#393 | |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
- ecu editor is irrelevant, you said you wanted to flash an OTS tune - padding etc has to do with reading, not writing. The first 0x8000 gets padded and it doesn't matter because that part of the ROM doesn't get written when you flash. - bin and hex are number systems, not file types. - those that were bricked were recovered from what I understand. A new ECU is less than one day's pay for a big shot like you anyways Why don't you use your big smart NASA brain to develop your own tuning platform (or for that matter, your own maps) and then document all the steps so us laymen can follow along. - AdrianG |
#394 |
Drives: 2013 GBS BRZ Limited
Just for trivia, here are a couple of software errors that cost taxpayers millions:
Mars Global Surveyor - Bad Software patch (wrote to wrong portion of memory) Result - complete mission loss - spacecraft blew up in orbit of Mars Mars 98 Orbiter - Bad software units in "logging data" Result - orbiter enters mars atmosphere and is destroyed Deep Impact (ground test) - corrupt software load (still on the ground) - engineer failed to disable watchdog timer before "flashing" BOOT PROM Result - removal of flight "bricked" ECU to be disassembled to get to JTAG port Deep Impact (flight) - Bad software parameter results in exception in code BEFORE exception handler is operational. Result - Constant CPU resets until power failure - complete mission failure. I was part of every one of those "easy" operations, but it only took one misstep for complete mission failure. So Maybe I am either stupid, or "overly cautious". |
#395 |
#396 |
Given that list of "easy" mistakes, "Overly Cautious" is not a phrase I would associate with you or your colleagues.
- AdrianG |
| The Following User Says Thank You to AdrianG For This Useful Post: | SkullWorks (02-04-2014) |
#397 | |
blowhard
Drives: frs, project forester
1) get definitions linked in the rom raider thread, make sure were XML files 2) put the definitions into the correct locations and direct the respective programs to use them 3) open tune .bin of choice in rom raider and save as a .bin 4) copy stock rom from car for safekeeping using ecuflash 5) write the tune file saved with rom raider with ecuflash Not nearly as complicated or risky as reflashing the warp booster on the battle star galactica near the shoulder of Orion. But for not being a highly paid professional i was pretty pleased with myself. |
#398 | |
blowhard
He has race cars to build for fun. |
| The Following User Says Thank You to utekineir For This Useful Post: | AdrianG (01-19-2014) |
#399 | |
Install RomRaider: Retrieve Beta version of RomRaider (file: RomRaider0.5.7obdTest2-windows.zip): https://dl.dropboxusercontent.com/s/...WWhQkeA8mqZAhg Place contents of folder in location where you want to run from (this is NOT an install archive) To star RR, you must execute the 'run.bat' file Obtain desired ROM (writable) file: Locate the proper ROM file (ex. ZA1JA01C.bin) from: file: 2013 USDM BRZ ZA1JA01C.bin http://www.romraider.com/forum/downl...e.php?id=20646 Have not yet found a generic website with all ROMs. Look through this thread: http://www.romraider.com/forum/viewtopic.php?f=8&t=8475 Obtain desired RR - Defininition file: retrieve the RR definition file:RR_ZA1JA01C.xml https://raw.github.com/TD-D/SubaruDe...R_ZA1JA01C.xml Then open RR_ECU editor Click on "ECU Definitions" tab, click "ECU definition Manager" Click "Add" and browse to wherever you saved the RR_ZA1JAO1C.xml file, select the xml, Click "Open" Back in Definition manager, click Save. Now you may Open the ROM saved above. in RR, click "File"->"Open Image" Browse to where you saved the above file "2013 USDM BRZ ZA1JA01C.bin", select, click "Open" This is where you may, or may not, encounter a checksum error. It might say: Checksum No. 1 is invalid in table: Checksum Fix The ROM image may be corrupt. Use of this ROM image is not advised! Click OK Then it might say: Checksum No. 1 is invalid in table: Checksum Fix 2 The ROM image may be corrupt Use of this ROM image is not advised! Click OK ROM should open & you can look through the tables. To fix the Checksum errors you need to use ECUFlash Install ECUFlash BRZ Beta: file: ecuflash_brz_beta_144040.exe http://www.tactrix.com/downloads/ecu...ta_1444040.exe Plug in Tactrix cable and allow drivers to be installed (on Win 7, this worked fine, on XP I had to get the driver package from the tactrix site instead of what came with the brz beta) Obtain desired ECUFlash - Defininition file: file:BRZ/ZA1JA01C.xml https://github.com/TD-D/SubaruDefs/b...Z/ZA1JA01C.xml Place this file (ZA1JA01C.xml) in directory: C:\Program Files\OpenECU\EcuFlash\rommetadata\subaru\BRZ\2012 \ Open ECU_Flash: Update Firmware in Tactrix cable In ECUFlash, click "Help" - select "Licensing" If Tactrix firmware is out of date, it will be updated here automatically to 1.14.4010 Open ROM: Click "FIle" -> "Open ROM" Browse to where you saved the ROM file: 2013 USDM BRZ ZA1JA01C.bin Click file, click "Open" IF you had checksum errors, a message will pop up: "The ROM you have loaded has one or more incorrect checksum values. Do you wish to correct them? Click "Yes" You should now be able to see the values of the tables for the ROM you selected. If the ROM is ready to be written, the red-arrow icon "Write calibration and code area using OEM method" will be "clickable" You are now ready to plug into your car and flash away. Final steps TBD - havent done it yet Yeah, that is all just obvious and "anyone" can do it in just 5 minutes. |
#400 |
#401 | ||
"confirming that the iginition" Maybe a max chars per post thing? |
#402 |
Thanks again.
