Old 01-21-2014, 02:22 PM   #43
Mathewgzlz
Mathewgzlz's Avatar
Drives: 2013 SCION FR-S FIRESTORM RED
Damn it now I'm going to have to build the motor
Mathewgzlz is offline   Reply With Quote
Old 01-21-2014, 02:22 PM   #44
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Originally Posted by arghx7 View Post
Also, please release
Intake Valve open event @ 1mm lift (or .05" if you want to do it that way)
Intake Valve Close event
Exhaust Valve Open event
Exhaust Valve Close event
Cam centerlines at AVCS most advanced and most retarded position
and if possible equivalent values for the stock cams.
What would really be nice is if you can give cam angle vs lift for each cam in a .csv file so we can actually see the ramp of the cam grind between stock and the aftermarket cams.
Also, please provide any durability information you have done on the high pressure fuel pump cam. Do you have a motoring test rig or a firing engine running durability schedules? I don't think anyone here wants premature failure of their high pressure fuel pump. Even copying the stock fuel pump cam love doesn't guarantee long term durability because the dynamics of the cam change when all the other lobes are different.
Just keep in mind guys that people measure their cam durations and lift like they measure their junk. The bigger number is always better, and nobody's sure exactly how the ruler was positioned.
If I open a service manual for the BMW N20 engine, their 2.0 DI turbo engine with continuously variable valve lift and dual cam phasers I get this diagram:
I can see the full grind of the cam there when the Valvetronic is in full lift mode. I can see the actual centerlines at the limits of the phasers rather than a calculated value. I can infer how the durations were calculated by looking at the listed duration and looking at the grind of the cam.
This is the information needrf from the vendors to make a fully informed decision about camshaft options. It's more than a silly listing of numbers and abbreviations that you would see plastered all over LS1Tech.
We have the cam profiles provided by BC. However, they have asked me not to release the information at this time. We are still working with them and hope to provide information, We are sorry if this is an inconvenience.
DAMotorsports is offline   Reply With Quote
Old 01-21-2014, 02:26 PM   #45
Calum
That Guy
Drives: 2013 asphalt FRS MT
Have you also been asked to not release the stock cam profile information?
Old 01-21-2014, 02:29 PM   #46
DAMotorsports
Originally Posted by Calum View Post
How long have you been running these cams? Any issues with the di pump?
Sent from my GT-S7560M using Tapatalk
Originally Posted by mad_sb View Post
So, these cams were designed with boost or NA in mind???
The cams use the cams same DI profile as stock, no change at this time. The cams we tested are the NA cams. BC wanted to see how they would respond with FI and give a starting point to work from.
The Following 2 Users Say Thank You to DAMotorsports For This Useful Post:
Frs300 (05-21-2014), mrk1 (01-21-2014)
Old 01-21-2014, 02:29 PM   #47
arghx7
Drives: car
Thank you for being understanding.
The Following User Says Thank You to arghx7 For This Useful Post:
DAMotorsports (01-21-2014)
Old 01-21-2014, 02:36 PM   #48
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Originally Posted by lbroskee View Post
for now not sure, but I'm just thinking ahead. would rather only open the block once. in the end of it all i think i want to sit around 700 (350 on my stock block with boost and then double it after i go built)
I agree, if your plan is to make 700bhp then replace everything you can the first time. If your factory crank does let go chances are those expensive rods and pistons will go with it and you'll be shopping for a whole new shortblock.
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
lbroskee (01-21-2014)
Old 01-21-2014, 02:38 PM   #49
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
So what are the expected/estimated hp/tq gains (and rev limit with springs) on NA?
fooddude is offline   Reply With Quote
Old 01-21-2014, 02:46 PM   #50
DAMotorsports
The info we have for the stock cams is only the lift and deration as tested by BC.
Deration@.05: Intake 206
Exhaust 200
Lift@.05: Intake 268
Exhaust 265
arghx7 (01-21-2014), Calum (01-21-2014)
Old 01-21-2014, 02:57 PM   #51
mid_life_crisis
Drives: FR-S 10 #103 AT
now the only thing still kissings is a stronger crankshaft
Wow. You really like built motors. No comment on bore and stroke...
Agreed, it sucks big time when pieces that belong inside the block end up on the outside while you're driving down the road. BTDT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following 3 Users Say Thank You to mid_life_crisis For This Useful Post:
lbroskee (01-21-2014), Mathewgzlz (01-21-2014), Sportsguy83 (01-21-2014)
Old 01-21-2014, 03:10 PM   #52
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
hahaha. weirdest autocorrect EVER. but yes i do like built motors. i grew up around bikers with great built engines and love what they can do over factory
lbroskee is offline   Reply With Quote
Old 01-21-2014, 03:13 PM   #53
lexusb3
Drives: FRS
@LBroskee all i have been waiting for rods pistons cams a one time thing. I would hate to build and then open the car up again to add the cams!
lexusb3 is offline   Reply With Quote
The Following User Says Thank You to lexusb3 For This Useful Post:
Old 01-21-2014, 03:20 PM   #54
AdrianG
At least you don't have to open the bottom end to do cams, you probably don't even need to take the heads off if you do it one at a time (or if you do it in space, gravity is a bitch).
Old 01-21-2014, 03:20 PM   #55
wparsons
wparsons's Avatar
In for N/A numbers!
flickr
Dephective (01-27-2014)
Old 01-21-2014, 03:29 PM   #56
lexusb3
Drives: FRS
YA but just that fact of going in the motor lol!
Introducing Bad Luck Brian: 86 Owner Anthony Off-Topic Lounge [WARNING: NO POLITICS] 23 02-01-2014 12:42 AM
Brian (PradiG)'s Ratchet FRS Photo Journal PradiG Member's Car Journals 13 09-11-2013 02:01 AM
Anyone choose zeta stage 1 over stage 2? BlackyRose Engine, Exhaust, Transmission 2 07-06-2013 02:32 PM
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 133 05-21-2013 02:39 AM
