Old 01-15-2014, 12:02 AM   #99
tvpr
tvpr's Avatar
Drives: 2013 Asphalt FR-S 6MT
For anyone who wants to see what the black housing looks like on asphalt:
Name:  2014-01-11 15.29.43.jpg
Name:  2014-01-12 16.27.05.jpg
Name:  2014-01-12 16.26.37.jpg
tvpr is offline   Reply With Quote
The Following 6 Users Say Thank You to tvpr For This Useful Post:
86SPEED (01-16-2014), Mooseknuckle44 (03-27-2014), SkAsphalt (01-15-2014), SlammedSilly (05-25-2016), TheLaughingMan (06-24-2014), wdninja (01-15-2014)
Old 01-16-2014, 01:15 AM   #100
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
86SPEED is offline   Reply With Quote
Old 01-16-2014, 01:23 AM   #101
YDNA
YDNA's Avatar
Drives: Raven FR-S
YDNA is offline   Reply With Quote
The Following 13 Users Say Thank You to YDNA For This Useful Post:
86SPEED (01-16-2014), Alexm_09 (01-17-2014), Bcarlos (01-28-2014), CrazyWookiee (01-17-2014), HATED1 (01-16-2014), M-17 (02-12-2014), MisterSheep (02-01-2017), Redlinedfrs86 (01-16-2014), RZ86 (01-16-2014), Slartibartfast (03-26-2014), SnapOv3st3r (02-21-2014), snk828 (02-25-2014), SP86 (01-30-2014)
Old 01-17-2014, 12:52 PM   #102
tC2FR-S
I baked them and used a heat gun. Had no issues with LED. However, they do not use same type of sealant as OEM. They use a rubber gasket and what looks to be a very thin bead of silicon caulk. I was surprised. Could be why some people have moisture problems. Not sure you even need to heat them up to open. I sealed back up with OEM type OCI Burly rubber.
Originally Posted by Onyx2013 View Post
How did you open them up? baking? heat gun? Any issues with heat as it pertains to the LED strip?
tC2FR-S is offline   Reply With Quote
The Following User Says Thank You to tC2FR-S For This Useful Post:
rcm47 (01-17-2014)
Old 01-17-2014, 01:09 PM   #103
tC2FR-S
Figured I'd share a pic of mine.
Have never posted a pic on here so I apologize if it doesn't come in correctly or not at all.
The Following 5 Users Say Thank You to tC2FR-S For This Useful Post:
86SPEED (01-17-2014), bellison13 (01-30-2014), Fett4Real (01-17-2014), rcm47 (01-17-2014), sal (02-11-2014)
Old 01-17-2014, 02:45 PM   #104
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
They look great man...so you might not even need to bake them huh? INTERESTING...and were you the one who said you had issues with the chrome and the tape? More info please...they look sooooo much better then all chrome or all black...Having a dark colored car I dont want to go black....will settle for chrome and have taken apart headlights before...just like to plan ahead. Buying a set from Phasetek.
Fett4Real is offline   Reply With Quote
Old 01-17-2014, 02:45 PM   #105
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
Looks good! I was waiting for someone to do this. Step by step DIY?
rcm47 is offline   Reply With Quote
The Following User Says Thank You to rcm47 For This Useful Post:
*KID* (01-18-2014)
Old 01-17-2014, 07:14 PM   #106
tC2FR-S
I didn't try it without baking them but I think you can just out take the 6 screws out in the back of the light and pull them apart with some elbow grease. It looked like it was just caulk holding it in so I don't see how applying heat would loosen it up
I've opened up Acura TL, Acura TSX, Honda s2000, Scion tc, and the FR-S lights and none of them were sealed like the winjets.
And yes I had a few minor issues with the chrome peeling off. I just had to touch up a few small spots with silver paint to cover up the black plastic that became exposed. I still would do it again if I had too because I really like the look. I would just say use high quality painters tape for delicate surfaces, take your time, only tape where necessary, again peel away really slowly? And finally, take the tape off within a few hours of your final coat of paint. Don't leave it on overnight.
The Following 2 Users Say Thank You to tC2FR-S For This Useful Post:
Fett4Real (01-17-2014), rcm47 (01-18-2014)
Old 01-17-2014, 07:17 PM   #107
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Copy that thanks...
Old 01-17-2014, 07:27 PM   #108
tC2FR-S
I am going to open up my passenger light when I get some time. The rotation of the projector is a little off. I can take more pics then. It wasn't easy fitting a TL projector in there. Basically had to cut the original mounting bracket down to where it there was very little left and had to cut the bottom of the bracket totally off so the bixenon solenoid could fit. I was a little nervous the projector and bracket would vibrate for lack of support however I used a lot JB Kwik weld and have no problems now.
Here's a couple of other pics I originally took during the project
rcm47 (01-18-2014)
Old 01-17-2014, 07:53 PM   #109
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
You wont have high and low beam that way will you?
Old 01-17-2014, 08:43 PM   #110
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
the TL projectors he put in are bi-xenon hid. has hi and low beams.
The Following User Says Thank You to m.box.design For This Useful Post:
VakaGT (03-09-2014)
Old 01-17-2014, 11:00 PM   #111
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
if you had a whiteout fr-s will you go chrome winjets or black?
914_WHITE_FRS is offline   Reply With Quote
Old 01-17-2014, 11:13 PM   #112
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Do you want a change or keep OEM look.
Black for change
Chrome foe OEM.
Ryan86 is offline   Reply With Quote
Winjet Headlights and HIDs HakunaMiata Cosmetic Modification (Interior/Exterior/Lighting) 27 07-18-2017 10:24 PM
New Winjet Headlights LED FLICKER?! Jeremehh Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 03:26 PM
Winjet Headlights - Installed, Compared, and done up the FT-86 SpeedFactory Way! FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 42 03-24-2014 11:08 PM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 08:28 AM
Norcal GB: Winjet JDM Style Headlights 86_ZN6 Northern California 2 12-11-2013 03:31 PM
