Old 05-19-2013, 07:12 PM   #43
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
If your dealer keeps replacing the taillights they are doing it wrong. The problem isn't the taillights unless they've actually cracked...read the revised TSB...the dealer has to fix the bent taillight mounting points and install an updated gasket and updated retaining nuts.
If they do it "right" they won't leak again. Don't drill holes...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
Zgrinch (05-19-2013)
Old 07-22-2013, 06:58 PM   #44
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Update:
After applying a second line of weather adhevise i now have the water back in my taillights.
I will try to put both the aftermarket and OEM foam, if not then i'll go back to the dealership...
Old 07-23-2013, 04:49 PM   #45
Surakusa
Mechanical Guru
Surakusa's Avatar
Drives: 2013 Scion FR-S (Argento) M/T
Anytime I get water in mine I just pull them out... they are held by 4 nuts... I pull the light bulbs out, put a hair dryer on it and the water evaporates out... I did discover that water pools around one of the plastic light bulbs which isn't sealed and I got water in that way... I took some putty-like material my dad gave me and wrapped it around the light and sealed it... I haven't had water in it ever since and it's been through several heavy storms as of late.
Surakusa is offline   Reply With Quote
Old 07-23-2013, 04:56 PM   #46
DJCarbine
Thupercharged
DJCarbine's Avatar
My condensation is gone after I drilled small (1.5mm) holes in the tail light.
I had fishbowl tail lights until I did this... after one day in the hot sun, all the condensation cleared up.
I've done this on previous cars with great success and no problems.
The amount of water that I got to drain out of the tail light was rediculous.
When I get more time I may seal the hole back up with black RTV and try to seal the tails properly... but I don't see that happening
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 07-24-2013, 02:18 PM   #47
BRZ_Lawyer
Hardworking
BRZ_Lawyer's Avatar
Drives: 2013 Subaru Brz, 2013 C300 4Matic
No offense but all the aftermarket taillights looks like they belong on a riced out Civic, not my style man.
very well said
Lawyer in NJ and Pennsylvania.
My BRZ gets me to court quick!
2013 WRB BRZ Limited
2013 C300 4Matic
Septa, NJtransit, MTA
BRZ_Lawyer is offline   Reply With Quote
Old 01-24-2014, 05:13 AM   #48
Trettiosjuan
Drives: GT86
Originally Posted by BRZ_Lawyer View Post
very well said
Oh, but the OE lights also look like ricer lights escaped from the nineties. Full red aftermarkets like Toms and Crystal Eye look more behaved IMHO.
Anyhow, thanks for this thread, will be drilling a small hole at the bottom, seems like a more robust solution than trying to forever perfectly seal those taillights...
Trettiosjuan is offline   Reply With Quote
Old 01-24-2014, 05:23 AM   #49
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Clear Toms on a BRZ look like that's how it should've come from the factory. If you have problems with tail light condensation, I have a pair that have no condensation issues that I wouldn't mind selling.
ericmpena is offline   Reply With Quote
Old 01-24-2014, 01:47 PM   #50
sirsol66
Drives: 2013 FRS- Hot Lava
Where did you drill the hole on yours? Into the clear plastic, or into the back portion?
sirsol66 is offline   Reply With Quote
Old 01-24-2014, 01:58 PM   #51
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
No, to let the magical butterflies free.
Why else would you drill a hole in your taillights? Extra 25HP?
I got 30whp out of mine bruh!
Crystal Eye tailights are in! deedz Cosmetic Modification (Interior/Exterior/Lighting) 79 06-07-2013 03:32 PM
Tinted Tailights IceCreamMan Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 05-20-2013 06:39 PM
Tailights tinting? imravenit Cosmetic Modification (Interior/Exterior/Lighting) 17 04-23-2013 09:54 PM
Toronto FR-S orders- Drill or no Drill on bumper Dragon86 CANADA 35 10-12-2012 02:35 PM
Mysterious microscopic hole Aznek Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-09-2012 09:22 PM
