Old 01-22-2014, 12:54 PM   #113
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Did you guys replace the OEM radiator too? Saw the thread with the supercharger intercooler and the oil cooler but didn't seem to see anything about the radiator.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 01-22-2014, 12:55 PM   #114
CSG Mike
CSG Mike's Avatar
Not yet; that's next.
Anthonytpt (01-27-2014)
Old 01-22-2014, 03:17 PM   #115
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
For now; it won't be here much longer. We want the temps to be lower; that's what this engine likes.
What radiator will you be going with?
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 01-22-2014, 04:06 PM   #116
CSG Mike
CSG Mike's Avatar
It's strictly a prototype at the moment; it's a brass core copper finned unit. It's a bit heavier than stock, but isn't any aftermarket oversized radiator?
This will allow the radiator to pull heat out of the coolant with greater efficiency than an aluminum radiator.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
Anthonytpt (01-27-2014), Frost (01-22-2014), RehabJeff86 (01-23-2014), smbstyle (01-22-2014)
Old 01-24-2014, 02:59 AM   #117
suaveflooder
this thread has so much win!
suaveflooder is offline   Reply With Quote
Old 01-27-2014, 04:44 PM   #118
CSG Mike
CSG Mike's Avatar
Yesterday, we did some stress testing.
Short results:
- Tripledigit speeds were sustained for 10+ minutes on a closed course (test ovals are nice, aren't they?). Oil temps held steady. Coolant temps were a bit high for our liking; they weren't at dangerous levels, but this engine definitely prefers to have coolant closer to 180F than the 200F+ we were seeing. Intake temps stabilized at about 105F at sustained WOT, compared to a 65F ambient.
-- In other words, all the cooling systems worked, but we want our coolant temps lower. Perfect, since we're going to be putting in the latest prototype radiator.
- On track, we stress tested the Winmax W4 on stock brakes, with heat cycled RS3s, and the supercharger. Lets just say, for FI cars, you need to have full race pads. The heat reading was off the scale (literally) on the laser temperature gauge when we pulled off track.
- We also tested the latest CSG-Spec SRC prototype. I believe we've found a new best valving, particularly since the street and track damper settings are now one and the same!
The Following 9 Users Say Thank You to CSG Mike For This Useful Post:
*LongFella (01-27-2014), amram (03-30-2014), Anthonytpt (01-27-2014), MyRx (01-27-2014), normancw (01-27-2014), ShoShin (01-28-2014), SkAsphalt (01-28-2014), Sonolin (03-07-2014), zoth (08-29-2014)
Old 01-27-2014, 04:46 PM   #119
OrbitalEllipses
Drives: Attitude
I would never FI without BBK. Stock brakes don't have the heat capacity for repeated braking from the speeds you see with FI.
Old 01-27-2014, 04:59 PM   #120
CSG Mike
CSG Mike's Avatar
I'd agree, but we're doing this strictly for the sake of testing and data. We already know they'd cook, but wanted to see WHEN they would cook.
Old 01-27-2014, 05:00 PM   #121
CSG Mike
CSG Mike's Avatar
Originally Posted by normancw View Post
Thanks Mike! A couple of questions:
  • What did the oil temps reach?
  • Is having coolant closer to 180F better for performance and/or reliability?
It stabilized at about 235F. Remember, this was a LONG time of sitting at 6000+ RPM.
Better for performance, probably negligible effect on reliability.
Old 01-27-2014, 07:05 PM   #122
phastafrican
phastafrican's Avatar
Drives: 2013 Raven Scion FR-S
Great feedback
phastafrican is offline   Reply With Quote
Old 01-27-2014, 09:55 PM   #123
Boxer486
Drives: small
Just trying to decipher your statement more clearly. My chats w/ Essex suggest the sprint kit should manage heat for most applications road and track w/ the right pads. Your testing seems to be more along the lines of endurance so I presume that would more closely suit their endurance kit and brake cooling solution. In other words, the sprint kit w/o duct cooling would be insufficient for your testing, am I getting that right?
Boxer486 is offline   Reply With Quote
Old 01-27-2014, 10:11 PM   #124
CSG Mike
CSG Mike's Avatar
We were testing with the stock calipers and rotors, not the Sprint kit.
But yes, we will be upgrading, we already have data that suggests that we will overwhelm the Sprint kit's capacity for our specific application. I suspect that won't be the case for most people. We're already using 800C race pads.
Old 01-27-2014, 11:36 PM   #125
Boxer486
Drives: small
Thanks, that's what I wanted to know. I'm not surprised after reading Edmunds had melted the seals on the stock calipers w/ base power.
Old 01-28-2014, 01:08 AM   #126
CSG Mike
CSG Mike's Avatar
That... happens to virtually every stock caliper, regardless of car
CounterSpace Garage (CSG) juliog User/Vendor/Sponsor Reviews, Feedback, Comments 11 10-21-2013 04:08 PM
Track day giveaway by CounterSpace Garage CSG Mike Southern California 43 04-19-2013 11:12 AM
CounterSpace Garage forwallblakmail User/Vendor/Sponsor Reviews, Feedback, Comments 0 04-12-2013 04:31 PM
CounterSpace Garage BRZ 2:00 lap at Buttonwillow 13 CW CounterSpace Garage Tracking / Autocross / HPDE / Drifting 11 03-07-2013 10:07 PM
CounterSpace Garage A++++ Asphalt~86 User/Vendor/Sponsor Reviews, Feedback, Comments 2 01-29-2013 01:18 AM
