Old 01-19-2014, 10:29 AM   #15
stueck9356
Drives: 2015 VW GTI SE
Do both the goodridge and stoptech have the clear sleeve over the SS line to prevent chafing?
stueck9356 is offline   Reply With Quote
Old 01-19-2014, 01:44 PM   #16
teamturbo
teamturbo's Avatar
Is there any noticeable performance increase using aftermarket brake lines for just street use?
teamturbo is offline   Reply With Quote
Old 01-19-2014, 01:46 PM   #17
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
That depends on how you drive on the street
This was a modification I did before a track day. I'm not sure you really require it for street driving.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
The Following User Says Thank You to Cjymiller For This Useful Post:
teamturbo (01-19-2014)
Old 01-19-2014, 01:52 PM   #18
stugray
Drives: 2013 GBS BRZ Limited
I build race cars as a hobby. I have been told numerous times to NOT put SS brake lines on a street car because they MUST be inspected regularly as they are MORE prone to failure than stock rubber lines.
As long as you intend to thoroughly inspect them on a regular basis, then go for it.
If you are the type that never gets underneath your car , then DONT do it.
I dont think the average driver will notice any difference in braking feel.
The Following User Says Thank You to stugray For This Useful Post:
Old 01-19-2014, 05:16 PM   #19
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
What kind of failure are we talking about? I've heard this before but no one has ever said what kind of failure. Are we talking about more prone to rupturing since it allows for the transmission of such high pressures? Not trying to be an ass but really do want to know.
EDIT: NVM - I found out. SS lines are harder to visually inspect for imminent failures since the actual tubing that holds the fluid is INSIDE the SS hosing and not visible from the outside. Most of the time, race cars change these along with their pads so they never have to check them but for the street, this is a bad thing given that people assume everything will continue to work forever.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
The Following User Says Thank You to Frost For This Useful Post:
stugray (01-19-2014)
Old 01-19-2014, 06:03 PM   #20
CSG David
CSG David's Avatar
OEM brake lines are very well designed these days. If you intend to track often, the heat cycling is also an issue in that area. OEM or SS lines, replacing them on a regular basis will ensure safety and performance. We have significant experience on track and DD cars. Safety is the utmost importance for you enjoy your car.
The Following User Says Thank You to CSG David For This Useful Post:
Frost (01-19-2014)
Old 01-19-2014, 08:45 PM   #21
wparsons
wparsons's Avatar
Stoptech does for sure, can't comment on goodridge since I haven't seen them in person.
No performance difference at all, just better braking feel from less elasticity in the lines.
Stainless lines also seem to fail catastrophically at the joint from line to fitting instead of somewhere along the line.
flickr
Old 01-19-2014, 09:29 PM   #22
Trac Toy
Trac Toy's Avatar
Good ridge does not have a cover over the stainless braiding.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
The Following User Says Thank You to Trac Toy For This Useful Post:
PNW FRS (10-05-2014)
Old 01-19-2014, 10:33 PM   #23
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Originally Posted by pauland View Post
Guys, im buying some SS brake lines very soon and i've decided to go with Goodridge since several friends have used and spoke highly of them. I have noticed there are several part numbers of the goodridge brakelines that would fit the BRZ/FRS. Anybody here bought a goodridge yet? Can you kindly share the part number of the item you bought? Thanks in advance!
Pauland, I ordered mine from Jeremy at Ft86speedfactory.com. I just installed them the other day, as my previous SS brake line ruptured. Getting ready for next season Racing Idol! See you on the 25th!
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
pauland (01-28-2014)
Old 01-19-2014, 11:20 PM   #24
utekineir
blowhard
Drives: frs, project forester
Last I knew they had a couple grades of lines
The lower more common line not being coated
utekineir is offline   Reply With Quote
Old 01-19-2014, 11:29 PM   #25
Trac Toy
Trac Toy's Avatar
Could be the case. All the ones I've ever used were not coated.
.o0+Eric+0o.
2013 FRS 6MT
Old 01-21-2014, 11:29 PM   #26
Tye300
Tye300's Avatar
Their Asian market lines do. I recently swapped mine out due to one of the lines rupturing. Here's how they look.
I went with the US spec lines now. Looks much beefier.
Old 01-22-2014, 08:52 AM   #27
Noz
Drives: Ultramarine Blue FR-S
Do NOT buy the Goodridge lines. Buy the Stoptechs.
I ran the Goodridge lines for about 9 months with only 1 track day and 1 autocross day and they failed on me a couple weeks ago. I was driving normally on the street and pressed on the brakes going down hill. The pedal went all the way down like how it feels when you're bleeding the brakes. Not a fun feeling. The front line ruptured where it connects to the suspension. It looked like it was caused by a design flaw. The lines were too short causing too much of a crease at the connection points and ended up rupturing at a stress point. I swapped to the Stoptechs and they fit much better. They were a bit beefier, longer and had no stress points.
Noz is offline   Reply With Quote
Old 01-23-2014, 09:36 PM   #28
kuhlka
Drives: 2013 BRZ Limited AT
I have Goodridge lines on my STI. Combined with the Perrin MC brace, the pedal feel is firmed up a lot.
kuhlka is offline   Reply With Quote
WTB: OEM stock Brake Lines 86_ZN6 Brakes, Suspension, Chassis 3 03-12-2013 01:55 AM
Hawk brake pads and Goodridge stainless lines... seven Brakes, Suspension, Chassis 3 03-05-2013 08:07 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Goodridge Stainless Steel Brake Lines LavosTRD Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-29-2012 06:37 PM
