Old 01-19-2014, 07:35 AM   #309
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Originally Posted by 86•BRZ View Post
have you still not decided on wheels?!
ahahah.
Yeah and No....
So many options :S... so little money.
So it's always going to be the lightest for the cheapest... which always comees back to these.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 01-19-2014, 08:22 AM   #310
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Originally Posted by DriftEightSix View Post
ahahah.
Yeah and No....
You're in AUS as well, if you do get them go through Autotechnik in Sydney, i got mine delivered to WA for $1600 incl Kyo-Ei hub rings.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 01-20-2014, 02:07 PM   #311
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Were these ever made/available in a 9" +30 or +25??
+30 would look nice... seeing how it still looks slightly sunk-in with +35's. +30 to +25 would have more lip too I bet (but at the same time might be only be able to fit 225's..and not 245's anymore..I could be wrong though)
fooddude is offline   Reply With Quote
Old 01-20-2014, 02:33 PM   #312
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Do you know what offset actually means? the wheel is still the same width so tyre choices will be the same all your doing is moving the wheel out more by changing where it contacts with the hub.
A 0 offset means the wheel attaches to the hub at dead center of the wheel, a positive offset is more toward the wheel outer edge and a negative is further towards the wheel inside edge.
Build thread
Old 01-20-2014, 05:50 PM   #313
fooddude
To be more clear.. I meant 245 might be harder to fit under the fender without rubbing issues with a lower 30+ to +25 offset (as compared to the already done +35)
Old 01-21-2014, 06:25 AM   #314
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Ahh ok, and nah with those offsets the wheel overall would be moving outward so no rubbing issues just a lot of poke, tyre size won't have much affect on the poke as a 225 will still have to end at the same point at a 245.
Build thread
Old 01-23-2014, 02:17 PM   #315
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
I was really looking for this width to get that small lip and concave look.
However I really dont want to do coils or slam super hard.
Looking at Eibach pro line
with 225/40?
Anyone have a pick similar to this? I'm not looking to get a super meaty look
Edit: also would this need camber bolts?
calmtigers is offline   Reply With Quote
Old 01-23-2014, 03:19 PM   #316
loogs
Drives: on cruise control
with 225/40?
if youre gonna go with the 17x9, do 225/45/17. it will look a million times better than the 40 and still give you pretty good performance
loogs is offline   Reply With Quote
Old 01-24-2014, 03:24 AM   #317
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
and you'll need camber bolts, even the +45 poke
86•BRZ is offline   Reply With Quote
Old 01-26-2014, 12:41 AM   #318
jaydee_do_work
jaydee_do_work's Avatar
Drives: 13' Whiteout FR-S
I'm running a 235/40 up front.
245/40 in the rear. they look a little sunk and I'm thinking of adding a 10 mm spacer. or maybe an 8 mm. I wanna keep my fenders stock
jaydee_do_work is offline   Reply With Quote
Old 01-26-2014, 07:27 AM   #319
DriftEightSix
Pegasus White
Drives: 86
how low are you? & how much camber?
Old 01-26-2014, 08:02 AM   #320
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
The answer will be very..
Old 01-27-2014, 02:32 PM   #321
Squishy86
Squishy86's Avatar
Drives: Your Car
Excuse the little girl putting away her shopping cart. I was getting groceries.
Tires are 245/40 square Hankook v12s. Car is dropped on Fortune Auto coils about a little more than an inch and a half drop. One finger gap all around. I have my alignment today but the camber is around 2 degrees all around. Maybe 3 degrees in the rear. That's with maxed out camber plates from the Fortune Autos and no camber bolt. Rear camber is natural.
Squishy86 is offline   Reply With Quote
Old 01-27-2014, 04:07 PM   #322
fooddude
^^ Very nice ...it's silver right? (kinda looks gunmetal from the pic)
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
