#827 |
Drives: Scion FR-S
#828 |
Poor College Kid
Drives: ~.~
Any of you guys are getting headlight condensation? The Toyota guy seem thought I hit something, he said he was just joking but I have a feeling that he wasn't really. I am getting it replaced tomorrow, I hope it doesn't come back like what you guys are experiencing.
#829 |
Drives: 2013 FRS
alright i guess i have the condesation too; has toyota or subaru released new tailights that will fix the problem or are they just going to replace them with a new lights?
#830 |
As far as I can tell, the TSB is only to replace the taillight assembly and/or the gasket that "seals"to the body. There has been no revision to the design or updated part number.
#831 |
Drives: 2013 FRS
thats not cool i wish they would make a new part. so when they do fix it does that mean that i wont have the condensation anymore?
#832 | |
Drives: FRS
Its a design flaw easily fixable by reading the threads - ![]() ![]() CERBERUS |
#833 | |
A few permanent solutions would be to A- replace the gasket with better material (this has worked for some but to me isn't ideal because the sheet metal can still deform), or B- a sealant, which I recommended a few times in this thread but makes the installation semi permanent, (could be problematic for some) or C- fabricate a more rigid bracket that sits on the sheet metal opposite the taillight that would prevent the thin sheet metal from deforming at all. |
#834 | |
Drives: FRS
AGREED
And perhaps a re-design of the black plastic top of the light where it contacts the water channel (and allows water to flow under it and into the gaskets) with a body metal lip over the top of the plastic to redirect the water flow. ![]() CERBERUS |
#835 |
Drives: 2013 FRS- Hot Lava
Just noticed this problem on my 2013 (Build date is April '13), after a year of ownership. It started late last week with a small area of condensation, and has been growing everyday.
Any reason why its popping up now rather than before? I have a spare set of taillights (with red paint) that I can throw on after sealing, but I'm tempted to just take them in to get the free gasket so I double up when I install my new ones. I'm not sure I want the dealership touching my car though...Thoughts? Also, has anybody tried using RTV or even petroleum jelly to seal around the bulbs? |
#836 | |
Drives: 2023 Toyota GR86 Premium
At this point I'd say just go back and read more of this thread. I will say doubling up the gasket isn't a good idea. A single new (better) gasket (but properly sealed to the housing, unlike the factory gaskets) is a good idea, in combination with building a dam using some sticky tack, Sugru, or some other removable, flexible material to divert the flow of water.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
#837 | |
The idea of building the dam doesn't appeal to me, as it traps the water on top of the trunk area, instead of letting it flow down and out as its intended to. I'm not suggesting the Toyota/Subaru design is ideal (far from it), but I'd much rather have condensation in my taillights than salt water sitting on the quarter panel of the car, especially since this car doesn't have any other drain holes. We'll see if my condensation comes back in a few days, it was just very weird that there was no hint of it until a year after the car arrived. |
#838 | |
Alright, my recommendation given your preferences is to seal the new gaskets to the housings with some kind of weatherstrip adhesive to create a stronger barrier than the factory "tape strip." It didn't happen right away because the barrage of water erodes the crap factory "seal" over time.
#839 |
Ah, I didn't realize that the factory gasket had something tape like on it. I'll see what kind of silicone I can find, thanks for the advice. Any specific suggestions from someone that's had good luck?
#840 | |
3M Automotive Weatherstrip Adhesive (1oz tube) works well and isn't expensive. I've used it to install my gaskets in 3 of my own sets of tail lights (factory, Colin, Valentis), and for installs for at least 10 other people with good results. Here's a video I made for my site showing how I apply the adhesive, you can skip to 4:40 for the application. [ame]http://youtu.be/eF62JXlSufM[/ame]
| Red tail light photoshops | OwenK | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 68 | 02-06-2013 03:48 PM |
| HKS head and tail lamps | DIG1992 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-19-2012 01:04 PM |
| Tail of the Dragon | Tomcat9700 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 02-10-2012 02:30 PM |
| headlight condensation | MRZ415 | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 01-23-2012 02:24 AM |
| Optional coloured tail lights? | m_life | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-30-2011 06:20 PM |
