Old 01-09-2014, 07:13 PM   #15
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
damn I need this. dont want to deal with the fuse issue.
tried PMing the member with no luck.
do you have any other contact for him? SVXdc has been on since Nov.
@ChiefG
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 01-09-2014, 08:25 PM   #16
Panman
Panman's Avatar
Drives: 86 GTS
@ChiefG
His contact details are on his website..... Which is linked earlier in the thread.
Panman is offline   Reply With Quote
The Following User Says Thank You to Panman For This Useful Post:
ChiefG (01-09-2014)
Old 01-09-2014, 11:41 PM   #17
ChiefG
Skeptic
ChiefG's Avatar
Drives: 2013 FR-S Ultramarine 6A
@ChiefG
Go to his website, linked earlier in the thread. He's a busy guy, so give him a few days to respond.
After installing a backup cam and aftermarket GPS/sound/touchscreen system, installing the dash cam and power magic unit was a piece of cake.
@Mr.Jay
"All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business. " - Red Green
ChiefG is offline   Reply With Quote
Old 01-10-2014, 09:24 PM   #18
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Lol sorry I read op and got excited!
Thanks for info
Out of the FRS game
Old 01-21-2014, 01:29 PM   #19
ChiefG
Skeptic
ChiefG's Avatar
If you ever need to remove something, like the BlackVue cam mount, that is mounted with 3M or any other type of double-sticky mounting tape, get some dental floss and wrap it under your mounted device. Use a sawing motion to cut through the sticky tape, then remove what's left with a solvent like Goo-Gone.
The Following User Says Thank You to ChiefG For This Useful Post:
ftc~brz (01-23-2014)
Old 01-21-2014, 02:07 PM   #20
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
does the Canadian BRZ have this factory option connector ?
thanks
ucsmfu is offline   Reply With Quote
Old 01-21-2014, 02:13 PM   #21
nocturne1
nocturne1's Avatar
Drives: 2013 BRZ Limited WRB
@ChiefG Have you had any issues with your battery getting too low to start? I've seen another thread here that despite the Power Magic Pro, our batteries may not have enough juice after being run down to start.
nocturne1 is offline   Reply With Quote
Old 01-21-2014, 03:29 PM   #22
ChiefG
Skeptic
ChiefG's Avatar
I have my Power Magic Pro set for 6 hours and 12v, and I turn it off when parked at home, so I haven't let it run long enough for that to happen.
Old 01-21-2014, 03:33 PM   #23
ChiefG
Skeptic
ChiefG's Avatar
thanks
I can only guess that it does. You'll have to pull the radio to find out - which is easy. Just pry off the bezel and undo 4 10mm bolts.
Old 01-21-2014, 06:04 PM   #24
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Can you take a picture of the connector that Iam looking for ?
Thanks
Old 01-21-2014, 06:13 PM   #25
ChiefG
Skeptic
ChiefG's Avatar
Thanks
Here's one, and there are more earlier in the thread.
b rawr z (02-19-2014)
Old 01-21-2014, 10:34 PM   #26
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Thanks !!, I emailed SVXdc, but no response.
Also, where did you ground the black wire ? or does the harness include all 3 (power, accessory, and ground ?)
thanks
Old 01-21-2014, 10:59 PM   #27
ChiefG
Skeptic
ChiefG's Avatar
thanks
He's a busy guy, but he will get back to you. Give it time. The harness includes pwr, accy and ground leads. Look at my pics. It could not be easier!
Old 01-21-2014, 11:00 PM   #28
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
yup saw the pics, thanks again, awesome DIY, and I love how it's factory plug and play
The Following User Says Thank You to ucsmfu For This Useful Post:
ChiefG (01-23-2014)
DIY Blackvue DR400G-HD/Power Magic Pro Dashcam F1point4 DIY (Do-It-Yourself) Guides 194 06-12-2020 02:08 PM
Fs: Blackvue DR550GW-2CH (built in wifi + power magic pro) ucsmfu Canada Classifieds 23 07-17-2015 05:04 PM
FS: Blackvue DR400G-HDII w/ Power Magic Pro subiestar Audio/Visual, Electronics, Infotainment, NAV 10 11-24-2013 03:00 AM
Max power for factory drivetrain and engine internals solidONE Forced Induction 64 09-23-2013 02:16 PM
New Option For Agency Power Exhaust vividracing Engine, Exhaust, Bolt-Ons 0 04-26-2013 02:37 PM
