| Member's Car Journals Car journals by our members. |
Drives: Dark Grey Metallic 2013 Subaru BRZ
My 2013 Dark Grey Metallic BRZ build
How's it going everyone? Thought I'd start my build thread since parts are starting to arrive.
Got my 6 speed manual 2013 Dark Grey Metallic BRZ at the end of December and I absolutely love it! I plan on on going supercharged eventually but I'm sticking with catless full exhaust, tune, drop in filter and a few things on the exterior and interior for now. So far: Engine: GFB lightweight pulley kit Crawford Air Oil Separator Shorai lightweight lithium iron battery Exhaust: Borla UEL header Perrin over pipe HKS dual resonated front pipe 3" Perrin resonated cat back Torque Solutions exhaust mounting kit Suspension: ISC Suspension N1 coilovers Stance Adjustable Lower Control Arms Perrin 22mm rear sway bar Kartboy rear sway bar endlinks Spencer Fabrication Company rear brace Intake: Sound tube delete kit Perrin drop in air filter Appearance: HID LED fog lights, red interior lights, red door lights, white trunk light, reverse light and white rear plate lights. All of which are HID LEDs. Red footwell lighting kit LED strip inside the trunk Smoked front corner turn signals Hexomat front rubber floor mats GrimmSpeed license plate relocate kit GrimmSpeed hood struts cQuarts coating Rally Armor mud flaps Valenti smoked tail lights and reverse light OEM Rear diffuser Kinetic Custom Machine aluminum battery mount Wheel and tires: Rays Gram Lights gunmetal 57dr 17x9 +38 offset Hankook Ventis v12s 245/45/17 Breaks: Stoptech Front and Rear slotted discs Stoptech Front and Rear pads Stoptech Front and Rear Stainless Steel braided break lines Perrin master cylinder brace Maintenance: Magnetic plugs for oil, trans and diff Motul Gear Oil 300 for trans and diff Should be fun putting all this stuff on! Here's my beauty after cQuarts coating and wax! ![]() ![]() ![]() ![]() Got the Perrin overpipe today 1-22-14! ![]() On jack stands for the first time! About to change the diff and trans fluid! Ended up doing some exhaust too! ![]() ![]() Stuff everywhere! ![]() Borla UEL header ![]() Borla header to Perrin over pipe ![]() GrimmSpeed front plate relocate kit. Gotta get the dremel out and trim the GrimmSpeed license plate frame because in Texas the actual word Texas has to be completely visible. ![]() Ordered a custom plate today. ![]() Got my Stance adjustable lower control arms in today! 1/28/14 ![]() Perrin 3" catback, Perrin 22mm sway and Stance adjustable control arms. ![]() ISC N1 front coilover ![]() ISC N1 upper front camber plate ![]() LED fog lights ![]() Red LED interior ![]() LED strip in trunk ![]() Valenti smoked tails and reverse light! Lookin clean! Also, the Perrin 4" tips on the 3" catback with the OEM rear diffuser underneath. ![]() ![]() Night time ![]() A little playing around with the night time pic. ![]() Water beading action thanks to cQuarts coating and wax. ![]() First drive after everything was feeling like it should. ![]() Did my first dyno pull with my mods on. 190 hp and 154 torque! Definitely gotta get a tune soon! ![]() Did a new video with the HKS front pipe. [ame="http://www.youtube.com/watch?v=w2cmrAT6HFc"]2013 Subaru BRZ with modified exhaust. - YouTube[/ame] New wheels and tires! Gram Lights 57DRs 17x9 +38 offset in gunmetal blue. Hankook ventus v12 evo tires 245/45/17. ![]() Got my Rays center caps in on my Gram Lights 57DRs ![]() Close up of the Rays center caps with the black Muteki lugs ![]() Crawford air oil separator and Kartboy rear sway bar endlinks. ![]() Sports car issues! It barely fit in the back seat! It was tight! ![]() Lookin clean! ![]() Removed the 3rd brake light from the rear deck. Had to use a soldering iron to melt the plastic rivets. Now I need to get it covered. ![]() Installed the GrimSpeed hood struts and Crawford air oil separator. Also installed the Perrin master cylinder brace, light weight pullies and rear diffuser. ![]() Better look at the Crawford air oil seperator. ![]() Perrin master cylinder brace ![]() Kinetic Custom Machine aluminum battery mount and Shorai lightweight lithium iron battery. ![]() Installed the custom rear body brace made by Spencer Fabrication Company! I found the company on Facebook and they do this rear brace and a few other things for the BRZ/FRS platform. Very high quality work! The back seat is kept and still functional. It was a bit of work but totally worth it! Had to modify the rear trunk mat a bit, the foam under that mat and those trim pieces connected to the rear deck.. The all weather Subaru liner still fits because its flexible. ![]() You can see the back seat is up and locked in place. ![]() ![]() Definitely need to upgrade the cooling system with radiator and oil cooler. Hope everyone enjoys and I look forward to your feedback! Last edited by DrewIsAmus; 03-29-2014 at 05:30 PM. |
#2 |
Woke up for my night shift and it was like Christmas on the front porch!
