Old 01-24-2014, 11:57 PM   #995
frslee
Just drive it
Drives: 13' FR-S
@solidONE haha yeah, i know why we install tune, to get more power! but I was a bit concerned about the abrupt engine noise at that 4000 rpm, that was all
I'm happy with the result. I can't wait to get a header and get stage 2 file..
frslee is offline   Reply With Quote
Old 01-25-2014, 01:41 AM   #996
Sonolin
Originally Posted by solidONE View Post
This is the reason you install OFT. it sound more agressive because it IS more aggressive.
After reflashing to E85 tune, I have killed 2 VQ35 equipped cars. I have AP2 S2000 in my sights next.
Nice which cars?
Sonolin is offline   Reply With Quote
Old 01-25-2014, 02:05 PM   #997
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Sonolin View Post
Nice which cars?
both mid 2000 VQ's one G35 coupe, and Maxima.
edit:
Add my neighbors Cayanne S to the kill list. I guess my 0-60 times are in the mid to low 5's at the moment.
Old 01-25-2014, 07:21 PM   #998
Vlady
Vlady's Avatar
Drives: Argento Scion FRS
Quick question. Would the Vigilant CAI be compatible with he current maps or with it mess up the afrs too much. Thanks!
Vlady is offline   Reply With Quote
Old 01-25-2014, 08:19 PM   #999
steve99
Drives: FT86
Hi,
I have no idea what spec's a viglinant CAI has however their is a good writeup here on the stock Intake.
http://www.ft86club.com/forums/showthread.php?t=56358
If this vigilant intake changes the diameter of the tube where the MAF sensor sits then its likely to need a specific re-tune of the MAF scaling parameters.
I also believe the stock intake has "straighteners" to smooth the air flow through the MAF some aftermarket intakes don't and this can upset the maf scaling can be fixed but requires re-scale.
It may come with scaling info.
Seems stock intake it pretty good for N/A cars and not much gains to be had by aftermarket intakes.
The consensus appears to be add
1. A quality drop in replacement filter
2. Maybe a "perrin" intake tube (only cause I have seen dyno results from a couple of sources that show small 2-3 whp gains) and it removes sound tube.
3. Cut the stock intake snorkel down and expand inlet (there is a how to do guide somewhere)
These simple cheap mods would appear to get results very close to any aftermarket intake system on an N/A car
Old 01-25-2014, 08:55 PM   #1000
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Checkout the Grimmspeed intake thread in the exhaust section...
Right now they are testing all kinds of setups including stock, modded stock and different intakes.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 01-25-2014, 09:27 PM   #1001
jflogerzi
jflogerzi's Avatar
If you can, go back to the stock Intake and modify it. Then sell your old intake to help pay for the OTF. Win, Win
Old 01-25-2014, 10:44 PM   #1002
Vlady
Vlady's Avatar
I already have an OFT and running a Stage 1 map. I was just looking to see if I could get a better flowing intake. Specifically one that has the filter located inside the bumper instead of sol close to the engine. But I will not purchase it if it will negatively impact my performance.
Old 01-25-2014, 10:57 PM   #1003
jflogerzi
jflogerzi's Avatar
Remember the stock intake has a snorkel that draws cool air in. Also Shiv bases his tunes with the stock intake due to the MAF scaling. On this car, intakes are a waste. I would just modify stock setup, and get rid of the sound tube to clean up the engine bay. I am getting rid of my aFe Intake and going back to stock to get the most out of Shiv's tunes and to be safe.
Old 01-26-2014, 01:35 AM   #1004
solidONE
solidONE's Avatar
Are you referring to a vibration noise? If so, I believe I've isolated the source at the overpipe heat shields. There are 5 pieces of the assembly in total not counting nuts and bolts. There are upper and lower sheet metal pieces at the front portion and rear portion plus a clamp that holds the 4 pieces together onto the overpipe like a hose clamp. Unfortunately you'd have to unbolt the pipe to remove the front upper piece. I tried and I have a deep cut on my thumb and some scuffed paint in the engine bay to show for it...
Old 01-26-2014, 05:01 AM   #1005
steve99
Drives: FT86
I covered my stock air box and intake tube in heat reflective aluminium tape cost about $10 and reduced intake air temps considerably on hot days in traffic, so much heat radiated from headers int these motors
Old 01-26-2014, 01:27 PM   #1006
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Is there any mounting solutions out for the OFT to keep an eye on live data while driving or on track? (i.e. oil temps, water temps, etc?)
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 01-26-2014, 01:34 PM   #1007
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
The FA20club CAI works very well with OFT v1.54 EL header gas tune. I will data log next week to provide IAT's with this tune. Previous data logging show only a two degree differential
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 01-26-2014, 02:45 PM   #1008
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
A cell phone holder would probably work. The kind that looks like a clamp.
I'm assuming you'll need one for a large phone, like a Note.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
