Old 01-25-2014, 12:59 AM   #43
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Try narrow size 9 feet. I still can't reliably reach the gas from the brake without my foot slipping off the brake pedal.
It's more about my feet being narrow rather than the size.
^GT5 Replay Photo Mode^
Old 01-25-2014, 03:57 AM   #44
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Originally Posted by Rampage View Post
What was your solution to the pedal stopper issue that @Jeff Lange mentioned? Or is it a non-issue?
I am lucky enough to work in a company with an F1-standard workshop (literally), I used some fancy 3M helicopter tape : http://www.3mdirect.co.uk/p-2893-3m-...91cm-roll.aspx
I added just enough to have a tight assembly even without the pin in place.
Guillaume is offline   Reply With Quote
Old 01-25-2014, 04:02 AM   #45
fatoni
if its an aesthetic thing im a little confused since i dont know how often you would be looking down there. if its a function thing, i never had the issue with the brz. i just bent the pedal in my miata to get the feel right. for some reason the miata is the only car where it felt odd to me.
Old 01-27-2014, 05:16 AM   #46
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Okay so a quick feedback on this wider pedal...
Like I said, I was fine heel-and-toeing with the stock pedals. Not the best set-up I got to drive, but it was OK...
Now I don't know if it's just me, but with the rather steep angle my ankle has to take, slippery wet shoe soles would make the whole process a lot trickier. I had one or two moments where things didn't go as planned because my foot slipped.
Anyway, the wider pedals is a lot safer for heel-and-toe with wet shoes. With the same move as with the stock pedal, you do cover a greater area of the gas pedal. Definitely feels more sure-footed.
The Following User Says Thank You to Guillaume For This Useful Post:
SirBrass (01-27-2014)
Old 01-27-2014, 05:21 AM   #47
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
That's really good to hear. It sounds ridiculous but my feet don't turn inwards very far (anatomically speaking), and the rotation I get is totally outwards facing (as in inner ankle against a wall if you were facing one) - probably from all the rock climbing and other stuff I've been doing haha.
leicaboss is offline   Reply With Quote
Old 01-27-2014, 06:45 AM   #48
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I have the same problem, which is why I heel toe "backwards" - my heel is on the brake and my toes blip the throttle. It works well for me and it gives me more confidence when getting on the brakes hard and downshifting.
EDIT - After actually paying attention to what I do, it's more like the left side (inside) of my right foot modulates the brake pedal while I blip the gas pedal with the left side (outside) of my foot.
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 01-29-2014, 09:41 AM   #49
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Would anyone happen to have a picture of the back side of the 78101-20150 pedal?
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 01-29-2014, 09:42 AM   #50
Guillaume
Guillaume's Avatar
Drives: Exige S 240
On the previous page (in the post I linked you in the other thread).
BRZNutt (01-29-2014)
Old 01-29-2014, 02:19 PM   #51
BRZNutt
BRZNutt's Avatar
Cool, that's what I thought. I just don't understand what is this stopper that is supposedly missing on the 78101-20150 pedal? Looks to be there in the picture above?
Old 01-29-2014, 02:37 PM   #52
frslee
Just drive it
Drives: 13' FR-S
Cusco works fine, but just a bit expensive.
frslee is offline   Reply With Quote
Old 01-30-2014, 08:21 AM   #53
Guillaume
Guillaume's Avatar
Drives: Exige S 240
The problem is that the housing in the new pedal is a little too big for the cylindrical beam of the throttle itself. Like 2mm maybe. So you have to find a way to fill that. I used helicopter tape, others used something else.
BRZNutt (01-30-2014)
Old 01-30-2014, 08:48 AM   #54
BRZNutt
BRZNutt's Avatar
Thank you so much! Sorry to be such a pain with all the questions. You have been such a big help with this, I owe you a beer if you are ever in the states...
I ordered mine last night. Building up the diameter of the throttle shaft should not be a problem at all. Thanks again for the help!!
The Following User Says Thank You to BRZNutt For This Useful Post:
Guillaume (01-30-2014)
Old 01-30-2014, 09:47 AM   #55
Guillaume
Guillaume's Avatar
Drives: Exige S 240
No worries man, that's what a message board is for
For further help, you might want to check this thread, on the French speaking GT86 board : http://gt86france.forumpro.fr/t923p45-talon-pointe
The pictures alone could prove helpful. If you run into trouble when installing, don't hesitate to PM me or something.
Old 01-30-2014, 12:42 PM   #56
D4S
Probably Watching F1
D4S's Avatar
Drives: 10 Series FR-S 6MT
I've found that the shoe you're wearing helps with heel toe as much as the pedal.
I have a pair of speed cats that refuse to touch the throttle because the sole has a weird shape.
A pair of chuck taylors do wonders since the wall is solid and little ankle twisting is required.
Plus it's one of those rare shoes with a thick sole and great pedal feel. Also try the Onitsuka Serrano.
D4S is offline   Reply With Quote
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
