Old 09-06-2013, 03:02 PM   #85
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Can those camber plates be installed on stock shocks with only lowing spring?
Originally Posted by track_warrior View Post
Vorshlag has camber plates out for the car btw. I got them installed yesterday.
Here are some pics of them installed on my car:
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 09-06-2013, 04:10 PM   #86
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
No.they said they would be making a oem spring perch for us that has not happened.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 09-06-2013, 04:20 PM   #87
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Would you consider these?
HVT Camber Plates
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-06-2013, 09:54 PM   #88
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
HVT Camber Plates
How do you like the HVT camber plates?
Phaedrus29 is offline   Reply With Quote
Old 09-06-2013, 10:13 PM   #89
tonystewart
Excellent Product, well thought out design, doesn't raise the front.
Easy to adjust, quiet, noise free operation.
Accommodates the Konis and the Swifts very easily.
Quiet operation. No additional NVH.
We like them.
Old 01-10-2014, 06:11 PM   #90
wahsaihin
Drives: 2013 Subaru BRZ Sport-Tech
bump.
just wondering if I will need a camber kit/bolts or crash bolts for my application. I will have a set of kwv3 installed (will use out of box settings) and 18x8 wheels with 245/35 tires on them.
i am a former s2000 owner and used the car as a weekend road course warrior. i had an HKS hipermax 3 suspension on it and 255/40 all around. without any camber kits or mods, the car was set up with -3.5R and -2.0F for camber.
i am not looking for anything as aggressive this time, but am thinking of something like -2.5R and -1.5F for camber this time. what do I need to make this work based on the aforementioned?
thanks
wahsaihin is offline   Reply With Quote
Old 01-13-2014, 02:44 PM   #91
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Wanted to ask:
How much max neg camber are you guys able to get using only/just the OEM crash camber bolts?? (ie: SU003-02818)
More, or less, or the same, as the Whiteline cam bolts?
More attracted to the OEM... since, it's OEM quality afterall, he he.
fooddude is offline   Reply With Quote
Old 01-19-2014, 01:29 PM   #92
fooddude
Originally Posted by fooddude View Post
Wanted to ask:
bump..max camber?
Old 01-20-2014, 03:34 PM   #93
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
bump..max camber?
Not sure how it compares against Whiteline but max neg camber I got from OEM camber bolts was -1.2.
The Following User Says Thank You to switchlanez For This Useful Post:
Bristecom (02-04-2014)
Old 01-20-2014, 05:55 PM   #94
fooddude
@switchlanez: nice thanks... that sounds like a good amount with just bolts for us poor people that can't afford COs/Upper-Plates yet
Old 03-08-2014, 10:02 PM   #95
Tiago
Tiago's Avatar
Drives: 2014 BRZ
Originally Posted by ft86Fan View Post
Just ordered two SU003-02818 at $7.95 each. They said there are only a few of them in the whole country. We can just reuse the nut from the upper bolt for this right?
How did this work out for you? I'm going to be tracking my car soon so I'll be needing to do this too. Any installation tips?
Also, where do you guys recommend getting alignments?
Tiago is offline   Reply With Quote
Old 03-10-2014, 05:31 PM   #96
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
It was a while ago I had these installed and they work pretty good. I have -1.3° left and right and thats the max that I can get out of those bolts. My brother has a BRZ and he didn't get these bolts (and he has stock alignment) and my car definitely feels better.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 03-10-2014, 10:07 PM   #97
Pat
Pat's Avatar
Drives: 2023 BRZ
I maxed at -1.2 with WL bolts on stock everything else.
Old 03-10-2014, 11:21 PM   #98
Tiago
Tiago's Avatar
Drives: 2014 BRZ
Thanks guys, I'll be probably be purchasing these soon.
Installed coilover; Too much camber in the back. trueno86power Suspension | Chassis | Brakes -- Sponsored by 949 Racing 69 04-11-2016 07:00 AM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
Camber arms? skoodge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 06-24-2012 10:09 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
