Old 01-21-2014, 07:45 PM   #1
Mathewgzlz
Mathewgzlz's Avatar
Drives: 2013 SCION FR-S FIRESTORM RED
Electronic power steering
ok heres the situation yesterday i was doing some hooning on some back roads came around the corner with little to much speed started to slide over corrected and went into the grass nothing to crazy. well today i started the car and the eps light was on for a brief moment then came off after about 5 sec any advice on what to check ?
Mathewgzlz is offline   Reply With Quote
Old 01-21-2014, 09:02 PM   #2
If the car drives OK, I'd wait to see if it goes away.....
Old 01-21-2014, 09:35 PM   #3
Mathewgzlz
Mathewgzlz's Avatar
It didn't pop up when it happened or even later tht day when I was driving only this morning
Old 01-21-2014, 09:36 PM   #4
Mathewgzlz
Mathewgzlz's Avatar
I think I might have an electrical issue to be honest because my gauges have been bugging out as well
Old 01-22-2014, 02:05 AM   #5
Is the car giving you and code(s)?
You might try disconnecting the battery for a few minutes to see if it straightens itself out ....
Old 01-22-2014, 02:06 AM   #6
Mathewgzlz
Mathewgzlz's Avatar
No code it stays illuminated for a few seconds after I start the car then goes away I haven't noticed anything different in the steering feel either
Old 01-22-2014, 02:22 AM   #7
You might try moving the steering wheel lock to lock several times.
Have you tried disconnecting the battery to re-set the system?
You mentioned "other gauges bugging out". How so?
Old 01-22-2014, 02:24 AM   #8
Mathewgzlz
Mathewgzlz's Avatar
Well some times they won't turn on until I've been driving for awhile my boost and afr gauge tht is almost like there not getting enough power and once the battery charges a bit they pop right back on
Old 01-22-2014, 02:33 AM   #9
Well ..... hmmmm .... you might check the battery.
This is a good guide:
http://www.aa1car.com/library/battery_runs_down.htm
I hope you get er straightened out......
Mathewgzlz (01-22-2014)
Old 01-22-2014, 02:50 AM   #10
Razz
Razz's Avatar
Drives: Fast
Jack up the car and check underneath.
You might have pulled a cable so it is loose etc..
Razz is offline   Reply With Quote
The Following User Says Thank You to Razz For This Useful Post:
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 04:41 PM
power steering ender2664 Engine, Exhaust, Transmission 32 03-21-2015 05:16 PM
Electric Power Steering control module? slicktop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-21-2013 09:38 PM
Dealer says power steering pump responsible for chirp joelg Issues | Warranty | Recalls / TSB 10 11-03-2013 09:54 AM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 11:11 AM
