#2871 | |
Drives: 2013 SWP BRZ
The BPV comes off with the elbow. You will see once the bolts are removed and you are about to pull the elbow off. It just sits in place. Also, I just removed the 4 Throttle body bolts and let it hang, so I didn't have to remove the coolant lines. I don't think much coolant will even come out of there but I hate coolant so I didn't chance it, LOL. |
| The Following User Says Thank You to xxscaxx For This Useful Post: | swift996 (01-24-2014) |
#2872 |
Drives: 2013 BRZ limited SWP
I bought the universal one. I don't know for sure where I'm going to mount it yet but I will post some pics after I install it. I'm waiting for my intercooler to show up so I'll probably wait and install everything at the same time.
#2873 |
Drives: 2005 kia spectra 5, 2004ford tauras
OK guys I am going to install a boost guage on wrkgooses car this weekend and couldn't decide on using the port in the back of the manifold or drilling and tapping the map sensor plate. I called innovate earlier to pick the tech supports brain, and they did not recommend using the port on the back but rather drill and tap the map plate. How ever they said they the heads on the screws on the plate will probaily break off. There standard threads and can be sources pretty easily. It shouldn't take to long to do, I'll let you know when I'm done.
| The Following User Says Thank You to lex tech For This Useful Post: | Joeyb860 (02-22-2018) |
#2874 | |
That Guy
Drives: 2013 asphalt FRS MT
Some wine to go with that cheese. That's pathetic.
#2875 |
I'm not wining, I'm just letting everybody know what innovate said. And by the way its " would you like some cheese with that wine.
| The Following User Says Thank You to lex tech For This Useful Post: | xjohnx (01-24-2014) |
#2876 |
Grip>Slip
#2877 | |
That Guy
I didn't say you were whining. I was referring to how cheesy it is that the bolts would break off, and that Innovate knows this. That's why I bolded the portion I was referring to. Good luck with the install. |
#2878 | |
WUB WUB
Drives: 2013 Firestorm
with any luck, shouldn't take more than 30 minutes to get the line set up, just trying to figure out where I want to mount the gauge. not going to do a permanent mounting, since i plan on getting an AFR gauge as well.
| The Following User Says Thank You to wrxgoose For This Useful Post: | Calum (01-24-2014) |
#2879 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
I've connected up for a month now no issues. |
#2880 | |
Road Warrior
This way you get every reading without having to run line or mount boost gauge. If you using stock map sensor then you will have to run mechanical gauge. Not sure if you have seen the Rally Sport vent gauge holder. Gauge in the vent takes not more than 15min and looks so OEM. That's my 1c
#2881 | |
WUB WUB
#2882 |
Here is where I tap for my boost gauge:
| The Following User Says Thank You to DriftEm For This Useful Post: | Ryan86 (01-24-2014) |
#2883 |
Drives: Frs
Does anyone know if and when the 335 will be available?..
Thanks |
#2884 |
WUB WUB
that's where we plan on doing it as well. how long is the line you used, and what hole did you go through? i plan on trying to go through the sound tube hole, just for now.
and iirc, the 335 was causing some engine problems. gotta look it up again ot be certain though
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