![]() Didn't have time to unbox any of it though. :-( Last edited by DrewIsAmus; 01-20-2014 at 06:45 PM. |
| The Following User Says Thank You to DrewIsAmus For This Useful Post: | BPAuto (02-25-2014) |
#3 |
The goodies I got yesterday! Thanks @SOURCE,LLC!
Top to bottom: Borla UEL header Tomei titanium front pipe GrimmSpeed hood struts GrimmSpeed front license plate relocate GFB pulley kit Perrin 3" resonated cat back Perrin 22mm rear sway bar Rally Armor mud flaps Torque solutions exhaust mount kit ![]() Just need my Perrin over pipe! |
| The Following 2 Users Say Thank You to DrewIsAmus For This Useful Post: | Richyjc (01-21-2014), SOURCE,LLC (01-28-2014) |
#4 |
Not what you think
Drives: 718 GTS 4.0
why Tomei front pipe but no Tomei exhaust?
#5 |
Wanted the low weight of the Tomei pipe plus, I prefer the Perrin sound and double exit. A single exit with notches in the bumper for a double looks silly to me.
#6 |
Not what you think
Drives: 718 GTS 4.0
Haha I get that a lot with my type 80 I'm thinking of doing a custom job to maybe plug the other side so it looks normal
#7 |
Drives: 2013 Scion FRS
Ft86speedfactory.com sells a block off for the other side of the exhaust so you can buy a single and not look stupid with two cut outs :P
| The Following User Says Thank You to Fresh86 For This Useful Post: | DrewIsAmus (01-22-2014) |
#8 |
Nice build so far btw
| The Following 2 Users Say Thank You to Fresh86 For This Useful Post: | Conundrum (02-12-2014), DrewIsAmus (01-22-2014) |
#9 |
Thanks! I'm trying to keep it classy and more performance related.
I just wish the brake upgrade options weren't so dang pricey! Besides pads and rotor upgrades, the bigger brake kits are crazy expensive!
#10 |
You should look into buying the 2004 sti brembos there cheap all 4, about 1200$ at most for pads rotors and even lines and calipers... 2004 sti is 5x100 2005 was changed
| The Following User Says Thank You to Fresh86 For This Useful Post: | DrewIsAmus (01-23-2014) |
#11 |
Thanks, I will!
#12 |
Not what you think
Drives: 718 GTS 4.0
#13 |
Worked on the car a bit yesterday. Was just going to change the diff and trans fluid as well as add better magnetic plugs but ended up doing some exhaust too!
Put on the Borla UEL header(super easy), Perrin over pipe, Tomei titanium front pipe and poly exhaust hangers. Tried to do the 3" Perrin cat back but one of the v-band clamps busted and sliced my finger pretty good! So had to put the stock cat back exhaust back on! Now, it sounds like crap! Oh well, ordered a new v-band clamp. Hopefully my coil overs will get here and I'll do em at the same time! Put in the Perrin air filter too! That sucker was a tight fit! Oh, and yes! The exhaust is now very smelly with no cats! Thanks for reading!
#14 |
Still trying to get the ride height correct but most of the parts are put ON! Been a rough few days under a car on jack stands! I'm sore like I did a 4 hour gym workout! It's a good kinda sore though!
![]() ![]() My helper and long time since childhood friend Charlie!
| 2013 FRS 10 Series / BRZ Smartkey REMOTE START | Dustin2JZ | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 03-18-2015 10:18 PM |
| Mister's 2013 FR-S Build | Mister | Member's Car Journals | 1 | 03-20-2014 07:49 AM |
| P&L Motorsports 2013 BRZ Build! | P&L Motorsports | Member's Car Journals | 28 | 11-04-2012 09:07 PM |
| 2012 or 2013 Build? | benoh | AUSTRALIA | 16 | 09-27-2012 12:56 AM |
| 2013 Subaru BRZ Limited Start Up, Exhaust, and In Depth Review | delta86 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 06-26-2012 03:25 AM |
