Old 01-22-2014, 11:59 PM   #351
CSG Mike
CSG Mike's Avatar
Originally Posted by T-dub View Post
I just found out that I made standby at TWS this weekend, which I didn't really expect...I have ~1200 miles on the car, factory engine oil/brake fluid and a set of 17x9 +38 255/40 rs3 sitting in my garage that are begging to go.
I hate the Prius tires, but the other set seems like serious overkill for 160 hp car at a fast track. WWYD?
I thought I read in the manual that I shouldn't change the factory oil until 5k miles, but I don't feel right about leaving it in. WWYD?
It depends on the track. Do you have a track map?
We did some track time on the factory oil, but I'd recommend a quality synthetic sooner rather than later.
Old 01-23-2014, 12:13 AM   #352
T-dub
Drives: '13 BRZ
Got a track related question? I'll try to answer.
CCW, if that matters.
T-dub is offline   Reply With Quote
Old 01-23-2014, 12:16 AM   #353
CSG Mike
CSG Mike's Avatar
Attachment 64661
Can you give me the approximate cornering speeds at each turn, and the top speeds on teh straights?
Old 01-23-2014, 01:15 AM   #354
fatoni
any advice for running streets of willow counter clockwise?
i havent decided if im going to take my miata or brz but i figure their power/weight is pretty similar and aero is not too significant on this track i figure some of the tips would translate well.
Old 01-23-2014, 01:55 AM   #355
CSG Mike
CSG Mike's Avatar
exit speeds are key to fast laps. Don't rush the entries.
Old 01-23-2014, 01:58 AM   #356
fatoni
any particular quirks to sow ccw? ive only driven cw
Old 01-23-2014, 11:53 AM   #357
CSG Mike
CSG Mike's Avatar
Lots of decreasing radius turns. Don't cook your entries; make sure your exit speeds are there (because that forces average speeds to go up too)
Old 01-23-2014, 12:06 PM   #358
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
Don't forget the Rocket Start, which is performed by accelerating when the number "2" begins to fade out. Works every time.
Anthonytpt is offline   Reply With Quote
Old 01-23-2014, 12:58 PM   #359
T-dub
Drives: '13 BRZ
I have only been there once before, so I can't remember all of them, but the front straight is ~125 mph in my WRX. If I had to guess the BRZ MIGHT do 110 mph? Basically from the exit of turn 15, until the entrance of turn 3 is all >80 mph and that is about 25-30% of the total length. I think the back straight is in the ~ 90 mph range, but I can't remember for sure (its been almost 2 years since I was there). I am still curious which set you would choose and why, but after sleeping on it I think I have a plan.
If I put the beefy wheels on, I would feel compelled to put better brake fluid in. I am fairly sure I won't boil the fluid on stock tires, but I COULD on the RS3s...I think.
After adding up all the pros and cons, I think I will keep the factory oil fill (this time) and in the interest of not taxing the motor too much (and not really having time, or feeling like bleeding my whole brake system tonight) I will go with the stock wheels. I will bring better fluid to the track anyway and if it becomes a problem, I will bleed them then.
The weather is predicting ice tomorrow, so all of Houston may be shut down (aint nobody here got winter tires)...so I might get bored tomorrow and do it anyway.
Old 01-23-2014, 01:02 PM   #360
CSG Mike
CSG Mike's Avatar
You'll *probably* be faster with the skinnier tires, because the straights are so long. I can't say 100% until I have data, but I would start by trying 225. The only courses I've seen where wider is faster NA is a really tight course like Streets of Willow Springs (try it on GT6)
Old 01-23-2014, 01:51 PM   #361
T-dub
Drives: '13 BRZ
That is what I was thinking. I almost forgot. What tire pressure should i start out with? Thanks for your input.
Old 01-23-2014, 01:53 PM   #362
CSG Mike
CSG Mike's Avatar
30 is a good starting point, but cold pressures won't matter, only the hot pressures. Keep your tire gauge with you in the car (secured or tied down), and check pressures after 3 laps. Bleed to 36-38 hot, and then check again IMMEDIATELY after your sesssion, and bleed as needed.
Remember to fill your tires back up at the end of the day.
Old 02-05-2014, 03:09 AM   #363
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Subscribed
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 02-06-2014, 05:27 PM   #364
Stevo22
Stevo22's Avatar
Drives: GR86
Why do people tape the gap between the bumper and fenders when going to the track?
Stevo22 is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
