Old 10-12-2013, 12:43 PM   #15
Nissanfan
Drives: subaru brz
guys? lol, if you're gonna sit there, put every single point by hand, you got waay too much time to spare
http://www.subaruxvforum.com/forum/i...ips-hacks.html
http://fixmygps.info/forum/showthrea...23607#pid23607
2013 BRZ Limited 6speed Manual
Nissanfan is offline   Reply With Quote
The Following 2 Users Say Thank You to Nissanfan For This Useful Post:
robot (10-14-2013), TIE Pilot (10-29-2013)
Old 10-13-2013, 05:40 PM   #16
PMok
Codename: Stitch
PMok's Avatar
So if I am reading this right, you found a way to download existing alert point data and add it to the SD card? Have you tried it and found it to work on the BRZ navi?
Old 10-14-2013, 02:04 PM   #17
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
This appears to be awesome. I may try it to confirm.
robot is offline   Reply With Quote
Old 10-15-2013, 05:26 PM   #18
Nissanfan
Drives: subaru brz
yes, exactly right. Redlight/Speedcameras is what i have put on SD card.
Old 10-16-2013, 08:06 PM   #19
Zoti
Drives: BRZ Limited 6MT
The files seem to be missing from the destination on that forum. :-(
Zoti is offline   Reply With Quote
Old 10-19-2013, 06:04 PM   #20
robot
I was going to come post the same thing.
As I understand it I have to download the trapster POI's and convert them to Primo format. I got the trapster POI's in garmin format just fine, but the (sketchy Russian) conversion software is nowhere to be found.
EDIT: I looked around again...I think the POI's from this place will work: http://poiplaza.com/index.php?p=dc&c=49
EDIT EDIT: there is one on page 5 called "fix speed cam" (2013) and one called "speed traps" (2010)
AND: page 10 has "redlight and speedcam" (2013)
Both of these seem to have been updated in 2013. So, that's good news. I have to run some errands, but I may try this later today.
AND: if you look at the map it seems that there aren't all that many POI's for all areas of the US (other countries might be different).
I'll have to find an alternative conversion program to get the trapster stuff into iGo Primo format.
Old 10-22-2013, 12:10 AM   #21
robot
I gave up. If someone figures it out let me know.
Old 10-29-2013, 06:24 AM   #22
Nissanfan
Drives: subaru brz
i'll write something up this weekend, maybe that'll help
The Following User Says Thank You to Nissanfan For This Useful Post:
DoomsdayJesus (11-04-2013)
Old 11-04-2013, 06:07 PM   #23
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Please do, this could be seriously awesome.
DoomsdayJesus is offline   Reply With Quote
Old 11-11-2013, 06:40 AM   #24
Nissanfan
Drives: subaru brz
sorry guys, didn't forget. I started on a write up in my spare time on friday, but gotta finish up working on my daily driver beater before snow comes in to Chicago. Will post step by step POI as soon as I finish it.
Old 01-28-2014, 12:41 PM   #25
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
bump. update? @Nissanfan
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 09-25-2014, 09:48 PM   #26
dinoniel
Hey guys sorry if this is bumping an old thread but I saw it ended a bit abruptly and I wanted to share how easy this is. This is on a 2014 Subaru BRZ Limited:
First off here is the only link you need
http://www.subaruoutback.org/forums/...am-alerts.html
A couple of the steps below are copied and pasted directly from there.
1. With car off eject SD card (alternatively if you want the radio on while you do this for some reason go through the menu and eject the SD card properly don't just pop it out).
2. (Optional but recommended) Make a back up of your SD card. I used disk utility on a mac to make an image of the card. You can also use the HDD Raw copy tool that is on the link, I would not be able to help you as I did not need it.
3. Download the file at http://fixmygps.info/forum/showthrea...23614#pid23614 (If you are in the US of course). This is a zip which when unzipped makes a folder called "speedcam"
4. Rename your speedcam folder on your SD card to "speedcam_OLD" (navigation/content/speedcam) and copy the one you downloaded to this content folder.
5. To enable. Go to Map>Menu>More>Settings>Sounds and Warnings> (scroll down) Alert point settings (tick box) and enable alert types
The end result is this:
dinoniel is offline   Reply With Quote
The Following 2 Users Say Thank You to dinoniel For This Useful Post:
a_dee (07-17-2015), KelvinBRZ (09-27-2014)
Old 09-28-2014, 10:11 PM   #27
PMok
Codename: Stitch
PMok's Avatar
that's awesome that someone got this to work!
EDIT: dinoniel sent me the ZIP file that you need and I am hosting it on my site for others to download as well.
http://86drive.com/wp-content/upload...-speedcams.zip
also, am I correct in assuming that if you replace the speedcam folder you will lose all your previously set custom alert points? (which would probably be fine for the 99% of people who never used it anyways but I have a few custom points set.)
Last edited by PMok; 10-01-2014 at 12:43 AM. Reason: added link to hosted ZIP file for download
Old 09-30-2014, 12:37 PM   #28
dinoniel
PMok check your email
The Following User Says Thank You to dinoniel For This Useful Post:
PMok (10-01-2014)
alert, brz, fujitsu, navigation, warning
Philippines on HIGH ALERT vs. china's INVASION phenoyz Off-Topic Lounge [WARNING: NO POLITICS] 46 12-11-2013 07:30 PM
protecting the pinch weld lifting points midnitz Scion FR-S / Toyota 86 GT86 General Forum 1 02-08-2013 10:36 PM
Car Jacking up Points? J-Money Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-21-2013 03:55 PM
Installed Curb Alert system sesmls BRZ First-Gen (2012+) — General Topics 17 07-27-2012 02:26 PM
