#1849 | |
Drives: Scion FR-S
Sent from my Q10 |
#1850 | |
Drives: 2015 Scion FR-S
Yeah, did I see that you came from Arizona? Where at? My girlfriend and I are looking to move out there. I come from Southern California, so getting back in to some desert heat is ideal for me. I wanna drive my BRZ year round.
#1851 | |
Drives: Scion FR-S
Sent from my Q10 |
#1852 | |
#1853 |
Drives: BRZ(sold), STI
I'd avoid BC/Megan like plague. They will handle worse than stock and be very inconsistent in terms of damping rates. If you only care about looks - it's fine. If you want decent control, you're better off with stock. Buy at least entry-level quality stuff (KW/RCE etc), or stay stock.
#1854 |
Drives: 2013 Raven FR-S
I have the Unichip, front and rear strut bars, Greddy CAI, single 2.5" exhaust, BPS short shifter, MTEC shift springs and a Perrin lightweight crank pulley. I'm also going to have a lightweight battery come spring.
I don't know what class that puts me in, but I just want to do it for fun!
Three pedals, six gears, and nothing but time.
#1855 |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
Everything sounds STX legal except the strut bars. Those will put you into CSP
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
#1856 |
#1857 |
Yes it is.
Also what is the difference between STX and CSP?
#1858 |
If you're gonna be running just for fun, it won't matter. You'll be hopelessly under-prepared for either class. I'd look at participation and see which class you'd have more people to run with so that you have some benchmark.
In STX you'd probably be a set of proper wheels/tires away from being in the running for an occasional trophy, locally. I don't think CSP has been well-attended locally in recent years. A couple of well-prepared NB Miatas, might change this year, time will tell. |
#1859 |
Detroit Region, MI
STX to CSP is a fairly big leap in terms of total allowance. It's much more difficult to show up in a mainly streeted car in SP and compete well if national/divisional prepped cars are there. The biggest leap is SP allows R-compound tires like Hoosier A6, or BFG R1S etc... whereas STX you are limited to 140TW tires... hankook RS-3, BFG Rival, Dunlop Z2 etc... so there is a significant increase in commitment there needing to show up with autocross specific wheels and tires which you won't be able to drive to and from the event on (I mean you can... but you shouldn't want to)
Modification wise, stepping to SP you also no longer have to retain the emissions components, you can remove stereo components, delete the factory A/C, you can also update/backdate drivetrains to other years (IE: A 2002 WRX with a 2007 WRX motor and trans), turbo cars also can modify boost levels. The reason strut bars are not allowed in STX is because STX does not allow for chassis/structural bracing in general. There is also a big difference in which cars are competitive in each class... STX is pretty wide open, BRZ/FR-S, RX-8, E36 BMWs are all competitive among potentially others. CSP is basically "spec-miata".
#1860 |
http://www.ft86club.com/forums/showt...=1#post1468839
In case anyone was interested in my VERY thorough initial inspection of the Function7 Lower Control Arms, there ya go. Also, @dsgerbc , thanks for the input but you're about a week too late to sway me in any direction. Accurate runs them on his car and likes them, so I went for them. The guys with different manufacturer cars (Honda, Volkswagen, Ford even) seem to enjoy their Megan's, so I'll give them a shot too. Last edited by Travisty75; 01-21-2014 at 09:50 PM. |
#1861 | |
Drives: Scion FR-S
Sent from my Q10 |
#1862 | |
Detroit Region, MI
There are products wildly over-priced because they can be and are well marketed, then there are others which are better deals... In the end though... it's best to use the expectation that if they are cheap, you are getting what you pay for, and if they are expensive, they better have a damn good customer service department.
| NorCal (Bay Area) OFF-TOPIC Chat Thread | BlaineWasHere | Northern California | 12912 | 08-18-2024 04:02 AM |
| NorCal (Bay Area) DRIVE Chat Thread | MyRx | Northern California | 5559 | 07-23-2023 02:11 AM |
| *Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread | peazs | CANADA | 1397 | 06-28-2019 12:17 PM |
| Mid-Atlantic Chat Thread | clevrname | Mid-Atlantic | 5296 | 08-25-2016 01:30 PM |
| Tri-State Chat Thread | Jayde | NY / NJ / CT / PA | 182 | 05-22-2014 11:14 AM |
