#15 |
Great White
Drives: 2013 Whiteout FRS
Just ordered my radiator, fans, hoses, and shroud, along with the FBM Oil Cooler that are getting installed with my FBM Turbo Kit on Wednesday! I can't wait!
| The Following User Says Thank You to Sterz For This Useful Post: | FullBlown (01-26-2014) |
#16 |
My FB shroud, fans, revised downpipe, and FB radiator are going in on Monday as well!
I'll install an oil cooler in a bit. I have to sell my Robispec Radiator/oil cooler to pay for the oil cooler. |
#17 |
Drives: 2013 MT Asphalt FRS
#18 |
in orbe terrum non visi
Drives: violent
Are you planning on adding this as an option to the base turbo kit?
#20 |
Drives: Scion FRS
#21 | |
I don't think the oil/water cooler like the Robispec is a bad idea at all. Millions of OEM cars have similar dual purpose radiators. I think as long as it's built well, it's actually a better, more compact solution. Less to buy, less to mount, less to go wrong, more effective. For NA cars or bottom-mount turbos, I still think the Robispec is best product for both coolant and oil cooling. Unfortunately the Robispec is much thicker than stock, and moved the fans back and killed what little clearance is there, causing my fans to melt. Going with all Full Blown stuff now, as it's proven to all work together. When I can afford it, I'm getting the FB oil cooler kit ASAP |
#22 | |
Drives: Scion FR-S
#23 |
That's true, but a small hole in anything can be bad. Element Tuning's car caught on fire because of a pinhole leak in the radiator, causing a blowup.
#24 |
Drives: 2013 SWP BRZ Limited
Damn LJ always stepping it up a notch above competition.
#25 |
Drives: violent
Cold oil is bad too dont forget. Integrated coolers bring oil temps up faster and those of us in cold climates with a separate oil cooler would never get up to temp.
#26 | |
Drives: STi
All you need is a slimmer setup. Few cm shall do the job. Sent from my SM-N9005 using Tapatalk |
#27 |
No way the Robispec was going to work. It shifted the fans back towards the engine. The FB kit already comes with slim fans because there's very little clearance, and with the Robi, the back of the fans were literally 1mm from the downpipe, and 1/2'' from the header collector.
The FB slim fans both died on the dyno within a few minutes. Even slimmer fans would still be too close as things were with the Robi. The FB radiator is designed so the clearance is the same as stock, the thicker portion is forward, and with the extra clearance from that, and the revised downpipe, I should be good to go. My clearance and overheating probs should be gone, especially now with the better Spal fans and shroud. |
#28 |
Drives: 240sx
How many cfm are those fans? Does the shroud for on the robi spec radiator?
| Spal Fan Shroud & Koyo Radiator | Carolina Dyno | Forced Induction | 64 | 12-14-2016 08:38 PM |
| FBM Aluminum Radiator $279 shipped | FullBlown | Engine, Exhaust, Bolt-Ons | 0 | 01-06-2014 05:40 PM |
| Aluminum radiator install and impressions | Tye300 | Engine, Exhaust, Transmission | 15 | 10-28-2013 01:52 PM |
| Product Release! Mishimoto Peformance Aluminum Radiator for Scion FR-S / Subaru BRZ! | Mishimoto | Announcements, Contests, Giveaways | 1 | 10-01-2013 11:44 AM |
| BRZ STI front under spoiler and 17" aluminum wheels released in Japan | yajin | BRZ First-Gen (2012+) — General Topics | 99 | 05-31-2012 06:09 PM |
