on the forum but searching for specific topics on this forum doesn't work all that well.
Old 01-28-2014, 11:23 PM   #1056
jflogerzi
jflogerzi's Avatar
wifi? OFT can use wifi?
Old 01-28-2014, 11:26 PM   #1057
Malt
Drives: 2015 WRX
No, shiv is just suck in Apple lala land with his macbook pro. You just need an active internet connection.
Malt is offline   Reply With Quote
Old 01-28-2014, 11:28 PM   #1058
jflogerzi
jflogerzi's Avatar
haha okay. I thought I missed something!
Old 01-29-2014, 02:47 AM   #1059
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
I did a log with OFT 1.42 stage 1 map
maf is recalibrated slightly by my self.
http://www.datazap.me/u/yobiwan/oft-...-6-10-11-13-16
I think AFR under wot is bit rich . but its not post learned. so after few days. I'll do again.
besides that, very satisfied to map. smooth, torquier.
Yobiwan is offline   Reply With Quote
Old 01-29-2014, 05:05 AM   #1060
s2d4
s2d4's Avatar
Originally Posted by Yobiwan View Post
I did a log with OFT 1.42 map .
Pretty sure it isn't, the stock o2 sensor reads lower but is actually closer to 12.5 AFR
The Following User Says Thank You to s2d4 For This Useful Post:
Yobiwan (01-29-2014)
Old 01-29-2014, 05:33 AM   #1061
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Hi! your WOT AFR looks better than mine on the same 1.42 stage 1 map.
What is your ECU CAL ID?
Here is my log with some wot pulls if you like to compare:
http://datazap.me/u/ondreiko/1-2-3-4...=1-3-9&mark=66
Let me know your MAF calibrating method, if possible.
In addition: And one more question - your log shows throttle position at 80 all the way - did you press the pad to the floor?
Everything looks like WOT pull, except your throttle position.
Last edited by Ondreiko; 01-29-2014 at 06:08 AM. Reason: forgot something+spelling correction
Ondreiko is offline   Reply With Quote
Old 01-29-2014, 06:01 AM   #1062
s2d4
s2d4's Avatar
btw, your perrin inlet tube doesn't appear to be doing you any favours on the MAF.
It seems quite a lot more turbulent than @Ondreiko.
Old 01-29-2014, 06:56 AM   #1063
jdcorbitt3
jdcorbitt3's Avatar
Drives: 2013 red FR-S, OFT. 2000 Miata SE
Hello Shiv
I am waiting for delivery of my OFH. Is it safe to run the E85 stage 2 tune with stock intake and exhaust?
John
jdcorbitt3 is offline   Reply With Quote
Old 01-29-2014, 07:55 AM   #1064
Yobiwan
Yobiwan's Avatar
I know nothing about tune. Im just trying to understand basics.
There is yike's spreadsheet for closed loop maf scale.
Jamesm' screencast is very helpful
http://www.ft86club.com/forums/showthread.php?t=53773
Actually Im ecutek user, so I copied map values to make my file.
Maybe I forgot something related to throttle value. So 80% is wot for me
Your log is fine to my eyes =)
The Following User Says Thank You to Yobiwan For This Useful Post:
jamesm (01-31-2014)
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