So I downloaded the ROM from my car (ZA1J700C). It seemed to work fine. However when I try to save the ROM Image, it doesnt matter if I select "Structured ROM files (*.srf)" or "RAW ROM Files (*.bin *.hex)" it always saves in *.srf format. I dont want to try to write until I have saved off my stock ROM (just in case). Is this expected? I assume that I need to save it in *.bin or I would not have any hope of restoring it in the future. |
#403 |
I compared the 'read_image.srf' to a stock_rom.bin for the ZA1J700C that I downloaded from the RR thread with hex editor.
They appear to be exactly the same except the *.srf file is missing the 0x0000-8000 padding. I tried saving as both *.srf & *.bin thinking they might just be backwards in the pulldown menu. Both times (to different paths) the files showed up as *.srf I tried to attach the *.srf file, but it says "Invalid file". I'll reboot everything and try again. |
#404 | |
Yes I use: File -> Save As, and in the pullup I select "Raw ROM Files (*.bin *.hex)" It saves it as:read_image.srf If I select save as *.srf, it saves it as a *.srf When you say it works: So the file gets saved as 'read_image.bin"? Here is a video of my trying all of the options: http://s366.photobucket.com/user/stu...55606.mp4.html I guess I'll try to reinstall ECUFlash. This is on an XP machine BTW |
#405 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Ai yai yai... anyhoo, with the pissing match now over
I'll just add that the words 'Alpha' and 'Beta' are there for a reason.Remember guys, this is open source - all of us do this in our spare time, after our day jobs. And trust me, I could also 'earn' all the donations I've received in 2 years for the 100+ definitions I've posted, and all the ecu analysis work, in a morning - it's not why I do it. Moving right along - thanks VGI and Stugray for putting that how to up. Just a heads up, I was requested to move the BRZ definitions with the OFT LC/FFS tables into their own branch (OFT) (here: https://github.com/TD-D/SubaruDefs/tree/OFT) If you're looking for the Ecuflash definitions, look here: https://github.com/TD-D/SubaruDefs/tree/Alpha/ECUFlash - you will also need the updated 32bitbase.xml - here: https://raw.github.com/TD-D/SubaruDe.../32BITBASE.xml The easiest thing to do it to download the entire repository, and then point Ecuflash to the Subarudefs directory. Even better, albeit more of a learning curve, is to set up a local Github repository, and then point Ecuflash to that directory. That way, you can update the entire directory regularly (easily, using Github with a GUI) and you'll have whatever new and exciting stuff I've added recently Granted, Github is a bit of a ballache to get your head around initially...
#406 |
Drives: 13 CSB BRZ Ltd
Is there any way to discover CANbus definitions/addresses/data using the OpenPort or ECUFlash?
| Close | iJason | Member's Car Journals | 1 | 08-04-2013 08:26 PM |
| Close | pche | Engine, Exhaust, Bolt-Ons | 3 | 08-04-2013 02:04 AM |
| Sorry. please close. | finch1750 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-31-2013 01:00 AM |
| please close | abutterman | Wheels and Tires | 0 | 07-05-2013 09:40 AM |
