Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-21-2014, 04:33 PM | #99 |
Drives: 2013 Scion FRS
I hate to see any engine blown... but from those that have popped comes hard won knowledge - what works, what does not. Breaking eggs, omelets and all that.
I like to think in a couple of years we will begin to see some truly built applications and options on the FA20 platform.. but, no, as of today I don't think it is a dud at all... For me personally, I've enjoyed inching up the NA horsepower with bolt-on mods and tunes. My NA goal is 200whp on 93oct - which should be obtainable. I'll eventually install an FI solution, probably a supercharger... and I expect to reach 300whp safely. If that requires building a block to make it happen, so be it. It's part of the fun of owning and enjoying the car. |
01-21-2014, 05:09 PM | #100 | |
I guess maybe we are saying the same or similar things. The actual engine and longblock is not bad on this car IMHO. The tune is shitty from OEM as are other Subaru models like the STI. You found out the hard way before you got an aftermarket retune unfortunately and I know first hand that can really suck after I had an STI engine blow up (it was very modified though, pay to play). I don't think this makes the FA20 engine bad, but I do freely admit the OEM tune, especially the early version, is risky on the track. I think the S2K engine is fabulous. At the same time, I am not blinded by the fact the BRZ/FRS is significantly cheaper new than the S2K was (at least $5K or more, not even considering inflation) and the S2K had less strict emissions in that era and finally (most importantly) the S2K is a hand assembled engine with Honda reliability. I don't expect the same robustness from the BRZ engine - honestly, how many modern engines have the same robustness as the S2K engine... Not many. I would argue the S2K engine is the best 2.0L NA engine ever, I might lose, but it's gotta be up there in the list. On the other hand, I also don't think the only known issue with FA20 DI seals which is most likely caused by a shitty OEM tune really is an engine hardware issue. The actual FA20 block may be pretty darn stout as long as it's not running that crappy early version OEM tune (time will tell). That tune causes det in certain situations. Any engine (even the S2K engine) will eventually fail after sustained detonation scenarios. Like somebody posted earlier, let's give it another couple year and see where all the high HP NA and FI builds are at. Opinions might be ALOT different then. |
01-21-2014, 05:20 PM | #101 |
^^ I would argue the K20's are better than the F20C's, but that's not much of an argument since they're both Honda
01-21-2014, 05:21 PM | #102 |
Yeah, I said I might lose that argument... Haha.. But my point is it's a pretty badass engine.
01-21-2014, 05:27 PM | #103 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Out of all current available engines, I don't think the FA is at the bottom - that being said, the engine's only been out to pasture for a couple of years. Like everyone said, give it a couple more and we'll start seeing a trend and ultimately judge whether it was good or not.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
01-21-2014, 05:38 PM | #104 |
Drives: 2014 FR-S MT Asphalt Grey
The only issue I for see is the d4s system not being fully realized due to subaru immediately switching to their own DIT with the wrx.
01-21-2014, 05:48 PM | #105 |
Drives: Challenger R/T, CRX SI,
Plenty of people are running around +100whp on stock internals. I don't see how that isn't impressive. Different people have range of expectations I assume but the FA20 engine itself is way better, than old ejs, in plenty of ways. Fuel efficiency, emissions, and power per liter.
They didn't use it in the new WRX for fun. Hopefully they can figure something out for the new STI in a few years. Last edited by CajunFRS; 01-21-2014 at 05:58 PM. Reason: EJJJJJJJ |
The Following User Says Thank You to CajunFRS For This Useful Post: | CSG Mike (01-21-2014) |
01-21-2014, 05:50 PM | #106 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | DAMotorsports (01-21-2014) |
01-21-2014, 06:00 PM | #107 |
Drives: 13 Subaru BRZ Limited
There's plenty of stuff going on in Japan.
AVO Turboworld: https://www.facebook.com/avojapan Esprit is making almost 400hp in their 86: [ame="https://www.youtube.com/watch?v=ynaamWqzaLQ"]ESPRIT TOYOTA 86 on Track【2012 TSUKUBA SUPER BATTLE 】 - YouTube[/ame] Aspiration (http://aspiration-r.info) has a turbo FRS with 300+ HP HKS in Kyushu has a turbo 86: http://www.hks-kyusyu.co.jp/blog/archives/98.html The list goes on and on. Check out this page for even more FI goodness from Japan: http://car.watch.impress.co.jp/docs/...12_581549.html |
The Following User Says Thank You to bobaab For This Useful Post: | sdwagonjp (12-15-2014) |
01-21-2014, 09:03 PM | #108 | |
They switched before the WRX, the Legacy in Japan already has the FA20DIT and so does the Forester XT here.
01-21-2014, 09:37 PM | #109 | |
Are you sure you aren't sponsored by Subaru? :P I kid I kid.
01-21-2014, 10:24 PM | #110 | |
Red wine
Drives: Subaru BRZ(R.I.P)
Just for the record, I do see where you are coming from. But teams would rather use a proven system rather than wasting their money on R&D. Which is why you see a lot of them dumping their money on the EJ and the almighty 2JZ. Just give it some time and once these race teams start figuring out this new FA engine they will be dumping that old proven system and start jumping on the bandwagon once the limit has been broken.
01-21-2014, 10:33 PM | #111 |
Member of the year - 2016
Drives: Scion FRS
You guys are a bit harsh on hmong337, he's a car guy like us, he's just a bit impatient and ignorant, aren't we all sometimes?
Rightful so, i don't post around here because my knowledge is limited. Patience is key. I'd rather companies take time then rush products, a rush product always leaves disappointment and a long lasting negativity towards a company.
The Following User Says Thank You to dem00n For This Useful Post: | SkAsphalt (01-21-2014) |
01-21-2014, 10:36 PM | #112 |
Drives: 2010 MS3
Jesus, OP sounds like my boss.
No, that's not a compliment. |
Tags |
this isn't a mr2 |
Similar Threads | ||||
Dynosty Turbo FR-S FA20 Highest Horsepower Record 324WHP | Hal@Dynosty | Forced Induction | 363 | 11-19-2014 10:03 AM |
High horsepower, straight line car forums... | husker741 | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 11-01-2013 12:50 PM |
FA20 Fuel lean at high boost fix | cf6mech | Forced Induction | 15 | 05-20-2013 03:33 PM |
FA20 bolt-on horsepower gain potential | CSI:86 | Engine, Exhaust, Transmission | 42 | 04-26-2013 11:14 AM |
What's high horsepower to you? | dem00n | Off-Topic Lounge [WARNING: NO POLITICS] | 42 | 04-13-2013 01:08 PM |
