Old 01-24-2014, 03:29 PM   #1
vividracing
vividracing's Avatar
New Hood Prop From Seibon? Yay or Nay? Your thoughts
Seibon has a new carbon hood prop. Seems pretty cool and simple. I would prefer the dampers but what are your thoughts?
vividracing is offline   Reply With Quote
Old 01-24-2014, 03:30 PM   #2
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Nay.
I agree with the dampers.
Carlitoz3 is offline   Reply With Quote
Old 01-24-2014, 03:41 PM   #3
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
Not feelin it. Dampers for sure
Sent from my HTC One using Tapatalk
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
Old 01-24-2014, 03:43 PM   #4
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Yay a cf broomstick mod lol
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
The Following User Says Thank You to FrsDuke For This Useful Post:
zooki (01-25-2014)
Old 01-24-2014, 03:48 PM   #5
utekineir
blowhard
Drives: frs, project forester
Can I attach this to my camera as a monopod when the hood doesn't need to be propped?
utekineir is offline   Reply With Quote
The Following User Says Thank You to utekineir For This Useful Post:
wparsons (01-24-2014)
Old 01-24-2014, 04:00 PM   #6
FR-S Matt
I have the Rexpeed carbon fiber dampers. Any hood that gets rid of those is an automatic no for me.
Old 01-24-2014, 04:16 PM   #7
xjohnx
Grip>Slip
xjohnx's Avatar
my thoughts? this appears in the appearance / cosmetic forum.
Old 01-24-2014, 04:54 PM   #8
mid_life_crisis
Drives: FR-S 10 #103 AT
To me, swapping out the hood prop sounds like the height of desperation in looking for something to change.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 01-24-2014, 04:59 PM   #9
wrohdejr
Drives: 2013 subaru limited wrb brz
Problem i run into is my password jdm carbon fiber engine dress kit gets in the way of the hood dampers. This might be a great alternative for people that can't use hood dampers due to mods.
Portland 86ers
wrohdejr is offline   Reply With Quote
Old 01-24-2014, 08:23 PM   #10
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
The reason people would want these are because they might not be able to use dampeners with a carbon fiber hood. For example, if you bought Grimmspeed Hood struts and used them on a stock hood, you'd get tons more clearance because they use a "third" hole already drilled on the stock hood instead of two holes like other hood dampeners. The Seibon hood struts only have two holes for hood dampeners, so they aren't compatible with some struts like the amazing Grimmspeed ones. I hope this makes sense. It's pretty hard to explain. The only reason I know about this is because I have the Grimmspeed Hood struts and ended up getting a carbon fiber hood and couldn't use them together.
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
Old 01-24-2014, 09:43 PM   #11
turbos86
Drives: 2014 Zenki 37J
Oh a $100 laundry pole?
Here's one, $6
Amazon JP
Bonus, it's JDM +5hp
turbos86 is offline   Reply With Quote
The Following User Says Thank You to turbos86 For This Useful Post:
finch1750 (01-25-2014)
Old 01-24-2014, 10:45 PM   #12
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Looks like my grandmas cane. Fuck if i had to have a cane it be CF. JDM as fuck at 70...
Old 01-25-2014, 01:22 AM   #13
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
See no point when dampers are so much easier. This still gets in the way even if the hood is higher.
Old 01-25-2014, 02:00 AM   #14
wrohdejr
With the engine bay carbon fiber you cant use hood dampers because of the layout of the carbon fiber. Also as mentioned above hood dampers don't fit well on Seibon carbon fiber hoods. See the pic below.
Portland 86ers
Vortech - Hood Prop Relocation Bracket Philly758 Want-To-Buy Requests 1 01-23-2014 02:32 PM
Seibon Carbon Hood Prop vividracing Exterior Parts - The Rest 0 01-16-2014 08:16 PM
Looking for vis aem hood or seibon fa hood ready to ship Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-30-2013 12:25 AM
DIY - Alternate Hood Prop F1point4 DIY (Do-It-Yourself) Guides 13 03-20-2013 11:22 PM
Hood strut/prop peenut1086 Cosmetic Modification (Interior/Exterior/Lighting) 0 07-26-2012 12:35 AM
