Old 01-27-2014, 06:23 PM   #15
andrew20195
Drives: 2013 Subaru BRZ
Originally Posted by Mister View Post
My steering wheel has started to peel at about the 9 o'clock position. At first it just started to bubble a bit, but it has slowly been growing, and is now about the size of a U.S. quarter.
Do you use lotion on your hands, or have you used leather cleaner on the steering wheel in the past? In my experience the cheap bonded leather they use in most cars doesn't like being exposed to certain chemicals.
andrew20195 is offline   Reply With Quote
Old 01-27-2014, 09:33 PM   #16
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
In for pics
Old 01-27-2014, 10:35 PM   #17
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
^^This.
In my case, I was working in the shop of a printed circuit board manufacturer for a few months to cover a personnel shortage, and the one constant thing I was in contact with daily was copper dust. I had a wheel replaced under warranty as it was only 5 months old.
It finally became apparent when I saw the steering wheels of some of the other workers that performed the same operations as I did at the facility with the same issue.
CircuitJerk is offline   Reply With Quote
Old 01-27-2014, 11:22 PM   #18
charged86
charged86's Avatar
Over the weekend I brought the car in for the 10k miles maintenance (oil change/tire rotation) and had them look at that along with a few other warranty related items.
The dealer said that the steering wheel was a "wear item" so it was not covered under the comprehensive warranty, but that they would replace it this time out of good will. A little annoyed by this, but other then that they have treated me with only respect and have taken very good care of my car, I have been in there many times:
1. Chirping pump
2. New transmission
3. Drivers side window seals
4. Passenger window switches
5. Chirping (again)
6. Steering wheel
I am wondering if anyone else has ran into this? Usually I am overly cautious to make sure my hands are clean before I drive so I do not muck up the interior, and am a bit concerned they are saying it is a wear item. I've had cars with a 100k-200k on them without a damaged steering wheel.
what was the fix for the driver side window seal? mine window pinches the dang seal every time
Old 01-28-2014, 07:57 AM   #19
Mister
Mister's Avatar
Drives: Firestorm FRS
I used a very diluted Simple Green solution on it (<40:1). The dealer got it covered in grease and oil during my last oil change, which they knew about and gave me a professional detailing when I complained, but I used this until I could bring it in for the cleaning, it tends to work very well as a degreaser. I have used Simple Green on cheap leather before like this without issues, but you are may be correct. Although in terms of cleaners it is extremely mild, especially when diluted. I've used it on my couch at home after parties and to clean up after my fiancé's senile cat, and it is an extremely cheap bonded leather.
They are replacing the seal, I am not sure if they are making adjustments to the window itself to prevent it from happening again though. Fingers crossed?
Originally Posted by sirsol66 View Post
Call corporate, I know for a fact that a few people have gotten theirs replaced under warranty. The latest one I saw pop up had 18,000 miles on it, so you should be covered.
They are replacing it, they just said they were not doing it under warranty? . I will be a little MORE OCD with the new one I guess haha. But I already tend to keep my car excessively clean, and usually try to avoid eating in the car so I don't get grease or stickies on the wheel and shift knob.
Sorry that I have not posted picks yet. I went straight from work to grad school, and then was doing homework the rest of the night so it slipped my mind.
Mister is offline   Reply With Quote
The Following User Says Thank You to Mister For This Useful Post:
charged86 (01-28-2014)
Old 01-28-2014, 12:49 PM   #20
sirsol66
Drives: 2013 FRS- Hot Lava
Not under warranty, as in the dealer is good-willing the replacement? Or as in you're paying for it out of pocket?
sirsol66 is offline   Reply With Quote
Old 02-01-2014, 05:15 PM   #21
ShaunNeutron
ShaunNeutron's Avatar
Drives: BRZ Limited Manual CBS
My steering wheel started bubbling and peeling as well, but in the 12 o'clock position. I asked about a replacement and was given the wear and tear line. Even with turning, my hands barely ever hit that spot so I do not believe it to be my fault.
ShaunNeutron is offline   Reply With Quote
Old 02-02-2014, 04:12 PM   #22
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
pics? O.o
The Following User Says Thank You to Bonburner For This Useful Post:
Carticular (05-15-2014)
Old 02-05-2014, 04:54 PM   #23
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Yeah, makes sense ..... wear and tear items. Tires, brake pads, windshield wipers, batteries .... and add to that list: steering wheel. What a croc. Toyota must be pretty hard up to nickel and dime everyone. Congrats that you got it replaced .... for free ... as it should be.
Braces is offline   Reply With Quote
Old 02-05-2014, 05:39 PM   #24
frslee
Just drive it
Drives: 13' FR-S
I just noticed that outer bottom of the steering is starting to peel a bit. I barely put my hands underneath but recently noticed while turning the wheel.
frslee is offline   Reply With Quote
Old 02-08-2014, 11:39 AM   #25
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
Mine also started to fade a bit at somewhere around 08:00, also because my jeans keep rubbing it when I go in/out from the car.
A bit of first world problem since I don't want to change the seating/steering position.
gzpermadi is offline   Reply With Quote
Old 02-08-2014, 12:25 PM   #26
Ocala FR-S
Ocala FR-S's Avatar
Drives: 2013 FR-S AT Argento
Originally Posted by CircuitJerk View Post
^^This.
That does not seem healthy my friend. Was the personnel shortage due to the mysterious deaths of employees?
Ocala FR-S is offline   Reply With Quote
Old 02-08-2014, 10:50 PM   #27
CircuitJerk
Pull my finger...
LOL No, vacation coverage... Engineering would often fill in since we all knew how to run the CNC machines, and we wrote the programming...
After drilling the copper clad laminates they would have to be deburred.
Didn't always wear gloves. Really, exposure was nominal.
Old 02-08-2014, 11:52 PM   #28
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Sucks to hear about the steering wheel, good thing it is getting fixed.
Chirping isn't an issue, so no matter how many times you fix it, it'll come back since it is normal.
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 02:23 PM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 06:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Different Steering Wheel?- NOT? BRZfan Cosmetic Modification (Interior/Exterior/Lighting) 10 03-07-2013 09:01 PM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 12:16 AM
